JD Sun
KEA128 Flash Erase and write problems
Discussion created by JD Sun on Jul 13, 2018
Latest reply on Jul 16, 2018 by Mark Butcher
Hello, I am using TRK - KEA128 board debugging Flash, debug mode can run normally, but in normal mode, the Flash will not erase and write properly, the program runs in a Flash, whether need before erasing and writing the code loaded into RAM?If so, what should I do?
