Why I erase the PFLASH system reset, I have disabled the interrupt.
jia_xuan
/* Erase the sixth PFlash sector */
address = 18u * FEATURE_FLS_PF_BLOCK_SECTOR_SIZE;
size = FEATURE_FLS_PF_BLOCK_SECTOR_SIZE;
INT_SYS_DisableIRQGlobal();
ret = FLASH_DRV_EraseSector(&flashSSDConfig, address, size);
INT_SYS_EnableIRQGlobal();
danielmartynek
Do you launch the erase flash command from RAM, D-Flash or from P-Flash block?
Allowed simultaneous memory operations are listed in Table 36-30, S32K1xx_RM_rev.7.
