VSDK installing need activation code ?
liuqimin
Hello:
when VSDK installing ,a windows popup that ask acivation code,like following picture. where we can get this code?
Best regards!
Liu qimin
paulvlase
Hi @ qimin liu,
Unfortunately the link from where to get the activation code for APU compiler is shown in a previous step of the installation. It is easy to miss it, we did that a lot of times at the beginning.
To get the activation code follow these steps:
1. Go to https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=NXP-APU-COMPILER
2. Read the Software Terms and Conditions and click the I Agree button if you are OK with them.
3. Click on the License Keys tab.
3. Here you will find the Activation Code
Hope this helps,
Paul
liuqimin
Hi Paul:
    I can find the activation code now.
 thanks!
 Liu qimin
paulvlase
Hi @ qimin liu,
Hope this helps,
Paul
