Problem running Android on iMX6DL
Question asked by Flavio Alves on Jul 1, 2018
Latest reply on Jul 16, 2018 by igorpadykov
I recently design a custom board using iMX6 Dual Lite. It is currently working, running Linux operating System (Yocto based project).
Now I am working on the installation of the Android Oreo operating system on the board. I am using the NXP provided version as starting point.
I recompiled Android from the sources, according to the Android User Guide. Then, I used the Linux version device tree DTS file as information to adapt the related DTS file for Android kernel compilation.
The system boots, but I can see nothing on the display. When booting on recovery mode, I can see image on the screen. I tried to see logcat and dmesg, but I could not find the correct reason for the display not work correctly. I verified and the /dev/graphics/fb0 is created.
Below there is the boot information and also the beginning of a local logcat call.
Does anybody can give me some advice to where to find the cause of my problem?
Flavio
=> boota mmc2 boot
boota mmc2 boot
Error: blob decap job completed with errors 0x2000081A
In boota get fastboot lock status error. Set lock status
kernel   @ 14008000 (9965456)
ramdisk  @ 15000000 (2038084)
fdt      @ 14f00000 (41300)
## Booting Android Image at 0x12000000 ...
Kernel load addr 0x14008000 size 9732 KiB
Kernel command line: console=ttymxc0,115200 init=/init video=mxcfb0:dev=ldb,fbpix=RGB32,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off vmalloc=128M androidboot.console=ttymxc0 consoleblank=0 androidboot.hardware=freescale cma=448M galcore.contiguousSize=33554432 buildvariant=userdebug androidboot.serialno=190ec9d4ea9a21da androidboot.soc_type=imx6dl androidboot.storage_type=emmc
## Flattened Device Tree blob at 14f00000
   Booting using the fdt blob at 0x14f00000
   Loading Kernel Image ... OK
   Using Device Tree in place at 14f00000, end 14f0d153
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 4.9.17-04736-ga88711e-dirty (jorge@phi) (gcc version 4.9.x 20150123 (prerelease) (GCC) ) #5 SMP PREEMPT Sun Jul 1 17:27:37 -03 2018
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
OF: fdt:Machine model: Freescale i.MX6 DualLite SABRE Smart Device Board
cma: Reserved 448 MiB at 0x2a000000
Memory policy: Data cache writealloc
percpu: Embedded 15 pages/cpu @f6edd000 s31040 r8192 d22208 u61440
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260368
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 556444K/1048576K available (13312K kernel code, 1121K rwdata, 4272K rodata, 1024K init, 612K bss, 33380K reserved, 458752K cma-reserved, 139264K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xf8000000 - 0xff800000   ( 120 MB)
    lowmem  : 0xc0000000 - 0xf7800000   ( 888 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc0e00000   (14304 kB)
      .init : 0xc1300000 - 0xc1400000   (1024 kB)
      .data : 0xc1400000 - 0xc1518718   (1122 kB)
       .bss : 0xc1518718 - 0xc15b18a0   ( 613 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    Build-time adjustment of leaf fanout to 32.
    RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 16 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 16 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76450001
Switching to timer-based delay loop, resolution 333ns
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
Security Framework initialized
SELinux:  Initializing.
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
CPU0: update cpu_capacity 1024
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x10100000 - 0x10100058
CPU1: update cpu_capacity 1024
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (12.00 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
CPU1: update max cpu_capacity 1024
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 512 (order: 3, 32768 bytes)
pinctrl core: initialized pinctrl subsystem
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor menu
CPU identified as i.MX6DL, silicon rev 1.3
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
imx6dl-pinctrl 20e0000.iomuxc: Invalid fsl,pins property in node /soc/aips-bus@02000000/iomuxc@020e0000/imx6qdl-sabresd/egalax_i2c3_intgrp
imx6dl-pinctrl 20e0000.iomuxc: Invalid fsl,pins property in node /soc/aips-bus@02000000/iomuxc@020e0000/imx6qdl-sabresd/gpio_keysgrp
imx6dl-pinctrl 20e0000.iomuxc: Invalid fsl,pins property in node /soc/aips-bus@02000000/iomuxc@020e0000/imx6qdl-sabresd/hdmicecgrp
imx6dl-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
imx-gpc 20dc000.gpc: Registered imx-gpc
mxs-dma 110000.dma-apbh: initialized
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
2000000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
2000000.aips-bus:usbphy_nop2 supply vcc not found, using dummy regulator
i2c i2c-0: IMX I2C adapter registered
i2c i2c-0: can't use DMA, using PIO instead.
i2c i2c-1: IMX I2C adapter registered
i2c i2c-1: can't use DMA, using PIO instead.
i2c i2c-2: IMX I2C adapter registered
i2c i2c-2: can't use DMA, using PIO instead.
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
MIPI CSI2 driver module loaded
imx rpmsg driver is registered.
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.22
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
clocksource: Switched to clocksource mxc_timer1
VFS: Disk quotas dquot_6.6.0
VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 1992K (c5000000 - c51f2000)
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
Bus freq driver module loaded
bt power gpio is:2
mxc_bt_rfkill driver success loaded
audit: initializing netlink subsys (disabled)
audit: type=2000 audit(0.580:1): initialized
rfkill: BT RF going to : on
mxc_bt_rfkill_reset
workingset: timestamp_bits=30 max_order=18 bucket_order=0
Registering sdcardfs 0.1
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
ntfs: driver 2.1.32 [Flags: R/W DEBUG].
