what are the difference between mask 1N81M and 0N78S
laxmikanthindur
Hello ,
 I have 2 different versions of 5748G controllers with me,  first one is PPC5748GSMKU6, 0N78S, QQAD1849F
and the second one is SPC5748GSMKU6 ,1N81M, QAR1702AF.
I am able to flash and  see my application working perfect in the first controller board where as for the second board it is not.
some one please help me to know the difference between both the controllers to get my application working in second controller board also
thanks in advance
Best Regards
Laxmikanth Indur
petervlna
Hello guys,
Please see attached presentation which brings more light on the differences between those 2 device cuts.
Peter
wangtezi
Hello  Laxmikanth Indur
I have the same problem, are you solved it?
Would you share your method with me?
thanks in advance
Best Regards
