Dave Jones
TK_BLOCK vs TK_SLEEP ?????
Discussion created by Dave Jones on Nov 17, 2008
Latest reply on Nov 18, 2008 by Dave Jones
I built a board that is similar to the M52235EVB board, with a few different pieces of hardware.
I am using Codewarrior 7.1 and the new ColdFire Lite 3.0 code that was released a few weeks ago.
I am using the ColdFire Lite RTOS build
I have created a couple of tasks and run them, and they work fine if I use TK_SLEEP(1) in them. If I use TK_BLOCK() then my task is never heard from again.
From the documentation I was under the impression that TK_BLOCK gives up control to the next available task, and I was under the impression that control would return to my task after one cycle through the list of tasks.
This does not appear to be the case.
Am I misunderstanding TK_BLOCK? or is there a bug in the 3.0 version of ColdFire Lite RTOS build?
