On-chip Flash memory JN5168
gibish
Hello!
I want to record my data on on-chip Flash memory JN5168.
Initialize memory
bAHI_FlashInit(E_FL_CHIP_INTERNAL, NULL);
When I try to erase two last sectors bAHI_FlashEraseSector(6) and bAHI_FlashEraseSector(7), I get TRUE.
But when I try to record data bAHI_FullFlashProgram(addrTemp, 2, &stepData); – I always get FALSE.
As addrTemp I tried addresses in range 0x0–0xFFFFFFFF with step 0x8000.
Is it the possibility to record user data on on-chip Flash memory JN5168?
Thank in advance.
mario_castaneda
Hi Igor,
Please look at the parameter.
Parameters
  • u32Addr Address offset from start of Flash memory of first byte to be programmed (must be on a 16-byte boundary)
  • u16Len Number of bytes to be programmed (must be a multiple of 16 up to 0x8000)
  • *pu8Data Pointer to start of data block to be written to Flash memory
Mario
gibish
Thanks Mario, it seems to work :smileyhappy:
