on a stm32 arm it is possibel to generate a pwm in one pulse mode. It means that output is generated for only one iteration of the autoreload.
Is this possible on s32k as well?
At the moment I realized this by setting up an interrupt and disable the PWM after the first iteration. Is it possible to this without an interrupt?
Thx
S32K FTM doesn't have this one-pulse mode.
I think the easiest way is to use the interrupt.
