MCUXpresso Config Tools
sd886189
MCUXpresso Config Tools 多次尝试安装失败。下面是弹出的LOG文件,请帮助看看是什么原因导致安装失败。感谢!
=== Verbose logging started: 2018\7\14 星期六 8:29:55 Build type: SHIP UNICODE 5.00.7601.00 Calling process: C:\Users\Administrator\Desktop\ImxRT\RT1050\MCUXpresso_Config_Tools_v4.1_x64.exe ===
MSI (c) (48:94) [08:29:55:808]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\ADMINI~1\AppData\Local\Temp\AIE6B11.tmp' against software restriction policy
MSI (c) (48:94) [08:29:55:809]: SOFTWARE RESTRICTION POLICY: C:\Users\ADMINI~1\AppData\Local\Temp\AIE6B11.tmp has a digital signature
MSI (c) (48:94) [08:29:55:971]: SOFTWARE RESTRICTION POLICY: C:\Users\ADMINI~1\AppData\Local\Temp\AIE6B11.tmp is permitted to run at the 'unrestricted' authorization level.
MSI (c) (48:94) [08:29:56:137]: Cloaking enabled.
MSI (c) (48:94) [08:29:56:137]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (48:94) [08:29:56:143]: End dialog not enabled
MSI (c) (48:94) [08:29:56:143]: Original package ==> C:\Users\ADMINI~1\AppData\Local\Temp\AIE6B11.tmp
MSI (c) (48:94) [08:29:56:143]: Package we're running from ==> C:\Users\ADMINI~1\AppData\Local\Temp\AIE6B11.tmp
MSI (c) (48:94) [08:29:56:150]: APPCOMPAT: Compatibility mode property overrides found.
MSI (c) (48:94) [08:29:56:153]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5FCE01F9-B255-4E47-97D4-C669C4115DCF}'.
MSI (c) (48:94) [08:29:56:154]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (48:94) [08:29:56:169]: MSCOREE not loaded loading copy from system32
MSI (c) (48:94) [08:29:56:204]: Machine policy value 'TransformsSecure' is 0
MSI (c) (48:94) [08:29:56:204]: User policy value 'TransformsAtSource' is 0
MSI (c) (48:94) [08:29:56:207]: Note: 1: 2205 2: 3: MsiFileHash
MSI (c) (48:94) [08:29:56:207]: Machine policy value 'DisablePatch' is 0
MSI (c) (48:94) [08:29:56:207]: Machine policy value 'AllowLockdownPatch' is 0
MSI (c) (48:94) [08:29:56:207]: Machine policy value 'DisableLUAPatching' is 0
MSI (c) (48:94) [08:29:56:207]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (c) (48:94) [08:29:56:210]: APPCOMPAT: looking for appcompat database entry with ProductCode '{5FCE01F9-B255-4E47-97D4-C669C4115DCF}'.
MSI (c) (48:94) [08:29:56:210]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (48:94) [08:29:56:210]: Transforms are not secure.
MSI (c) (48:94) [08:29:56:210]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Users\ADMINI~1\AppData\Local\Temp\MSI6B41.LOG'.
MSI (c) (48:94) [08:29:56:210]: No Command Line.
MSI (c) (48:94) [08:29:56:210]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{0F96A007-D81C-4E46-B86F-D529D2CEE8BC}'.
MSI (c) (48:94) [08:29:56:210]: Product Code passed to Engine.Initialize: '(none)'
MSI (c) (48:94) [08:29:56:210]: Product Code from property table before transforms: '{5FCE01F9-B255-4E47-97D4-C669C4115DCF}'
MSI (c) (48:94) [08:29:56:210]: Product Code from property table after transforms: '{5FCE01F9-B255-4E47-97D4-C669C4115DCF}'
MSI (c) (48:94) [08:29:56:210]: Product not registered: beginning first-time install
MSI (c) (48:94) [08:29:56:210]: PROPERTY CHANGE: Modifying ALLUSERS property. Its current value is '2'. Its new value: '1'.
MSI (c) (48:94) [08:29:56:210]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI (c) (48:94) [08:29:56:211]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (c) (48:94) [08:29:56:211]: User policy value 'SearchOrder' is 'nmu'
MSI (c) (48:94) [08:29:56:211]: Adding new sources is allowed.
MSI (c) (48:94) [08:29:56:212]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI (c) (48:94) [08:29:56:212]: Package name extracted from package path: 'AIE6B11.tmp'
MSI (c) (48:94) [08:29:56:212]: Package to be registered: 'AIE6B11.tmp'
MSI (c) (48:94) [08:29:56:212]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (c) (48:94) [08:29:56:212]: Machine policy value 'DisableMsi' is 0
MSI (c) (48:94) [08:29:56:212]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (c) (48:94) [08:29:56:212]: User policy value 'AlwaysInstallElevated' is 0
MSI (c) (48:94) [08:29:56:212]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI (c) (48:94) [08:29:56:212]: Running product '{5FCE01F9-B255-4E47-97D4-C669C4115DCF}' with elevated privileges: Product is assigned.
MSI (c) (48:94) [08:29:56:213]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI (c) (48:94) [08:29:56:213]: TRANSFORMS property is now:
MSI (c) (48:94) [08:29:56:213]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI (c) (48:94) [08:29:56:213]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\AppData\Roaming
MSI (c) (48:94) [08:29:56:215]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\Favorites
MSI (c) (48:94) [08:29:56:216]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (c) (48:94) [08:29:56:217]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\Documents
MSI (c) (48:94) [08:29:56:218]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (c) (48:94) [08:29:56:219]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Recent
MSI (c) (48:94) [08:29:56:220]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\SendTo
MSI (c) (48:94) [08:29:56:221]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Templates
MSI (c) (48:94) [08:29:56:221]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (c) (48:94) [08:29:56:222]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\AppData\Local
MSI (c) (48:94) [08:29:56:223]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\Pictures
MSI (c) (48:94) [08:29:56:224]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (48:94) [08:29:56:225]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (48:94) [08:29:56:226]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs
MSI (c) (48:94) [08:29:56:227]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu
MSI (c) (48:94) [08:29:56:227]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (c) (48:94) [08:29:56:229]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (48:94) [08:29:56:230]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (48:94) [08:29:56:231]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Start Menu
MSI (c) (48:94) [08:29:56:231]: SHELL32::SHGetFolderPath returned: C:\Users\Administrator\Desktop
MSI (c) (48:94) [08:29:56:233]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (c) (48:94) [08:29:56:234]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI (c) (48:94) [08:29:56:236]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 20
MSI (c) (48:94) [08:29:56:245]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI (c) (48:94) [08:29:56:245]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI (c) (48:94) [08:29:56:245]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (c) (48:94) [08:29:56:245]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (c) (48:94) [08:29:56:246]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'User'.
