dpaa2_net: dpni disable failed (-110) DPAA2, DPDK
Question asked by nic nic on Aug 1, 2018
Latest reply on Aug 15, 2018 by Yiping Wang
I am using DPDK on LS2088ardb board.
I have allocated 1 DPNI and connected it to 1 DPMAC.1 (SPF+).
When I start DPDK testpmd application it works and can be closed only if incomming trafic is ~100 pkt/s.
If I send packets on wirespeed from another PC testpmd application can not be closed (even after traffic generator is stopped)
There is only one error:
Shutting down port 0...
Stopping ports...
dpaa2_net: Failure (ret -110) in disabling dpni 0 dev
Done
Closing ports...
dpaa2_net: Failure cleaning dpni device: err=-110
Done
If I run testpmd application it can not receive any packets.
Output from /dev/fsl_mc_console
[E:36f3b2a5ec, ifp_mng_cmd_enqueue:1708, CTLU]  Busy: No available Management command descriptor
[E:36f43fbafc, ifp_mng_cmd_enqueue:1708, CTLU]  Busy: No available Management command descriptor
[E:36f4cccaf0, ifp_mng_cmd_enqueue:1708, CTLU]  Busy: No available Management command descriptor
[E:36f9c18a2e, qbman_rec_isr:354, QBMAN]  QBMAN recoverable event 0x20040000
[E:36fb871426, qbman_rec_isr:387, QBMAN]  [FQ#7]: 12036
What does error -110 means? Is there any document about  /dev/fsl_mc_console ?
