I compile BSP according to SBC Tutorial 2a_Create_BSP_with_VSDK_support.pdf. But I get an error.
In the Makefile line 106, there is a mv command "sudo mv $(BUILDROOT_ROOT)/lib/modules/4.1.26-rt29+gbda2b35 $(BUILDROOT_ROOT)/lib/modules/4.1.26-rt29-dirty;", but I can only find 4.1.26-rt29+g1048b56 folder under modules. How should I solve this problem?
Thanks&Regards.