MSI (c) (48:94) [08:29:56:246]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (c) (48:94) [08:29:56:246]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'China'.
MSI (c) (48:94) [08:29:56:246]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Users\ADMINI~1\AppData\Local\Temp\AIE6B11.tmp'.
MSI (c) (48:94) [08:29:56:246]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Users\ADMINI~1\AppData\Local\Temp\AIE6B11.tmp'.
MSI (c) (48:94) [08:29:56:246]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (c) (48:94) [08:29:56:246]: EEUI - Disabling MsiEmbeddedUI due to existing external or embedded UI
MSI (c) (48:94) [08:29:56:246]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Users\ADMINI~1\AppData\Local\Temp\'.
MSI (c) (48:94) [08:29:56:246]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Users\ADMINI~1\AppData\Local\Temp\'.
MSI (c) (48:9C) [08:29:56:246]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
=== 记录开始: 2018\7\14 星期六 8:29:56 ===
MSI (c) (48:94) [08:29:56:249]: Note: 1: 2262 2: PatchPackage 3: -2147287038
MSI (c) (48:94) [08:29:56:249]: Machine policy value 'DisableRollback' is 0
MSI (c) (48:94) [08:29:56:249]: User policy value 'DisableRollback' is 0
MSI (c) (48:94) [08:29:56:249]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
MSI (c) (48:94) [08:29:56:249]: MsiOpenPackageEx is returning 0
MSI (c) (48:94) [08:29:56:249]: MsiOpenPackage is returning 0
MSI (c) (48:94) [08:29:56:249]: Note: 1: 2205 2: 3: MultipleInstancesProps
MSI (c) (48:94) [08:29:56:249]: Note: 1: 2228 2: 3: MultipleInstancesProps 4: SELECT `PropertyValue` FROM `MultipleInstancesProps`
MSI (c) (48:94) [08:29:56:253]: PROPERTY CHANGE: Adding AIEXTERNALUI property. Its value is '5'.
MSI (c) (48:94) [08:29:56:253]: PROPERTY CHANGE: Adding TRANSFORMS property. Its value is ':2052'.
MSI (c) (48:94) [08:29:56:253]: PROPERTY CHANGE: Adding AI_SETUPEXEPATH property. Its value is 'C:\Users\Administrator\Desktop\ImxRT\RT1050\MCUXpresso_Config_Tools_v4.1_x64.exe'.
MSI (c) (48:94) [08:29:56:254]: PROPERTY CHANGE: Adding AI_LOGFILELOCATION property. Its value is 'C:\Users\ADMINI~1\AppData\Local\Temp\MSI6B41.LOG'.
MSI (c) (48:94) [08:29:56:254]: PROPERTY CHANGE: Adding SETUPEXEDIR property. Its value is 'C:\Users\Administrator\Desktop\ImxRT\RT1050\'.
MSI (c) (48:94) [08:29:56:254]: PROPERTY CHANGE: Adding EXE_CMD_LINE property. Its value is '/exenoupdates '.
MSI (c) (48:94) [08:29:56:254]: PROPERTY CHANGE: Modifying SourceDir property. Its current value is 'C:\Users\ADMINI~1\AppData\Local\Temp\'. Its new value: 'C:\Users\Administrator\AppData\Roaming\NXP Semiconductors\MCUXpresso Config Tools 4.1.0.48\install\'.
MSI (c) (48:94) [08:29:56:254]: PROPERTY CHANGE: Adding PRIMARYFOLDER property. Its value is 'APPDIR'.
MSI (c) (48:94) [08:29:56:254]: PROPERTY CHANGE: Adding AI_IE_Ver property. Its value is '9'.
MSI (c) (48:94) [08:29:56:254]: PROPERTY CHANGE: Adding AI_IE_MinorVer property. Its value is '0'.
MSI (c) (48:94) [08:29:56:254]: PROPERTY CHANGE: Adding AI_BOOTSTRAPPER property. Its value is '1'.
MSI (c) (48:94) [08:29:56:254]: Doing action: AI_DpiContentScale
操作 8:29:56: AI_DpiContentScale。
操作开始 8:29:56: AI_DpiContentScale。
MSI (c) (48:F0) [08:29:56:258]: Invoking remote custom action. DLL: C:\Users\ADMINI~1\AppData\Local\Temp\MSI6D06.tmp, Entrypoint: DpiContentScale
MSI (c) (48:F4) [08:29:56:260]: Cloaking enabled.
MSI (c) (48:F4) [08:29:56:260]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (48:F4) [08:29:56:260]: Connected to service for CA interface.
MSI (c) (48!14) [08:29:56:454]: PROPERTY CHANGE: Adding AI_SYSTEM_DPI property. Its value is '120'.
MSI (c) (48!14) [08:29:56:454]: PROPERTY CHANGE: Adding AI_SYSTEM_DPI_SCALE property. Its value is '125'.
操作结束 8:29:56: AI_DpiContentScale。返回值 1。
MSI (c) (48:94) [08:29:56:479]: PROPERTY CHANGE: Modifying AI_BOOTSTRAPPERLANG property. Its current value is '1033'. Its new value: '2052'.
