the available ram size of the s32k142 is about 12k ,why?
18682445387
the ide is  iar for arm
danielmartynek
The MCU has two SRAM regions.
It seems that the 12K of SRAM is the SRAM_U region.
But I'm not familiar with IAR.
danielmartynek
18682445387
First of all ,Thank you for you help  At first, I wanted to apply for 28k memory, but I could not apply for insufficient space. Now it seems that the data space most supported is 16k, to apply for larger data may only be able to another method.
smith