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.26)
bounce: pool size: 64 pages
io scheduler noop registered
imx-weim 21b8000.weim: Driver registered.
backlight supply power not found, using dummy regulator
mxc_sdc_fb fb@0: registered mxc display driver ldb
Console: switching to colour frame buffer device 100x30
mxc_sdc_fb fb@1: Can't get fb option for mxcfb1!
imx-sdma 20ec000.sdma: no iram assigned, using external mem
imx-sdma 20ec000.sdma: loaded firmware 3.3
2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 24, base_baud = 5000000) is a IMX
console [ttymxc0] enabled
21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 72, base_baud = 5000000) is a IMX
21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 73, base_baud = 5000000) is a IMX
imx sema4 driver is registered.
[drm] Initialized
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
zram: Added device: zram0
libphy: Fixed MDIO Bus: probed
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
CAN device driver interface
2090000.flexcan supply xceiver not found, using dummy regulator
flexcan 2090000.flexcan: device registered (reg_base=f8234000, irq=30)
imx6dl-pinctrl 20e0000.iomuxc: pin MX6DL_PAD_KEY_COL4 already requested by 21f4000.serial; cannot claim for 2094000.flexcan
imx6dl-pinctrl 20e0000.iomuxc: pin-149 (2094000.flexcan) status -22
imx6dl-pinctrl 20e0000.iomuxc: could not request pin 149 (MX6DL_PAD_KEY_COL4) from group flexcan2grp  on device 20e0000.iomuxc
flexcan 2094000.flexcan: Error applying setting, reverse things back
flexcan: probe of 2094000.flexcan failed with error -22
2188000.ethernet supply phy not found, using dummy regulator
pps pps0: new PPS source ptp0
fec 2188000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
fec 2188000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: 1a:10:0f:79:9e:ba
libphy: fec_enet_mii_bus: probed
fec 2188000.ethernet eth0: registered PHC device 0
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
usbcore: registered new interface driver kaweth
pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
usbcore: registered new interface driver pegasus
usbcore: registered new interface driver rtl8150
usbcore: registered new interface driver r8152
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver cdc_eem
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
ehci-mxc: Freescale On-Chip EHCI Host driver
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver ftdi_sio
usbserial: USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver option
usbserial: USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver usbtest
usbcore: registered new interface driver usb_ehset_test
2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
2184000.usb supply vbus not found, using dummy regulator
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 4.9.17-04736-ga88711e-dirty ehci_hcd
usb usb1: SerialNumber: ci_hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
2184200.usb supply vbus not found, using dummy regulator
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: EHCI Host Controller
usb usb2: Manufacturer: Linux 4.9.17-04736-ga88711e-dirty ehci_hcd
usb usb2: SerialNumber: ci_hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
usbcore: registered new interface driver xpad
usbcore: registered new interface driver usb_acecad
usbcore: registered new interface driver aiptek
usbcore: registered new interface driver gtco
usbcore: registered new interface driver hanwang
usbcore: registered new interface driver kbtab
snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc0
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x/sz) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR SANYO protocol handler initialized
IR Sharp protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR XMP protocol handler initialized
mxc_v4l2_output v4l2_out: V4L2 device registered as video16
mxc_v4l2_output v4l2_out: V4L2 device registered as video17
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
Bluetooth: HCI UART driver ver 2.3
Bluetooth: HCI UART protocol H4 registered
Bluetooth: HCI UART protocol BCSP registered
Bluetooth: HCI UART protocol ATH3K registered
usbcore: registered new interface driver btusb
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
sdhci-esdhc-imx 2194000.usdhc: Got WP GPIO
sdhci-esdhc-imx 2194000.usdhc: assigned as wifi host
mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
mmc3: SDHCI controller on 219c000.usdhc [219c000.usdhc] using ADMA
mxc_vpu 2040000.vpu_fsl: VPU initialized
mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
galcore: clk_get vg clock failed, disable vg!
Galcore version 6.2.2.96445
usb 2-1: new high-speed USB device number 2 using ci_hdrc
mmc3: new DDR MMC card at address 0001
mmcblk3: mmc3:0001 DG4016 14.7 GiB
mmcblk3boot0: mmc3:0001 DG4016 partition 1 4.00 MiB
mmcblk3boot1: mmc3:0001 DG4016 partition 2 4.00 MiB
mmcblk3rpmb: mmc3:0001 DG4016 partition 3 4.00 MiB
Alternate GPT is invalid, using primary GPT.
 mmcblk3: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
caam 2100000.caam: ERA source: CAAMVID.
caam 2100000.caam: AXI pipeline throttling enabled.