MSI (c) (48:94) [08:29:56:479]: Doing action: LanguageDlg
操作 8:29:56: LanguageDlg。
操作开始 8:29:56: LanguageDlg。
MSI (c) (48:9C) [08:29:56:480]: Note: 1: 2205 2: 3: AI_ControlConditionEx
MSI (c) (48:9C) [08:29:56:480]: Note: 1: 2228 2: 3: AI_ControlConditionEx 4: SELECT `Dialog_`,`Control_`,`Action`,`Condition` FROM `AI_ControlConditionEx`
MSI (c) (48:9C) [08:29:56:481]: Note: 1: 2205 2: 3: AI_EventMappingEx
MSI (c) (48:9C) [08:29:56:481]: Note: 1: 2228 2: 3: AI_EventMappingEx 4: SELECT `Dialog_`,`Control_`,`Event`,`Attribute` FROM `AI_EventMappingEx`
MSI (c) (48:4C) [08:29:56:522]: Note: 1: 2205 2: 3: AI_ControlEx
MSI (c) (48:4C) [08:29:56:522]: Note: 1: 2228 2: 3: AI_ControlEx 4: SELECT `Dialog_`,`Control`,`Type`,`Parent`,`Attributes`,`Data` FROM `AI_ControlEx` WHERE `Dialog_` = 'LanguageDlg'
操作结束 8:29:57: LanguageDlg。返回值 1。
MSI (c) (48:94) [08:29:57:611]: Note: 1: 2205 2: 3: AI_PreRequisite
MSI (c) (48:94) [08:29:57:611]: Note: 1: 2228 2: 3: AI_PreRequisite 4: SELECT `Options`,`Feature_`,`MissingCondition`,`DisplayName`,`PrereqKey`,`Sequence` FROM `AI_PreRequisite`
MSI (c) (48:94) [08:29:57:611]: Note: 1: 2262 2: Condition 3: -2147287038
MSI (c) (48:94) [08:29:57:612]: Note: 1: 2205 2: 3: MultipleInstances
MSI (c) (48:94) [08:29:57:612]: Note: 1: 2228 2: 3: MultipleInstances 4: SELECT `InstKey`,`InstancesId`,`Order` FROM `MultipleInstances`
MSI (c) (48:94) [08:29:57:612]: Note: 1: 2205 2: 3: MultipleInstancesProps
MSI (c) (48:94) [08:29:57:612]: Note: 1: 2228 2: 3: MultipleInstancesProps 4: SELECT `Instance`,`PropertyName`,`PropertyValue` FROM `MultipleInstancesProps`
MSI (c) (48:94) [08:29:57:612]: PROPERTY CHANGE: Deleting AI_BOOTSTRAPPER property. Its current value is '1'.
MSI (c) (48:94) [08:29:57:612]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '8264'.
MSI (c) (48:94) [08:29:57:612]: Doing action: AI_SET_INSTALL
操作 8:29:57: AI_SET_INSTALL。
操作开始 8:29:57: AI_SET_INSTALL。
MSI (c) (48:94) [08:29:57:613]: PROPERTY CHANGE: Adding AI_INSTALL property. Its value is '1'.
操作结束 8:29:57: AI_SET_INSTALL。返回值 1。
MSI (c) (48:94) [08:29:57:613]: Doing action: AI_EnableDebugLog
操作 8:29:57: AI_EnableDebugLog。
操作开始 8:29:57: AI_EnableDebugLog。
MSI (c) (48:4C) [08:29:57:615]: Invoking remote custom action. DLL: C:\Users\ADMINI~1\AppData\Local\Temp\MSI7254.tmp, Entrypoint: EnableDebugLog
AI_EnableDebugLog: Log disabled
操作结束 8:29:57: AI_EnableDebugLog。返回值 1。
MSI (c) (48:94) [08:29:57:627]: Doing action: AI_DpiContentScale
操作 8:29:57: AI_DpiContentScale。
操作开始 8:29:57: AI_DpiContentScale。
MSI (c) (48:54) [08:29:57:629]: Invoking remote custom action. DLL: C:\Users\ADMINI~1\AppData\Local\Temp\MSI7265.tmp, Entrypoint: DpiContentScale
操作结束 8:29:57: AI_DpiContentScale。返回值 1。
MSI (c) (48:94) [08:29:57:655]: Doing action: AI_ResolveKnownFolders
操作 8:29:57: AI_ResolveKnownFolders。
操作开始 8:29:57: AI_ResolveKnownFolders。
MSI (c) (48:5C) [08:29:57:658]: Invoking remote custom action. DLL: C:\Users\ADMINI~1\AppData\Local\Temp\MSI7285.tmp, Entrypoint: AI_ResolveKnownFolders
MSI (c) (48!60) [08:29:57:679]: PROPERTY CHANGE: Adding SavedGamesFolder property. Its value is 'C:\Users\Administrator\Saved Games\'.
MSI (c) (48!60) [08:29:57:681]: PROPERTY CHANGE: Adding WindowsLibrariesFolder property. Its value is 'C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Libraries\'.
MSI (c) (48!60) [08:29:57:683]: PROPERTY CHANGE: Adding PublicDocumentsFolder property. Its value is 'C:\Users\Public\Documents\'.
MSI (c) (48!60) [08:29:57:684]: PROPERTY CHANGE: Adding PublicFolder property. Its value is 'C:\Users\Public\'.
操作结束 8:29:57: AI_ResolveKnownFolders。返回值 1。
MSI (c) (48:94) [08:29:57:686]: Doing action: PrepareDlg
操作 8:29:57: PrepareDlg。
操作开始 8:29:57: PrepareDlg。
MSI (c) (48:4C) [08:29:57:689]: Note: 1: 2205 2: 3: AI_ControlEx
MSI (c) (48:4C) [08:29:57:689]: Note: 1: 2228 2: 3: AI_ControlEx 4: SELECT `Dialog_`,`Control`,`Type`,`Parent`,`Attributes`,`Data` FROM `AI_ControlEx` WHERE `Dialog_` = 'PrepareDlg'
操作结束 8:29:57: PrepareDlg。返回值 1。
MSI (c) (48:94) [08:29:57:712]: Doing action: AI_BACKUP_AI_SETUPEXEPATH
操作 8:29:57: AI_BACKUP_AI_SETUPEXEPATH。
操作开始 8:29:57: AI_BACKUP_AI_SETUPEXEPATH。
MSI (c) (48:94) [08:29:57:713]: PROPERTY CHANGE: Adding AI_SETUPEXEPATH_ORIGINAL property. Its value is 'C:\Users\Administrator\Desktop\ImxRT\RT1050\MCUXpresso_Config_Tools_v4.1_x64.exe'.
