How to compile mfgtool uboot under android 8.1
hannywei
hi
I am using i.mx8m
After modifing uboot source code, I want to know how to  compile mfgtool uboot under android 8.1?
传策薛
Contributor V
Have you solved this problem?
hannywei
NO
传策薛
Contributor V
I sovled it,we should build another mfgtool uboot image,should change the uboot source,and there are some uboot errors we should fix it!
hannywei
Can you share me the change and code?
Rita_Wang
I am confiming it for you.
hannywei
any update?
hannywei
Have you confirmed it?
Rita_Wang
I have If the DDR is the same as our refrence board, you can directly use the default mfgtool. You do not need to build the mfgtool firmware. If you change the DDR you need to rebuild the firmware for your board mfgtool, About the mfgtool uboot here you can use the same one uboot image with your board uboot image.
Have a nice day
Rita
hannywei
HI
The  DDR is same.
Do you have a test? we have tried and failed.
Rita_Wang
Here you can use the default mfgtool u-boot, and you need to copy your board images to the mfgtool file. Could you tell me your details steps?
hannywei
The default mfgtool u-boot can not work.
sure ,I copy the board images to he mfgtool file , i following the guidance document.
the steps is the same as  i.MX8MQ u-boot和mgftool烧写emmc失败
Rita_Wang
You can refer to our user guide document. And here could you tell me which flash you download the images to , EMMC or SD card?
Rita_Wang
hannywei
Not success,my question is same as https://community.nxp.com/thread/479888 。
Rita_Wang
About the mfgtool uboot here you can use the same one uboot image with your board uboot image. You do not need to compile special for it. You can have a try.
Rita
hannywei
hi Rita Wang
any update?
hannywei
Not success,my question is same as i.MX8MQ u-boot和mgftool烧写emmc失败 。