usb 2-1: New USB device found, idVendor=0424, idProduct=2512
usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 2 ports detected
caam 2100000.caam: Instantiated RNG4 SH1
caam 2100000.caam: device ID = 0x0a16010000000100 (Era 4)
caam 2100000.caam: job rings = 2, qi = 0
caam algorithms registered in /proc/crypto
caam_jr 2101000.jr0: registering rng-caam
platform caam_sm: blkkey_ex: 4 keystore units available
platform caam_sm: 64-bit clear key:
platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
platform caam_sm: 64-bit black key:
platform caam_sm: [0000] d8 73 a2 ab 0e 4b 53 35
platform caam_sm: [0008] 8e a8 3a 21 a5 89 80 7a
platform caam_sm: 128-bit clear key:
platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
platform caam_sm: 128-bit black key:
platform caam_sm: [0000] 5a e2 3d 4e 88 b9 38 7d
platform caam_sm: [0008] c6 3b f5 85 56 6f fe 9d
platform caam_sm: 192-bit clear key:
platform caam_sm: [0016] 10 11 12 13 14 15 16 17
platform caam_sm: 192-bit black key:
platform caam_sm: [0000] fc cf 52 aa 97 b1 4e 2d
platform caam_sm: [0008] 59 a6 78 85 fa 07 74 fc
platform caam_sm: [0016] ec b6 a2 d2 c1 0c a8 ce
platform caam_sm: [0024] cb 74 04 d7 21 99 89 17
platform caam_sm: 256-bit clear key:
platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
platform caam_sm: 256-bit black key:
platform caam_sm: [0000] 92 56 20 1f 76 1f 6b 9a
platform caam_sm: [0008] e9 ff fb 48 77 c6 be fa
platform caam_sm: [0016] 4a cb bf 1e 05 d1 69 75
platform caam_sm: [0024] 8b 3c 0f 5a ca 22 5c e7
platform caam_sm: 64-bit unwritten blob:
platform caam_sm: [0000] 00 00 00 00 00 00 00 00
platform caam_sm: [0008] 00 00 00 00 00 00 00 00
platform caam_sm: [0016] 00 00 00 00 00 00 00 00
platform caam_sm: [0024] 00 00 00 00 00 00 00 00
platform caam_sm: [0032] 00 00 00 00 00 00 00 00
platform caam_sm: [0040] 00 00 00 00 00 00 00 00
platform caam_sm: [0048] 00 00 00 00 00 00 00 00
platform caam_sm: [0056] 00 00 00 00 00 00 00 00
platform caam_sm: [0064] 00 00 00 00 00 00 00 00
platform caam_sm: [0072] 00 00 00 00 00 00 00 00
platform caam_sm: [0080] 00 00 00 00 00 00 00 00
platform caam_sm: [0088] 00 00 00 00 00 00 00 00
platform caam_sm: 128-bit unwritten blob:
platform caam_sm: 196-bit unwritten blob:
platform caam_sm: 256-bit unwritten blob:
platform caam_sm: 64-bit black key in blob:
platform caam_sm: [0000] 3e 83 e1 10 bd cb a5 9b
platform caam_sm: [0008] 7c 47 9a 80 79 fe 85 07
platform caam_sm: [0016] 14 ee 58 49 bd d9 9f 17
platform caam_sm: [0024] e7 0b fc 10 86 ef f7 30
platform caam_sm: [0032] 9c fb 53 16 b1 f9 9d fe
platform caam_sm: [0040] 87 fc 3b dd 4c cb 7f 97
platform caam_sm: [0048] 4f ea 88 73 75 86 78 60
platform caam_sm: 128-bit black key in blob:
platform caam_sm: [0000] 90 80 fe 42 86 1c 4c 30
platform caam_sm: [0008] cd a6 c6 b6 ef df b5 7d
platform caam_sm: [0016] bb 35 dd d1 58 94 88 78
platform caam_sm: [0024] b4 d3 fd f6 ce 6e 9d c7
platform caam_sm: [0032] c6 11 07 61 b1 f6 96 6d
platform caam_sm: [0040] 7a e8 45 d2 aa 15 e9 bd
platform caam_sm: [0048] 3b f5 bb 26 25 fd 4e 72
platform caam_sm: [0056] 76 b0 16 a2 6d 3e 3a e7
platform caam_sm: 192-bit black key in blob:
platform caam_sm: [0000] 34 45 00 1e 63 04 72 d0
platform caam_sm: [0008] fc 04 fe a6 7e ef fe 5e
platform caam_sm: [0016] 57 4c 1e 3f 68 8a bd 30
platform caam_sm: [0024] 55 52 27 db fb dc f1 76
platform caam_sm: [0032] 8b a6 e5 94 bb a0 6d bd
platform caam_sm: [0040] 81 74 0a ef e6 23 d8 4e
platform caam_sm: [0048] c2 19 c5 83 e8 fb 12 b2
platform caam_sm: [0056] 29 09 a2 48 e4 c4 5e d3
platform caam_sm: [0064] b7 9b 43 d4 84 36 c7 1e
platform caam_sm: 256-bit black key in blob:
platform caam_sm: [0000] 2e 46 9e c2 1c 67 70 66
platform caam_sm: [0008] 28 ea dd 32 a8 0f 51 4c
platform caam_sm: [0016] be 1d 75 38 36 5e 5c 24
platform caam_sm: [0024] 49 c8 34 15 dc 25 cf 74
platform caam_sm: [0032] 77 de 27 54 38 d0 cb c1
platform caam_sm: [0040] 5c f9 2d e5 aa 63 d6 60
platform caam_sm: [0048] b2 05 86 6c 42 dc 65 40
platform caam_sm: [0056] d1 78 a5 3e df f9 bb 1f
platform caam_sm: [0064] 94 b3 ff 28 8b 89 06 00
platform caam_sm: [0072] b9 69 c1 b3 6f de a0 75
platform caam_sm: restored 64-bit black key:
platform caam_sm: [0000] 19 96 c6 6c f6 7e eb 09
platform caam_sm: [0008] 4f 00 68 77 d9 ed 00 6f
platform caam_sm: restored 128-bit black key:
platform caam_sm: restored 192-bit black key:
platform caam_sm: [0016] ab 43 18 a6 c7 b3 e5 87
platform caam_sm: [0024] f9 f0 0b 13 98 76 d0 cb
platform caam_sm: restored 256-bit black key:
snvs-secvio 20cc000.caam-snvs: can't get snvs clock
snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ion_parse_dt_heap_common: id 0 type 4 name cma align 1000
ion_parse_dt_heap_common: id 1 type 1 name sys-contig align 1000
ion_parse_dt_heap_common: id 2 type 0 name system align 1000
ashmem: initialized
usbcore: registered new interface driver snd-usb-audio
fsl-ssi-dai 202c000.ssi: No cache defaults, reading back from HW
NET: Registered protocol family 26
u32 classifier
    Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
ctnetlink v0.93: registering with nfnetlink.
xt_time: kernel timezone is -0000
ip_tables: (C) 2000-2006 Netfilter Core Team
arp_tables: arp_tables: (C) 2002 David S. Miller
Initializing XFRM netlink socket
NET: Registered protocol family 10
mip6: Mobile IPv6
ip6_tables: (C) 2000-2006 Netfilter Core Team
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
NET: Registered protocol family 15
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20161123 t)
can: netlink gateway (rev 20130117) max_hops=1
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
cpu cpu0: Registered imx6q-cpufreq
registered taskstats version 1
imx_epdc_fb 20f4000.epdc: can't get/select pinctrl
imx_thermal 2000000.aips-bus:tempmon: Industrial CPU temperature grade - max:105C critical:100C passive:95C
dhd_module_init in
snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:13 UTC (13)
sensor-supply: disabling
ALSA device list:
  No soundcards found.
Freeing unused kernel memory: 1024K (c1300000 - c1400000)
init: init first stage started!
init: First stage mount skipped (missing/incompatible fstab in device tree)
init: Skipped setting INIT_AVB_VERSION (not in recovery mode)
init: Loading SELinux policy
SELinux:  Permission validate_trans in class security not defined in policy.
SELinux: the above unknown classes and permissions will be denied
audit: type=1403 audit(13.650:2): policy loaded auid=4294967295 ses=4294967295
selinux: SELinux: Loaded policy from /sepolicy
audit: type=1404 audit(13.670:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
selinux: SELinux: Loaded file_contexts
random: init: uninitialized urandom read (40 bytes read)
init: init second stage started!
selinux: SELinux: Loaded property_contexts from /plat_property_contexts & /nonplat_property_contexts.
init: Running restorecon...
selinux: SELinux:  Could not stat /dev/block: No such file or directory.
init: waitpid failed: No child processes
init: Couldn't load property file: Unable to open '/system/etc/prop.default': No such file or directory: No such file or directory
init: Couldn't load property file: Unable to open '/prop.default': No such file or directory: No such file or directory
init: Couldn't load property file: Unable to open '/odm/default.prop': No such file or directory: No such file or directory
init: Couldn't load property file: Unable to open '/vendor/default.prop': No such file or directory: No such file or directory
random: ueventd: uninitialized urandom read (40 bytes read)
ueventd: ueventd started!
ueventd: Parsing file /ueventd.rc...
ueventd: Parsing file /vendor/ueventd.rc...
ueventd: Unable to open '/vendor/ueventd.rc': No such file or directory
ueventd: Parsing file /odm/ueventd.rc...
ueventd: Unable to open '/odm/ueventd.rc': No such file or directory
ueventd: Parsing file /ueventd.freescale.rc...
ueventd: Coldboot took 0.310698 seconds
Console: switching to colour dummy device 80x30
random: fast init done
fec: <204> warning: __ecc_read: RS block 5263360: decoding failed
fec: <206> warning: __ecc_read: RS block 5263360: decoding failed
fec: <209> warning: __ecc_read: RS block 5263360: decoding failed
EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: barrier=1
tune2fs: tune2fs 1.43.3 (04-Sep-2016)
EXT4-fs (mmcblk3p10): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk3p10): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
e2fsck: e2fsck 1.43.3 (04-Sep-2016)
e2fsck: Pass 1: Checking inodes, blocks, and sizes
e2fsck: Pass 2: Checking directory structure
e2fsck: Pass 3: Checking directory connectivity
e2fsck: Pass 4: Checking reference counts
e2fsck: Pass 5: Checking group summary information
e2fsck: /dev/block/by-name/userdata: 11/315120 files (0.0% non-contiguous), 55023/1260032 blocks
EXT4-fs (mmcblk3p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
init: [libfs_mgr]__mount(source=/dev/block/by-name/userdata,target=/data,type=ext4)=0
init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/cache
init: [libfs_mgr]Requested quota status is match on /dev/block/by-name/cache
EXT4-fs (mmcblk3p4): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk3p4): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
init: [libfs_mgr]__mount(source=/dev/block/by-name/cache,target=/cache,type=ext4)=0
init: [libfs_mgr]superblock s_max_mnt_count:10,/dev/block/by-name/vendor
init: [libfs_mgr]Requested quota status is match on /dev/block/by-name/vendor
EXT4-fs (mmcblk3p9): mounted filesystem with ordered data mode. Opts: barrier=1
init: [libfs_mgr]__mount(source=/dev/block/by-name/vendor,target=/vendor,type=ext4)=0
init: Parsing directory /system/etc/init...
init: Parsing file /system/etc/init/android.hidl.allocator@1.0-service.rc...