操作结束 8:29:57: AI_BACKUP_AI_SETUPEXEPATH。返回值 1。
MSI (c) (48:94) [08:29:57:713]: Doing action: AppSearch
操作 8:29:57: AppSearch。正在搜索已安装的应用程序
操作开始 8:29:57: AppSearch。
AppSearch: 属性: AI_SHORTCUTSREG,签名: AI_ShRegOptionMachine
MSI (c) (48:94) [08:29:57:719]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (c) (48:94) [08:29:57:719]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\Software\Caphyon\Advanced Installer\Installs\{5FCE01F9-B255-4E47-97D4-C669C4115DCF} 3: 2
AppSearch: 属性: AI_SHORTCUTSREG,签名: AI_ShRegOptionUser
MSI (c) (48:94) [08:29:57:724]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (c) (48:94) [08:29:57:724]: Note: 1: 1402 2: HKEY_CURRENT_USER32\Software\Caphyon\Advanced Installer\Installs\{5FCE01F9-B255-4E47-97D4-C669C4115DCF} 3: 2
操作结束 8:29:57: AppSearch。返回值 1。
MSI (c) (48:94) [08:29:57:724]: Doing action: AI_RESTORE_AI_SETUPEXEPATH
操作 8:29:57: AI_RESTORE_AI_SETUPEXEPATH。
操作开始 8:29:57: AI_RESTORE_AI_SETUPEXEPATH。
操作结束 8:29:57: AI_RESTORE_AI_SETUPEXEPATH。返回值 1。
MSI (c) (48:94) [08:29:57:725]: Doing action: FindRelatedProducts
操作 8:29:57: FindRelatedProducts。正在搜索相关的应用程序
操作开始 8:29:57: FindRelatedProducts。
操作结束 8:29:57: FindRelatedProducts。返回值 1。
MSI (c) (48:94) [08:29:57:725]: Doing action: LaunchConditions
操作 8:29:57: LaunchConditions。正在评估启动条件
操作开始 8:29:57: LaunchConditions。
操作结束 8:29:57: LaunchConditions。返回值 1。
MSI (c) (48:94) [08:29:57:726]: Doing action: AI_SETMIXINSTLOCATION
操作 8:29:57: AI_SETMIXINSTLOCATION。
操作开始 8:29:57: AI_SETMIXINSTLOCATION。
MSI (c) (48:64) [08:29:57:728]: Invoking remote custom action. DLL: C:\Users\ADMINI~1\AppData\Local\Temp\MSI72D4.tmp, Entrypoint: MixedAllUsersInstallLocation
MSI (c) (48!68) [08:29:57:740]: PROPERTY CHANGE: Adding AI_UserProgramFiles property. Its value is 'C:\Program Files (x86)\'.
操作结束 8:29:57: AI_SETMIXINSTLOCATION。返回值 1。
MSI (c) (48:94) [08:29:57:742]: Doing action: AI_SETPROGRAMFILES64
操作 8:29:57: AI_SETPROGRAMFILES64。
操作开始 8:29:57: AI_SETPROGRAMFILES64。
MSI (c) (48:94) [08:29:57:742]: PROPERTY CHANGE: Adding AI_ProgramFiles property. Its value is 'C:\Program Files\'.
操作结束 8:29:57: AI_SETPROGRAMFILES64。返回值 1。
MSI (c) (48:94) [08:29:57:742]: Doing action: SET_APPDIR
操作 8:29:57: SET_APPDIR。
操作开始 8:29:57: SET_APPDIR。
MSI (c) (48:94) [08:29:57:743]: PROPERTY CHANGE: Adding APPDIR property. Its value is 'C:\\nxp\MCUX_CFG_v4_1'.
操作结束 8:29:57: SET_APPDIR。返回值 1。
MSI (c) (48:94) [08:29:57:743]: Doing action: SET_SHORTCUTDIR
操作 8:29:57: SET_SHORTCUTDIR。
操作开始 8:29:57: SET_SHORTCUTDIR。
MSI (c) (48:94) [08:29:57:743]: PROPERTY CHANGE: Adding SHORTCUTDIR property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\\MCUXpresso Config v4.1'.
