I imported the S32R274 Radar RTM 1.0.0 Example into the S32DS for PA 2017.
I builded it successfully, but after I ran the Z4 and Z7_0 Core, the tftp_client_write function in Z4 Core encountered an error. The Error Info is shown below.#@@@
Thanks a lot.S32 Design StudioAutomotive MCUs / MPUs and Tools
Solved! Go to Solution.
I tried the example - and for me is working normally - but I don't use any communication channel, only PE Micro. I tried to locate tftp.c file - but it is part of library.
What is your scenario settings?
Jiri
Jiri
