how to use flexCAN in imx6ull processor ?
somnath_roy
hi all,
    i am using a SOM module by toradex it came with imx6ull processor
i have changed the dtsi file and my module is loaded in startup.
but i am getting a msg as
[   13.641388] CAN device driver interface
[  OK  ] Reached target System Initialization.
[   13.677653] 2094000.can supply xceiver not found, using dummy regulator
and when i am using cansend utility i am not getting and signal in CAN_tx pin.
yet i am using can xceiver IC UJA1161 and my xceiver is powered up.
Labels (2)
Hi Somnath
please connect other board or protocal analyzer and for testing
one can use unit tets (folder ..test/can) :
imx-test
www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-test-5.7.tar.gz