操作结束 8:29:57: SET_SHORTCUTDIR。返回值 1。
MSI (c) (48:94) [08:29:57:743]: Doing action: CostInitialize
操作 8:29:57: CostInitialize。正在计算所需的空间
操作开始 8:29:57: CostInitialize。
MSI (c) (48:94) [08:29:57:743]: Machine policy value 'MaxPatchCacheSize' is 10
MSI (c) (48:94) [08:29:57:754]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI (c) (48:94) [08:29:57:754]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
操作结束 8:29:57: CostInitialize。返回值 1。
MSI (c) (48:94) [08:29:57:755]: Doing action: FileCost
操作 8:29:57: FileCost。正在计算所需的空间
操作开始 8:29:57: FileCost。
MSI (c) (48:94) [08:29:57:756]: Note: 1: 2205 2: 3: MsiAssembly
MSI (c) (48:94) [08:29:57:756]: Note: 1: 2262 2: Class 3: -2147287038
MSI (c) (48:94) [08:29:57:756]: Note: 1: 2205 2: 3: TypeLib
操作结束 8:29:57: FileCost。返回值 1。
MSI (c) (48:94) [08:29:57:757]: Note: 1: 2205 2: 3: AI_PreRequisite
MSI (c) (48:94) [08:29:57:757]: Note: 1: 2228 2: 3: AI_PreRequisite 4: SELECT `Options`,`Feature_`,`MissingCondition`,`DisplayName`,`PrereqKey`,`Sequence` FROM `AI_PreRequisite`
MSI (c) (48:94) [08:29:57:757]: Note: 1: 2262 2: Condition 3: -2147287038
MSI (c) (48:94) [08:29:57:757]: Doing action: CostFinalize
操作 8:29:57: CostFinalize。正在计算所需的空间
操作开始 8:29:57: CostFinalize。
MSI (c) (48:94) [08:29:57:757]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (c) (48:94) [08:29:57:758]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (c) (48:94) [08:29:57:758]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (c) (48:94) [08:29:57:758]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (c) (48:94) [08:29:57:758]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (c) (48:94) [08:29:57:758]: Note: 1: 2262 2: Patch 3: -2147287038
MSI (c) (48:94) [08:29:57:758]: Note: 1: 2262 2: Condition 3: -2147287038
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Modifying SHORTCUTDIR property. Its current value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\\MCUXpresso Config v4.1'. Its new value: 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MCUXpresso Config v4.1\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding MCUXpressoConfigv4.1_Dir property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MCUXpresso Config v4.1\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Modifying APPDIR property. Its current value is 'C:\\nxp\MCUX_CFG_v4_1'. Its new value: 'C:\nxp\MCUX_CFG_v4_1\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding licenses_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\licenses\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding doc_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\doc\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding en_1_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\doc\en\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding zh_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\doc\zh\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding mcu_data_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\mcu_data\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding resources_1_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\mcu_data\resources\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding fonts_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\mcu_data\resources\fonts\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding RobotoCondensed_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\mcu_data\resources\fonts\RobotoCondensed\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding bin_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding readme_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\readme\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding p2_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\p2\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding org.eclipse.equinox.p2.core_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\p2\org.eclipse.equinox.p2.core\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding cache_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\p2\org.eclipse.equinox.p2.core\cache\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding binary_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\p2\org.eclipse.equinox.p2.core\cache\binary\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding org.eclipse.equinox.p2.engine_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\p2\org.eclipse.equinox.p2.engine\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding settings_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\p2\org.eclipse.equinox.p2.engine\.settings\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding profileRegistry_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\p2\org.eclipse.equinox.p2.engine\profileRegistry\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding DefaultProfile.profile_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\p2\org.eclipse.equinox.p2.engine\profileRegistry\DefaultProfile.profile\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding data_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\p2\org.eclipse.equinox.p2.engine\profileRegistry\DefaultProfile.profile\.data\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\p2\org.eclipse.equinox.p2.engine\profileRegistry\DefaultProfile.profile\.data\org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding configuration_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\configuration\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding org.eclipse.update_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\configuration\org.eclipse.update\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding plugins_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\plugins\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding com.nxp.swtools.doc.kinetis_4.0.0.201805101316_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\plugins\com.nxp.swtools.doc.kinetis_4.0.0.201805101316\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding resources_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\plugins\com.nxp.swtools.doc.kinetis_4.0.0.201805101316\resources\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding support_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\plugins\com.nxp.swtools.doc.kinetis_4.0.0.201805101316\resources\support\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding help_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\plugins\com.nxp.swtools.doc.kinetis_4.0.0.201805101316\resources\support\help\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding en_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\plugins\com.nxp.swtools.doc.kinetis_4.0.0.201805101316\resources\support\help\en\'.
MSI (c) (48:94) [08:29:57:759]: PROPERTY CHANGE: Adding METAINF_21_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\plugins\com.nxp.swtools.doc.kinetis_4.0.0.201805101316\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.551.v20171108183_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\plugins\org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.551.v20171108-1834\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_22_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\plugins\org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.551.v20171108-1834\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding features_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding org.eclipse.equinox.p2.extras.feature_1.3.1.v201709281405_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.equinox.p2.extras.feature_1.3.1.v20170928-1405\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_18_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.equinox.p2.extras.feature_1.3.1.v20170928-1405\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding org.eclipse.equinox.p2.core.feature_1.4.1.v201709281405_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.equinox.p2.core.feature_1.4.1.v20170928-1405\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_17_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.equinox.p2.core.feature_1.4.1.v20170928-1405\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding org.eclipse.ecf.filetransfer.ssl.feature_1.1.0.v201701101317_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.filetransfer.ssl.feature_1.1.0.v20170110-1317\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_14_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.filetransfer.ssl.feature_1.1.0.v20170110-1317\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding org.eclipse.ecf.filetransfer.httpclient4.feature_3.13.8.v20170715225_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.filetransfer.httpclient4.feature_3.13.8.v20170715-2257\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_12_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.filetransfer.httpclient4.feature_3.13.8.v20170715-2257\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding org.eclipse.ecf.filetransfer.feature_3.13.8.v201707152257_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.filetransfer.feature_3.13.8.v20170715-2257\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_11_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.filetransfer.feature_3.13.8.v20170715-2257\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding org.eclipse.ecf.core.ssl.feature_1.1.0.v201701101317_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.core.ssl.feature_1.1.0.v20170110-1317\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_10_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.core.ssl.feature_1.1.0.v20170110-1317\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding org.eclipse.babel.nls_eclipse_zh_4.7.0.v20170819060001_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.babel.nls_eclipse_zh_4.7.0.v20170819060001\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding com.nxp.swtools.mcuxstandalone.feature_4.1.0.201805101316_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.mcuxstandalone.feature_4.1.0.201805101316\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_3_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.mcuxstandalone.feature_4.1.0.201805101316\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding com.nxp.swtools.periphs.feature_4.1.0.201805101316_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.periphs.feature_4.1.0.201805101316\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_4_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.periphs.feature_4.1.0.201805101316\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding com.nxp.swtools.rcp.feature_1.0.0.201805101316_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.rcp.feature_1.0.0.201805101316\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_7_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.rcp.feature_1.0.0.201805101316\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding org.eclipse.ecf.core.feature_1.4.0.v201705162248_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.core.feature_1.4.0.v20170516-2248\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_9_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.core.feature_1.4.0.v20170516-2248\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding com.nxp.swtools.framework.feature_4.1.0.201805101316_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.framework.feature_4.1.0.201805101316\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_2_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.framework.feature_4.1.0.201805101316\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding com.nxp.swtools.clocks.feature_4.1.0.201805101316_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.clocks.feature_4.1.0.201805101316\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.clocks.feature_4.1.0.201805101316\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding com.nxp.swtools.doc.kinetis.feature_4.0.0.201805101316_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.doc.kinetis.feature_4.0.0.201805101316\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_1_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.doc.kinetis.feature_4.0.0.201805101316\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding org.eclipse.emf.common_2.13.0.v201706090707_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.emf.common_2.13.0.v20170609-0707\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_15_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.emf.common_2.13.0.v20170609-0707\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding com.nxp.swtools.pins.feature_4.1.0.201805101316_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.pins.feature_4.1.0.201805101316\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_5_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.pins.feature_4.1.0.201805101316\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding com.nxp.swtools.projectcloner.feature_2.0.0.201805101316_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.projectcloner.feature_2.0.0.201805101316\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_6_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.projectcloner.feature_2.0.0.201805101316\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding org.eclipse.ecf.filetransfer.httpclient4.ssl.feature_1.1.0.v20170110_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.filetransfer.httpclient4.ssl.feature_1.1.0.v20170110-1317\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_13_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.filetransfer.httpclient4.ssl.feature_1.1.0.v20170110-1317\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding org.eclipse.e4.rcp_1.6.3.v201802140345_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.e4.rcp_1.6.3.v20180214-0345\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_8_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.e4.rcp_1.6.3.v20180214-0345\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding org.eclipse.rcp_4.7.3.v201803010715_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.rcp_4.7.3.v20180301-0715\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_20_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.rcp_4.7.3.v20180301-0715\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding org.eclipse.emf.ecore_2.13.0.v201706090707_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.emf.ecore_2.13.0.v20170609-0707\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_16_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.emf.ecore_2.13.0.v20170609-0707\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding org.eclipse.help_2.2.103.v201803010715_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.help_2.2.103.v20180301-0715\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding METAINF_19_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.help_2.2.103.v20180301-0715\META-INF\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding jre_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\jre\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding lib_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding management_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\management\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding jfr_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\jfr\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding images_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\images\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding cursors_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\images\cursors\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding fonts_1_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\fonts\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding ext_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\ext\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding deploy_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\deploy\'.
MSI (c) (48:94) [08:29:57:760]: PROPERTY CHANGE: Adding amd64_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\amd64\'.
MSI (c) (48:94) [08:29:57:761]: PROPERTY CHANGE: Adding cmm_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\cmm\'.
MSI (c) (48:94) [08:29:57:761]: PROPERTY CHANGE: Adding security_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\security\'.
MSI (c) (48:94) [08:29:57:761]: PROPERTY CHANGE: Adding applet_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\applet\'.
MSI (c) (48:94) [08:29:57:761]: PROPERTY CHANGE: Adding bin_1_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\jre\bin\'.
MSI (c) (48:94) [08:29:57:761]: PROPERTY CHANGE: Adding server_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\jre\bin\server\'.
MSI (c) (48:94) [08:29:57:761]: PROPERTY CHANGE: Adding plugin2_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\jre\bin\plugin2\'.
MSI (c) (48:94) [08:29:57:761]: PROPERTY CHANGE: Adding dtplugin_Dir property. Its value is 'C:\nxp\MCUX_CFG_v4_1\bin\jre\bin\dtplugin\'.
MSI (c) (48:94) [08:29:57:761]: Target path resolution complete. Dumping Directory table...
MSI (c) (48:94) [08:29:57:761]: Note: target paths subject to change (via custom actions or browsing)
