The standard Windows excutable "cscrpit.exe" was not found on Path
2541162274
When I install MCUXpresso ,this problem ocurrs,how can I solve this problem? Thank you .
lpcxpresso_supp
That dialog in the installer needs updating. The information you need is at :
But basically you need to fix your PATH environment variable
MCUXpresso IDE Support
lpcxpresso_supp
2541162274
