Swapping P/N on CBTL02043ABQ
avihayf
Hey,
I'm using 2:1 Mux, P/N CBTL02043ABQ.
Due to layout difficulties, I want to swap between P & N signals in the "IN" side of the mux, and swap them again in the "OUT" side of the mux (to keep the correct polarity).
See example below:
According to the datasheet, there are no active parts (i. e. Pull up / Pull down / OD / ...) inside the mux that prevent me from doing the swap.
Is it possible to use the mux this way (regarding it internal electrical implementation)?
Avihay.
TomasVaverka
Hi Avihay,
Yes. P and N channel are symmetrical.
Tomas
