Antonio Brewer
K66 Flexcan TableB FIFO
Discussion created by Antonio Brewer on Jul 2, 2018
Latest reply on Jul 6, 2018 by Antonio Brewer
I’m having an issue with TableB format of flexcan on the K66, is there a special way the mask (individual masking enabled), I can’t seem to work out an example or find referenced to this table’s mask setup since we’re dealing with 2 IDs per filter. The datasheet seems clear enough for the details of the graph layout for the IDTable entry, but no idea on how the single RXIMR filter is used or shifted to work with that TableB format of 2 IDs
Tony