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: TARGETDIR , Object: C:\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: DesktopFolder , Object: C:\Users\Public\Desktop\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: SHORTCUTDIR , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MCUXpresso Config v4.1\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: ProgramMenuFolder , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: MCUXpressoConfigv4.1_Dir , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MCUXpresso Config v4.1\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: APPDIR , Object: C:\nxp\MCUX_CFG_v4_1\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: licenses_Dir , Object: C:\nxp\MCUX_CFG_v4_1\licenses\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: doc_Dir , Object: C:\nxp\MCUX_CFG_v4_1\doc\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: en_1_Dir , Object: C:\nxp\MCUX_CFG_v4_1\doc\en\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: zh_Dir , Object: C:\nxp\MCUX_CFG_v4_1\doc\zh\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: mcu_data_Dir , Object: C:\nxp\MCUX_CFG_v4_1\mcu_data\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: resources_1_Dir , Object: C:\nxp\MCUX_CFG_v4_1\mcu_data\resources\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: fonts_Dir , Object: C:\nxp\MCUX_CFG_v4_1\mcu_data\resources\fonts\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: RobotoCondensed_Dir , Object: C:\nxp\MCUX_CFG_v4_1\mcu_data\resources\fonts\RobotoCondensed\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: bin_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: readme_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\readme\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: p2_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\p2\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: org.eclipse.equinox.p2.core_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\p2\org.eclipse.equinox.p2.core\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: cache_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\p2\org.eclipse.equinox.p2.core\cache\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: binary_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\p2\org.eclipse.equinox.p2.core\cache\binary\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: org.eclipse.equinox.p2.engine_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\p2\org.eclipse.equinox.p2.engine\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: settings_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\p2\org.eclipse.equinox.p2.engine\.settings\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: profileRegistry_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\p2\org.eclipse.equinox.p2.engine\profileRegistry\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: DefaultProfile.profile_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\p2\org.eclipse.equinox.p2.engine\profileRegistry\DefaultProfile.profile\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: data_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\p2\org.eclipse.equinox.p2.engine\profileRegistry\DefaultProfile.profile\.data\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\p2\org.eclipse.equinox.p2.engine\profileRegistry\DefaultProfile.profile\.data\org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: configuration_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\configuration\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: org.eclipse.update_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\configuration\org.eclipse.update\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: plugins_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\plugins\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: com.nxp.swtools.doc.kinetis_4.0.0.201805101316_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\plugins\com.nxp.swtools.doc.kinetis_4.0.0.201805101316\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: resources_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\plugins\com.nxp.swtools.doc.kinetis_4.0.0.201805101316\resources\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: support_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\plugins\com.nxp.swtools.doc.kinetis_4.0.0.201805101316\resources\support\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: help_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\plugins\com.nxp.swtools.doc.kinetis_4.0.0.201805101316\resources\support\help\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: en_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\plugins\com.nxp.swtools.doc.kinetis_4.0.0.201805101316\resources\support\help\en\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_21_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\plugins\com.nxp.swtools.doc.kinetis_4.0.0.201805101316\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.551.v20171108183_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\plugins\org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.551.v20171108-1834\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_22_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\plugins\org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.551.v20171108-1834\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: features_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: org.eclipse.equinox.p2.extras.feature_1.3.1.v201709281405_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.equinox.p2.extras.feature_1.3.1.v20170928-1405\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_18_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.equinox.p2.extras.feature_1.3.1.v20170928-1405\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: org.eclipse.equinox.p2.core.feature_1.4.1.v201709281405_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.equinox.p2.core.feature_1.4.1.v20170928-1405\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_17_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.equinox.p2.core.feature_1.4.1.v20170928-1405\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: org.eclipse.ecf.filetransfer.ssl.feature_1.1.0.v201701101317_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.filetransfer.ssl.feature_1.1.0.v20170110-1317\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_14_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.filetransfer.ssl.feature_1.1.0.v20170110-1317\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: org.eclipse.ecf.filetransfer.httpclient4.feature_3.13.8.v20170715225_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.filetransfer.httpclient4.feature_3.13.8.v20170715-2257\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_12_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.filetransfer.httpclient4.feature_3.13.8.v20170715-2257\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: org.eclipse.ecf.filetransfer.feature_3.13.8.v201707152257_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.filetransfer.feature_3.13.8.v20170715-2257\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_11_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.filetransfer.feature_3.13.8.v20170715-2257\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: org.eclipse.ecf.core.ssl.feature_1.1.0.v201701101317_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.core.ssl.feature_1.1.0.v20170110-1317\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_10_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.core.ssl.feature_1.1.0.v20170110-1317\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: org.eclipse.babel.nls_eclipse_zh_4.7.0.v20170819060001_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.babel.nls_eclipse_zh_4.7.0.v20170819060001\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: com.nxp.swtools.mcuxstandalone.feature_4.1.0.201805101316_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.mcuxstandalone.feature_4.1.0.201805101316\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_3_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.mcuxstandalone.feature_4.1.0.201805101316\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: com.nxp.swtools.periphs.feature_4.1.0.201805101316_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.periphs.feature_4.1.0.201805101316\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_4_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.periphs.feature_4.1.0.201805101316\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: com.nxp.swtools.rcp.feature_1.0.0.201805101316_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.rcp.feature_1.0.0.201805101316\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_7_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.rcp.feature_1.0.0.201805101316\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: org.eclipse.ecf.core.feature_1.4.0.v201705162248_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.core.feature_1.4.0.v20170516-2248\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_9_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.core.feature_1.4.0.v20170516-2248\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: com.nxp.swtools.framework.feature_4.1.0.201805101316_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.framework.feature_4.1.0.201805101316\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_2_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.framework.feature_4.1.0.201805101316\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: com.nxp.swtools.clocks.feature_4.1.0.201805101316_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.clocks.feature_4.1.0.201805101316\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.clocks.feature_4.1.0.201805101316\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: com.nxp.swtools.doc.kinetis.feature_4.0.0.201805101316_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.doc.kinetis.feature_4.0.0.201805101316\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_1_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.doc.kinetis.feature_4.0.0.201805101316\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: