Lpc1517 build setting
Question asked by Martin Pelletier on Jul 20, 2018
I am working on LPC1517.
I am using uvision5.
I builded my program code and i got my hex file without error.
But when i programmed my lpc1517 with this version,  it does not start!!!
If i remove one line code ex: i++; and i rebuild it .. it is working!!! But i need to add some functions but i can't!!!
It likes i reached a limit but my flash has 256KB and my code takes only 60KB.
I had enough space of ram too.
And i can use only Level 0 (the program is not working if i use the other other level??)
Which is my problem?? (i attached my map file just in case)
Thx for your response