init: Parsing file /system/etc/init/atrace.rc...
fec: <230> warning: __ecc_read: RS block 5263360: decoding failed
file system registered
using random self ethernet address
using random host ethernet address
logd.auditd: start
logd.klogd: 11073856667
binder: 234:234 ioctl 620a 487fcf7b returned -22
zram0: detected capacity change from 0 to 314572800
mkswap: Swapspace size: 307196k, UUID=734f7afc-d68b-48d5-86da-a3e8aed37420
Adding 307196k swap on /dev/block/zram0.  Priority:-1 extents:1 across:307196k SS
logd.daemon: reinit
rfkill: BT RF going to : off
type=1400 audit(22.110:4): avc: granted { read } for pid=1 comm="init" name="ttymxc0" dev="tmpfs" ino=9436 scontext=u:r:init:s0 tcontext=u:object_r:tty_device:s0 tclass=chr_file
sabresd_6dq:/ $ read descriptors
read strings
healthd: unable to get HAL interface, using defaults
healthd: No battery devices found
healthd: battery l=100 v=0 t=42.4 h=2 st=2 chg=a
type=1400 audit(22.150:5): avc: granted { read open } for pid=1 comm="init" path="/dev/ttymxc0" dev="tmpfs" ino=9436 scontext=u:r:init:s0 tcontext=u:object_r:tty_device:s0 tclass=chr_file
ERROR: v4l2 capture: slave not found!
type=1400 audit(22.170:6): avc: granted { read } for pid=268 comm="init" name="ttymxc0" dev="tmpfs" ino=9436 scontext=u:r:init:s0 tcontext=u:object_r:tty_device:s0 tclass=chr_file
init: starting service 'bootanim'...
type=1400 audit(22.170:7): avc: granted { read open } for pid=268 comm="init" path="/dev/ttymxc0" dev="tmpfs" ino=9436 scontext=u:r:init:s0 tcontext=u:object_r:tty_device:s0 tclass=chr_file
type=1400 audit(25.780:8): avc: denied { read } for pid=267 comm="surfaceflinger" name="dri" dev="tmpfs" ino=6769 scontext=u:r:surfaceflinger:s0 tcontext=u:object_r:device:s0 tclass=dir permissive=0
random: crng init done
capability: warning: `main' uses 32-bit capabilities (legacy support in use)
init: processing action (sys.interactive=active) from (/init.freescale.rc:172)
sabresd_6dq:/ $ healthd: battery l=100 v=0 t=42.4 h=2 st=2 chg=a
init: processing action (sys.sysctl.extra_free_kbytes=*) from (/init.rc:682)
init: Unable to open '/proc/sys/vm/extra_free_kbytes': No such file or directory
acc_open
acc_release
Micrel KSZ8081 or KSZ8091 2188000.ethernet:01: attached PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=2188000.ethernet:01, irq=-1)
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
sdcardfs version 2.0
sdcardfs: dev_name -> /data/media
sdcardfs: options -> fsuid=1023,fsgid=1023,multiuser,mask=6,userid=0,gid=1015
sdcardfs: mnt -> d12de310
sdcardfs: mounted on top of /data/media type ext4
Remount options were mask=23,gid=9997 for vfsmnt d12ded10.
init: starting service 'webview_zygote32'...
init: Created socket '/dev/socket/webview_zygote', mode 660, user 1053, group 1000
sdcardfs : options - debug:1
sdcardfs : options - gid:9997
sdcardfs : options - mask:23
Remount options were mask=7,gid=9997 for vfsmnt d1374410.
sdcardfs : options - mask:7
init: processing action (sys.usb.config=none && sys.usb.configfs=1) from (init.freescale.usb.rc:45)
init: processing action (sys.usb.config=none && sys.usb.configfs=1) from (/init.usb.configfs.rc:1)
init: Unable to write to '/config/usb_gadget/g1/UDC': No such device
init: Sending signal 9 to service 'adbd' (pid 269) process group...
init: Successfully killed process cgroup uid 0 pid 269 in 17ms
init: Command 'stop adbd' action=sys.usb.config=none && sys.usb.configfs=1 (/init.usb.configfs.rc:3) returned 0 took 54.155ms.
init: Service 'adbd' (pid 269) killed by signal 9
init: processing action (init.svc.adbd=stopped) from (/init.usb.configfs.rc:15)
read descriptors
read strings
read descriptors
read strings
type=1400 audit(64.270:9): avc: denied { write } for pid=379 comm="Binder:379_4" name="timerslack_ns" dev="proc" ino=14766 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
alloc_contig_range: [2de00, 2df78) PFNs busy
audit: audit_lost=1 audit_rate_limit=20 audit_backlog_limit=64
audit: rate limit exceeded
type=1400 audit(64.270:10): avc: denied { write } for pid=379 comm="Binder:379_4" name="timerslack_ns" dev="proc" ino=15578 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
type=1400 audit(64.270:11): avc: denied { write } for pid=379 comm="Binder:379_4" name="timerslack_ns" dev="proc" ino=15580 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
type=1400 audit(64.270:12): avc: denied { write } for pid=379 comm="Binder:379_4" name="timerslack_ns" dev="proc" ino=15582 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
type=1400 audit(64.270:13): avc: denied { write } for pid=379 comm="Binder:379_4" name="timerslack_ns" dev="proc" ino=15584 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
type=1400 audit(64.270:14): avc: denied { write } for pid=379 comm="Binder:379_4" name="timerslack_ns" dev="proc" ino=15586 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
type=1400 audit(64.270:15): avc: denied { write } for pid=379 comm="Binder:379_4" name="timerslack_ns" dev="proc" ino=15588 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
type=1400 audit(64.270:16): avc: denied { write } for pid=379 comm="Binder:379_4" name="timerslack_ns" dev="proc" ino=15590 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
type=1400 audit(64.270:17): avc: denied { write } for pid=379 comm="Binder:379_4" name="timerslack_ns" dev="proc" ino=14805 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
init: Service 'bootanim' (pid 366) exited with status 0
init: processing action (sys.boot_completed=1) from (/init.rc:676)
init: processing action (sys.boot_completed=1) from (/init.freescale.rc:164)
init: processing action (sys.boot_completed=1 && sys.logbootcomplete=1) from (/system/etc/init/bootstat.rc:34)
init: starting service 'exec 3 (/system/bin/bootstat --record_boot_complete)'...