org.eclipse.emf.common_2.13.0.v201706090707_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.emf.common_2.13.0.v20170609-0707\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_15_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.emf.common_2.13.0.v20170609-0707\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: com.nxp.swtools.pins.feature_4.1.0.201805101316_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.pins.feature_4.1.0.201805101316\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_5_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.pins.feature_4.1.0.201805101316\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: com.nxp.swtools.projectcloner.feature_2.0.0.201805101316_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.projectcloner.feature_2.0.0.201805101316\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_6_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\com.nxp.swtools.projectcloner.feature_2.0.0.201805101316\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: org.eclipse.ecf.filetransfer.httpclient4.ssl.feature_1.1.0.v20170110_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.filetransfer.httpclient4.ssl.feature_1.1.0.v20170110-1317\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_13_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.ecf.filetransfer.httpclient4.ssl.feature_1.1.0.v20170110-1317\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: org.eclipse.e4.rcp_1.6.3.v201802140345_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.e4.rcp_1.6.3.v20180214-0345\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_8_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.e4.rcp_1.6.3.v20180214-0345\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: org.eclipse.rcp_4.7.3.v201803010715_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.rcp_4.7.3.v20180301-0715\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_20_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.rcp_4.7.3.v20180301-0715\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: org.eclipse.emf.ecore_2.13.0.v201706090707_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.emf.ecore_2.13.0.v20170609-0707\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_16_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.emf.ecore_2.13.0.v20170609-0707\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: org.eclipse.help_2.2.103.v201803010715_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.help_2.2.103.v20180301-0715\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: METAINF_19_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\features\org.eclipse.help_2.2.103.v20180301-0715\META-INF\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: jre_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\jre\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: lib_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: management_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\management\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: jfr_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\jfr\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: images_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\images\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: cursors_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\images\cursors\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: fonts_1_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\fonts\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: ext_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\ext\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: deploy_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\deploy\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: amd64_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\amd64\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: cmm_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\cmm\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: security_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\security\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: applet_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\jre\lib\applet\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: bin_1_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\jre\bin\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: server_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\jre\bin\server\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: plugin2_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\jre\bin\plugin2\
MSI (c) (48:94) [08:29:57:761]: Dir (target): Key: dtplugin_Dir , Object: C:\nxp\MCUX_CFG_v4_1\bin\jre\bin\dtplugin\
MSI (c) (48:94) [08:29:57:762]: Note: 1: 2205 2: 3: MsiAssembly
MSI (c) (48:94) [08:29:57:762]: Note: 1: 2228 2: 3: MsiAssembly 4: SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`, `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
操作结束 8:29:57: CostFinalize。返回值 1。
MSI (c) (48:94) [08:29:57:776]: Doing action: MigrateFeatureStates
操作 8:29:57: MigrateFeatureStates。正在从相关应用程序迁移功能
操作开始 8:29:57: MigrateFeatureStates。
操作结束 8:29:57: MigrateFeatureStates。返回值 0。
MSI (c) (48:94) [08:29:57:776]: Doing action: WelcomeDlg
操作 8:29:57: WelcomeDlg。
操作开始 8:29:57: WelcomeDlg。
MSI (c) (48:4C) [08:29:57:780]: Note: 1: 2205 2: 3: AI_ControlEx
MSI (c) (48:4C) [08:29:57:780]: Note: 1: 2228 2: 3: AI_ControlEx 4: SELECT `Dialog_`,`Control`,`Type`,`Parent`,`Attributes`,`Data` FROM `AI_ControlEx` WHERE `Dialog_` = 'WelcomeDlg'
MSI (c) (48:4C) [08:29:58:357]: Note: 1: 2205 2: 3: AI_ControlEx
MSI (c) (48:4C) [08:29:58:357]: Note: 1: 2228 2: 3: AI_ControlEx 4: SELECT `Dialog_`,`Control`,`Type`,`Parent`,`Attributes`,`Data` FROM `AI_ControlEx` WHERE `Dialog_` = 'FolderDlg'
操作结束 8:29:59: WelcomeDlg。返回值 1。
MSI (c) (48:94) [08:29:59:659]: Doing action: AI_ValidateInstallPath
操作 8:29:59: AI_ValidateInstallPath。
操作开始 8:29:59: AI_ValidateInstallPath。
MSI (c) (48:D4) [08:29:59:665]: Invoking remote custom action. DLL: C:\Users\ADMINI~1\AppData\Local\Temp\MSI7A64.tmp, Entrypoint: ValidateInstallFolder
操作结束 8:30:00: AI_ValidateInstallPath。返回值 1。
MSI (c) (48:94) [08:30:00:777]: Doing action: FolderDlg
操作 8:30:00: FolderDlg。
操作开始 8:30:00: FolderDlg。
操作结束 8:30:00: FolderDlg。返回值 1。
MSI (c) (48:94) [08:30:00:778]: Doing action: AI_DATA_SETTER_4
操作 8:30:00: AI_DATA_SETTER_4。
操作开始 8:30:00: AI_DATA_SETTER_4。
MSI (c) (48:94) [08:30:00:778]: PROPERTY CHANGE: Adding CustomActionData property. Its value is 'Is64Bit  Params  Script # Block for declaring the script parameters.
Param()
#get the target directory string
$path = AI_GetMsiProperty APPDIR
# Your code goes here.
#Prepare a regular expression object
$regex = "[!@#$%^&]+" #Define pattern with forbiden characters
#Check if user used in path forbidden characters
If ($path -match $regex) {
#The user used in path forbidden characters
#path is invalid and can not be used
#return error
AI_SetMsiProperty PATH_RE_STRING 1
#msgbox ("Path contains one of unallowed characters: !@#$%^&")
} Else {
#path is correct and can be used
#return success
AI_SetMsiProperty PATH_RE_STRING 0
操作结束 8:30:00: AI_DATA_SETTER_4。返回值 1。
MSI (c) (48:94) [08:30:00:778]: Doing action: FolderDlg
MSI (c) (48:94) [08:30:00:779]: Doing action: Validate_Path
操作 8:30:00: Validate_Path。
操作开始 8:30:00: Validate_Path。
MSI (c) (48:DC) [08:30:00:781]: Invoking remote custom action. DLL: C:\Users\ADMINI~1\AppData\Local\Temp\MSI7EB8.tmp, Entrypoint: RunPowerShellScript
Dumping PowerShell invoke log ...
--> Found PowerShell path:
--> PowerShell Script Execution Result Code: -1
--> PowerShell Script Execution log:
Could not find PowerShell!
CustomAction Validate_Path returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
操作结束 8:30:00: Validate_Path。返回值 3。
MSI (c) (48:94) [08:30:00:798]: Doing action: FatalError
操作 8:30:00: FatalError。
操作开始 8:30:00: FatalError。
MSI (c) (48:4C) [08:30:00:804]: Note: 1: 2205 2: 3: AI_ControlEx
MSI (c) (48:4C) [08:30:00:804]: Note: 1: 2228 2: 3: AI_ControlEx 4: SELECT `Dialog_`,`Control`,`Type`,`Parent`,`Attributes`,`Data` FROM `AI_ControlEx` WHERE `Dialog_` = 'FatalError'
操作结束 8:30:02: FatalError。返回值 1。
MSI (c) (48:94) [08:30:02:471]: Doing action: AI_SHOW_LOG
操作 8:30:02: AI_SHOW_LOG。
操作开始 8:30:02: AI_SHOW_LOG。
MSI (c) (48:30) [08:30:02:473]: Invoking remote custom action. DLL: C:\Users\ADMINI~1\AppData\Local\Temp\MSI855E.tmp, Entrypoint: LaunchLogFile
操作结束 8:30:02: AI_SHOW_LOG。返回值 1。
MSI (c) (48:94) [08:30:02:591]: Doing action: FatalError
操作 8:30:02: FatalError。
操作开始 8:30:02: FatalError。
操作结束 8:30:02: FatalError。返回值 2。
MSI (c) (48:94) [08:30:02:591]: Note: 1: 2205 2: 3: Environment
MSI (c) (48:94) [08:30:02:591]: Note: 1: 2228 2: 3: Environment 4: SELECT `Environment`,`Component_` FROM `Environment`
MSI (c) (48:50) [08:30:02:593]: Destroying RemoteAPI object.
MSI (c) (48:F4) [08:30:02:593]: Custom Action Manager thread ending.
=== Verbose logging stopped: 2018\7\14 星期六 8:30:02 ===
martinformanek-
Hello Andy,
please try out latest version of MCUX Tools. Reported issue should be fixed now
MCUXpresso Config Tools, Windows 64bit package
please let me know if it solved your issue or not.
Martin
