I found a sample code to read flash octet. Here under the sample code
// Read the content of a memory address
char flash_read(unsigned int address)
unsigned char *pointer;
pointer = (char*) address;
return (*pointer);
I don't understand why there is no action, no register modification to read a contain of specific adress.
For me, the second line of the previous function do: pointer receiver adress of adress parameter (for example E000 = first octet of flash. That all!!! But there is not flash register has been modified before!!!?
Somebody have any explanation about this sample
David
