Setting IP in MPC5748G LCEVB
rahulramakrishn
In my project I need to send data from one board to the MPC5748G LCEVB board. In order to send the data I need to set the IP address for both the device. How can I configure Ethernet in MPC5748G LCEVB so that I can able to set the IP address? Is there any example projects available?
martin_kovar
I sent you the answer in the thread below:
https://community.nxp.com/thread/480417
Martin
rahulramakrishn
Ok. Thank you for support.
