To implement C/C++ delay() for MPC5748G(S32 DS)
barkly_lin
Just found someone implement delay() function with interrupt + timer by using C language.
Is it possible to achieve that with easier way? or S32 DS may already has function available in library?
jiri_kral
using PIT is the right way. If you are using SDK - there is PIT module which can be used for timing.
Jiri
