I Create an example(hello world) project using S32 DS , when i debug ,it always reports "No source available for "0x0" "
don't know what is the problem ? actually, the problem doesnt' do anything , only delay
for (;;)
/* Insert a small delay to make the blinking visible */
delay(720000);
/* Toggle output value LED0 & LED1 */
// PINS_DRV_TogglePins(GPIO_PORT, ((1 << LED1) | (1 << LED2)));
your program ends in exception for some reason (clock issue?). Did you modify the example? Unfortunately I don't have board with S32K118 and can't test the hello word by myself. But when I look at the code - the example looks okay and should work.
Jiri
