Sensless position control FRDM-KV31F
andreaswickstrom
Is there any example where i can use a pmsm motor and position control with the   FRDM-KV31F board?
I can run the sensless velocity but i cant find any example with go to angle.
I use a motor with a gearbox connected to it.
Andreas
linestream-adam
Senior Contributor I
Andreas,
Kinetis Motor Suite includes a sensored position control reference project. This project requires the use of an encoder attached to the motor. Sensorless control isn't good enough at low speeds to support sensorless position control.