init: SVC_EXEC pid 878 (uid 0 gid 0+0 context default) started; waiting...
init: Service 'exec 3 (/system/bin/bootstat --record_boot_complete)' (pid 878) exited with status 0 waiting took 0.446871 seconds
init: starting service 'exec 4 (/system/bin/bootstat --record_boot_reason)'...
init: SVC_EXEC pid 889 (uid 0 gid 0+0 context default) started; waiting...
init: Command 'exec - root root -- /system/bin/bootstat --record_boot_reason' action=sys.boot_completed=1 && sys.logbootcomplete=1 (/system/etc/init/bootstat.rc:39) returned 0 took 58.2287ms.
type=1400 audit(65.640:42): avc: denied { write } for pid=379 comm="Binder:379_2" name="timerslack_ns" dev="proc" ino=14805 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
type=1400 audit(77.420:48): avc: granted { getattr } for pid=518 comm=496E666C6174657254687265616420 path="/" dev="rootfs" ino=2 scontext=u:r:platform_app:s0:c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir
alloc_contig_range: [2da00, 2db78) PFNs busy
alloc_contig_range: [2db00, 2dc78) PFNs busy
alloc_contig_range: [2e000, 2e178) PFNs busy
type=1400 audit(78.420:59): avc: granted { getattr } for pid=518 comm=496E666C6174657254687265616420 path="/" dev="rootfs" ino=2 scontext=u:r:platform_app:s0:c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir duplicate messages suppressed
alloc_contig_range: [2e800, 2efd1) PFNs busy
alloc_contig_range: [2e800, 2f0d1) PFNs busy
alloc_contig_range: [2ea00, 2f1d1) PFNs busy
alloc_contig_range: [2eb00, 2f2d1) PFNs busy
alloc_contig_range: [2ec00, 2f3d1) PFNs busy
alloc_contig_range: [2ed00, 2f4d1) PFNs busy
alloc_contig_range: [2ee00, 2f5d1) PFNs busy
alloc_contig_range: [2ee00, 2f6d1) PFNs busy
alloc_contig_range: [2f000, 2f7d1) PFNs busy
alloc_contig_range: [2f000, 2f8d1) PFNs busy
alloc_contig_range: [2f200, 2f9d1) PFNs busy
alloc_contig_range: [2f300, 2fad1) PFNs busy
type=1400 audit(79.290:60): avc: denied { write } for pid=379 comm="Binder:379_3" name="timerslack_ns" dev="proc" ino=18506 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
type=1400 audit(79.290:61): avc: denied { write } for pid=379 comm="Binder:379_3" name="timerslack_ns" dev="proc" ino=17726 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
type=1400 audit(79.290:62): avc: denied { write } for pid=379 comm="Binder:379_3" name="timerslack_ns" dev="proc" ino=17728 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
type=1400 audit(79.290:63): avc: denied { write } for pid=379 comm="Binder:379_3" name="timerslack_ns" dev="proc" ino=17730 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
type=1400 audit(79.450:75): avc: granted { getattr } for pid=518 comm=496E666C6174657254687265616420 path="/" dev="rootfs" ino=2 scontext=u:r:platform_app:s0:c512,c768 tcontext=u:object_r:rootfs:s0 tclass=dir duplicate messages suppressed
type=1400 audit(84.890:76): avc: denied { write } for pid=379 comm="Binder:379_4" name="timerslack_ns" dev="proc" ino=18183 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
type=1400 audit(84.890:77): avc: denied { write } for pid=379 comm="Binder:379_4" name="timerslack_ns" dev="proc" ino=18217 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
type=1400 audit(84.890:78): avc: denied { write } for pid=379 comm="Binder:379_4" name="timerslack_ns" dev="proc" ino=18219 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
type=1400 audit(84.890:79): avc: denied { write } for pid=379 comm="Binder:379_4" name="timerslack_ns" dev="proc" ino=18221 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
type=1400 audit(84.890:80): avc: denied { write } for pid=379 comm="Binder:379_4" name="timerslack_ns" dev="proc" ino=18223 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
sabresd_6dq:/ $
sabresd_6dq:/ $
sabresd_6dq:/ $ logcat
--------- beginning of main
01-01 00:00:00.580   232   232 W auditd  : type=2000 audit(0.0:1): initialized
01-01 00:00:13.650   232   232 I auditd  : type=1403 audit(0.0:2): policy loaded auid=4294967295 ses=4294967295
01-01 00:00:13.670   232   232 W auditd  : type=1404 audit(0.0:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
01-01 00:00:21.041   235   235 I SELinux : SELinux: Loaded service_contexts from:
01-01 00:00:21.044   235   235 I SELinux :     /vndservice_contexts
01-01 00:00:21.055   233   233 I SELinux : SELinux: Loaded service_contexts from:
01-01 00:00:21.058   233   233 I SELinux :     /plat_service_contexts
01-01 00:00:21.058   233   233 I SELinux :     /nonplat_service_contexts
