USB connect state
USB connect state
googcheng
how to check USB connect state for lpc1343 at chip endpoint?
when will it enter USB interrupt handler?
what does (*rom)->pUSBD->isr(); do?
Labels (2)
kerryzhou
Hi Jay,
   What the USB type you are using?
   Normally, you can check it in the PC device manager usb controllers item, if your USB is useful, it will be list in the device mange item.
Kerry
googcheng
connect lpc1343 dali master to PC,  i want to check the connect state within lpc endpoint code,
like the "Get Device Status" command.  is there a connect/disconnect interrupt or a state check function?
kerryzhou
Hi Jay,
   About the dali master, you can refer to our application note and the according example:
https://www.nxp.com/downloads/en/software/LPC11xx_LPC13xx_DALI_DevKit_AN11175.zip
Wish it helps you!
Kerry
