Error to import the FRDN-KL25Z SDK on MCUXpresso IDE
leandrodantas
I was using version 10.2.0 of the MUCXpresso IDE with the SKD for the FRDM-KL25Z.
Today when I opened the IDE the sdk did not appear as installed, I tried to reinstall but there were error messages.
I installed version 10.2.1 but the error continues and I can no longer compile my programs.
Attached is the log.
What should I do?
danielchen
Hi Leandro:
I would suggest you delete your work space (backup if you need it),  and try it again