01-01 00:00:21.214   234   234 E hwservicemanager: BINDER_SET_INHERIT_FIFO_PRIO failed with error -1
--------- beginning of system
01-01 00:00:21.582   244   244 I vold    : Vold 3.0 (the awakening) firing up
01-01 00:00:21.582   244   244 V vold    : Detected support for: ext4 f2fs vfat
01-01 00:00:21.590   244   244 W Vold    : Tearing down stale mount /mnt/shm
01-01 00:00:21.654   244   244 I vold    : [libfs_mgr]fs_mgr_read_fstab_dt(): failed to read fstab from dt
01-01 00:00:21.662   244   248 D vold    : e4crypt_init_user0
01-01 00:00:21.662   244   248 D vold    : e4crypt_prepare_user_storage for volume null, user 0, serial 0, flags 1
01-01 00:00:21.663   244   248 D vold    : Preparing: /data/system/users/0
01-01 00:00:21.664   244   248 D vold    : Preparing: /data/misc/profiles/cur/0
01-01 00:00:21.666   244   248 D vold    : Preparing: /data/system_de/0
01-01 00:00:21.668   244   248 D vold    : Preparing: /data/misc_de/0
01-01 00:00:21.669   244   248 D vold    : Preparing: /data/user_de/0
01-01 00:00:21.671   244   248 D vold    : e4crypt_unlock_user_key 0 serial=0 token_present=0
01-01 00:00:21.671   244   248 E vold    : Failed to chmod /data/system_ce/0: No such file or directory
01-01 00:00:21.671   244   248 E vold    : Failed to chmod /data/misc_ce/0: No such file or directory
01-01 00:00:21.672   244   248 E vold    : Failed to chmod /data/media/0: No such file or directory
01-01 00:00:21.764   249   249 I /system/bin/tzdatacheck: timezone distro dir /data/misc/zoneinfo/current does not exist. No action required.
01-01 00:00:22.110     1     1 W init    : type=1400 audit(0.0:4): avc: granted { read } for name="ttymxc0" dev="tmpfs" ino=9436 scontext=u:r:init:s0 tcontext=u:object_r:tty_device:s0 tclass=chr_file
01-01 00:00:22.150     1     1 W init    : type=1400 audit(0.0:5): avc: granted { read open } for path="/dev/ttymxc0" dev="tmpfs" ino=9436 scontext=u:r:init:s0 tcontext=u:object_r:tty_device:s0 tclass=chr_file
01-01 00:00:22.170   268   268 W init    : type=1400 audit(0.0:6): avc: granted { read } for name="ttymxc0" dev="tmpfs" ino=9436 scontext=u:r:init:s0 tcontext=u:object_r:tty_device:s0 tclass=chr_file
01-01 00:00:22.170   268   268 W init    : type=1400 audit(0.0:7): avc: granted { read open } for path="/dev/ttymxc0" dev="tmpfs" ino=9436 scontext=u:r:init:s0 tcontext=u:object_r:tty_device:s0 tclass=chr_file
01-01 00:00:22.234   257   257 I ServiceManagement: Removing namespace from process name android.hardware.configstore@1.0-service to configstore@1.0.
01-01 00:00:22.239   253   253 I ServiceManagement: Removing namespace from process name android.hidl.allocator@1.0-service to allocator@1.0-s.
01-01 00:00:22.294   269   276 I adbd    : initializing functionfs
01-01 00:00:22.294   269   276 I adbd    : opening control endpoint /dev/usb-ffs/adb/ep0
01-01 00:00:22.444   266   266 I lowmemorykiller: Using in-kernel low memory killer interface
01-01 00:00:22.521   234   234 E hw-IPCThreadState: binder thread pool (1 threads) starved for 118 ms
01-01 00:00:22.523   255   255 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/android.hardware.bluetooth@1.0-impl.so from the current namespace instead.
01-01 00:00:22.532   259   259 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/android.hardware.light@2.0-impl.so from the current namespace instead.
01-01 00:00:22.578   261   261 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/android.hardware.power@1.0-impl.so from the current namespace instead.
01-01 00:00:22.580   255   255 I ServiceManagement: Removing namespace from process name android.hardware.bluetooth@1.0-service to bluetooth@1.0-s.
01-01 00:00:22.581   260   260 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/android.hardware.memtrack@1.0-impl.so from the current namespace instead.
01-01 00:00:22.585   263   263 I ServiceManagement: Removing namespace from process name android.hardware.usb@1.0-service to usb@1.0-service.
01-01 00:00:22.594   255   255 I android.hardware.bluetooth@1.0-service: Registration complete for android.hardware.bluetooth@1.0::IBluetoothHci/default.
01-01 00:00:22.597   262   262 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/android.hardware.sensors@1.0-impl.so from the current namespace instead.
01-01 00:00:22.608   261   261 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/power.imx6.so from the current namespace instead.
01-01 00:00:22.608   260   260 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/memtrack.imx6.so from the current namespace instead.
