mxc_vpu_test.out work on fb0 will led Screen flicker on imx6q
stevenhuang
when I test imx6q FB0(video 16)with mxc_vpu_test.out, the Screen flicker. But it can work normally on fb1(video17) , how can dell this issue?
joanxie
I  got two cases which have the similar contents, and I reply to you in another case, any update, pls follow that one.
stevenhuang
thks for 有 answer, i will close this case。
