MK20DX128VFM5 forced to bootloader
kumarnarendrasi
Hello NXP,
We are using MK20DX128VFM5 as open SDA for K66 controller. K20 and K66 is also interfaced to a SOC module(running Linux) through an USB hub. We were able to program K66 through an #open SDA using JTAG(Keil uvision).
But when we tried rebooting the Whole system,the K20 gets forced into Bootloader Mode.
So we are unable to debug application and run the debugger, serial terminal and mass storage for programming the K66.
Please help us in resolving the Issue.
Thanks in advance.
Kumar Narendra Singh
Hello Kumar Narendra Singh,
You can reprogram your OpenSDA application in your the BOOTLOADER direver from computer file explorer,
About detail steps please refer to :
OpenSDA Serial and Debug Adapter|NXP
TIC
