STAR 12 CPU
STAR 12 CPU
haricharanreddy
Hi Everyone,
When I am studying the Data sheet of  MC9S12DP256 In the features I came through this
what Does it mean? what is the difference between Normal CPU and  STAR 12 CPU
Can someone Please explain it?
Thanks in Advance:smileyhappy:
Data Sheet : https://www.nxp.com/docs/en/data-sheet/MC9S12DP256.pdf
Tags (2)
ZhangJennie
Here are some of the mayor differences in between HC12 & HCS12:
HC12                  HCS12
16K-128K        16K-512K
1.2-0.5u             0.25u
8-12MHz            25MHz
Providing smaller dies and updated memory among other changes in our HCS12’s.
Jennie Zhang
ZhangJennie
HC12                  HCS12
16K-128K        16K-512K
1.2-0.5u             0.25u
8-12MHz            25MHz
Jennie Zhang
kef2
Senior Contributor IV
"normal" was on older HC12 family, MC912D60(A), MC68HC912B32 etc. The biggest difference was top bus clock, HC12 8MHz vs S12 25MHz. A couple of instructions were taking bit more bus cycles.
Edward
