S12X Memory
S12X Memory
rayhall
Contributor V
Why does my S12XE have dashes "-" at memory address 0x120000
See attached image.
Ray.
ZhangJennie
Hi Ray,
In CW full chip simulation mode ( without connecting board ), for the memory that is not initialized or used, it shows as dashes "-" in memory window. If you define data or code to these addresses,  dashes "-" will be changed.
Jennie Zhang
