TimeSys uboot/bsp/rootfs and build environement for iMX6UL
johnot
    Whether Timesys based boot/bsp/rootfs and build environement available for iMX6UL? How to get it?
Is there any license required for it?
JOT
timesyssupport
Senior Contributor II
Hi JOT,
Yes, we do support the i.MX6UL EVK. Our landing page for this board is here: i.MX6UL EVK - LinuxLink
You can create a free LinuxLink account at https://linuxlink.timesys.com/register/.  Your free account will enable you to:
  • Build a custom BSP — From the dashboard, simply create a build, select a target and jump into customizing your board support package.
  • Use Yocto and LinuxLink Factory build engines  — Timesys now offers two build engines to choose from. Evaluate both systems and choose the one best for your project.
  • Download our prebuilt images — Get started right away with one of our demos.
  • Try TimeStorm IDE free for 30 days — Generate a 30-day license to unlock all the features of TimeStorm, enabling you to try it for that period of time.
  • Access our documentation — If you get stuck or want to learn more, you can check out our extensive documentation.
Prior to downloading your customized build or any available starting point/prebuilt image, you will be prompted to read and accept the license to view and download files.
In addition to enabling you to build a custom BSP, we also provide:
Timesys Support
timesyssupport
Hi JOT,
Timesys Support
gusarambula
Hello JOT,
They do have support for i.MX6UL as part of their BSPs:
https://www.timesys.com/open-source-embedded/bsp-tools/reference-bsp/processors/nxp/
timesyssupport, would you please help us with details on how to obtain a specific BSP and licenses required for its use?
