KL82Z LPUART2 and SPI1 Initialization with Processor Expert
audreyhendon
In my current project I have LPUART1 and SPI0 peripherals working. I want to change the pins and peripheral instances to use LPUART2 and SPI1, which are on a different pin mux.
When I switch the pins and instances using Processor Expert, the peripherals are not working.
Is Processor Expert able to perform the initialization for LPUART2 and SPI1?
Tags (2)
Robin_Shen
Hi Audrey Hendon,
I am using KDS3.2 and CW10.7, but the Processor Expert does not support KL82 at all.
Would you please tell me what IDE are you using?
Please tell us which pins are you using for SPI1, so that I can test it on my FRDM-KL82Z board with MCUXpresso SDK.
Robin