01-01 00:00:22.609   259   259 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/lights.imx6.so from the current namespace instead.
01-01 00:00:22.614   262   262 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/sensors.imx6.so from the current namespace instead.
01-01 00:00:22.617   262   262 E         : couldn't find 'FreescaleAccelerometer' input device
01-01 00:00:22.618   262   262 E         : Couldn't  open /dev/mma8x5x (No such file or directory)
01-01 00:00:22.618   262   262 E         : Can`t find the Acc sensor!
01-01 00:00:22.618   262   262 E         : couldn't find 'eCompass' input device
01-01 00:00:22.618   262   262 E         : Can`t find the mag sensor!
01-01 00:00:22.618   262   262 E         : couldn't find 'isl29023 light sensor' input device
01-01 00:00:22.618   262   262 E /vendor/bin/hw/android.hardware.sensors@1.0-service: HAL specifies version 1.4, but does not implement inject_sensor_data()
01-01 00:00:22.619   262   262 E /vendor/bin/hw/android.hardware.sensors@1.0-service: HAL specifies version 1.4, but does not implement set_operation_mode()
01-01 00:00:22.630   259   259 I lights  : max backlight file is /sys/class/backlight/backlight/max_brightness
01-01 00:00:22.630   259   259 I lights  : backlight brightness file is /sys/class/backlight/backlight/brightness
01-01 00:00:22.630   259   259 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/lights.imx6.so from the current namespace instead.
01-01 00:00:22.631   259   259 E light   : light_open lights keyboard failed: -22
01-01 00:00:22.631   259   259 E light   : Light passthrough failed to load legacy HAL.
01-01 00:00:22.631   259   259 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/lights.imx6.so from the current namespace instead.
01-01 00:00:22.632   259   259 E light   : light_open lights buttons failed: -22
01-01 00:00:22.632   259   259 E light   : Light passthrough failed to load legacy HAL.
01-01 00:00:22.632   259   259 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/lights.imx6.so from the current namespace instead.
01-01 00:00:22.633   259   259 E light   : light_open lights battery failed: -22
01-01 00:00:22.633   259   259 E light   : Light passthrough failed to load legacy HAL.
01-01 00:00:22.633   259   259 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/lights.imx6.so from the current namespace instead.
01-01 00:00:22.634   259   259 E light   : light_open lights notifications failed: -22
01-01 00:00:22.634   259   259 E light   : Light passthrough failed to load legacy HAL.
01-01 00:00:22.634   259   259 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/lights.imx6.so from the current namespace instead.
01-01 00:00:22.635   259   259 E light   : light_open lights attention failed: -22
01-01 00:00:22.635   259   259 E light   : Light passthrough failed to load legacy HAL.
01-01 00:00:22.635   259   259 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/lights.imx6.so from the current namespace instead.
01-01 00:00:22.636   259   259 E light   : light_open lights bluetooth failed: -22
01-01 00:00:22.636   259   259 E light   : Light passthrough failed to load legacy HAL.
01-01 00:00:22.636   259   259 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/lights.imx6.so from the current namespace instead.
01-01 00:00:22.637   259   259 E light   : light_open lights wifi failed: -22
01-01 00:00:22.637   259   259 E light   : Light passthrough failed to load legacy HAL.
01-01 00:00:22.642   263   263 I android.hardware.usb@1.0-service: USB HAL Ready.
01-01 00:00:22.643   260   260 I ServiceManagement: Removing namespace from process name android.hardware.memtrack@1.0-service to memtrack@1.0-se.
01-01 00:00:22.678   262   262 I ServiceManagement: Removing namespace from process name android.hardware.sensors@1.0-service to sensors@1.0-ser.
01-01 00:00:22.678   259   259 I ServiceManagement: Removing namespace from process name android.hardware.light@2.0-service to light@2.0-servi.
01-01 00:00:22.680   260   260 I android.hardware.memtrack@1.0-service: Registration complete for android.hardware.memtrack@1.0::IMemtrack/default.
01-01 00:00:22.683   262   262 I android.hardware.sensors@1.0-service: Registration complete for android.hardware.sensors@1.0::ISensors/default.
01-01 00:00:22.685   259   259 I android.hardware.light@2.0-service: Registration complete for android.hardware.light@2.0::ILight/default.
01-01 00:00:22.696   261   261 I ServiceManagement: Removing namespace from process name android.hardware.power@1.0-service to power@1.0-servi.
01-01 00:00:22.698   261   261 I android.hardware.power@1.0-service: Registration complete for android.hardware.power@1.0::IPower/default.
01-01 00:00:22.708   258   258 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/android.hardware.graphics.allocator@2.0-impl.so from the current namespace instead.
01-01 00:00:22.725   258   258 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/gralloc.imx6.so from the current namespace instead.
01-01 00:00:22.758   250   250 I Netd    : Netd 1.0 starting
01-01 00:00:22.759   250   250 D TetherController: Setting IP forward enable = 0
01-01 00:00:22.791   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.health@1.0::IHealth/default in either framework or device manifest.
01-01 00:00:22.814   256   256 I android.hardware.camera.provider@2.4-service: Camera provider Service is starting.
01-01 00:00:22.839   273   273 I installd: installd firing up
01-01 00:00:22.839   273   273 E cutils  : Failed to read /data/.layout_version: No such file or directory
01-01 00:00:22.840   273   273 D installd: Assuming that device has multi-user storage layout; upgrade no longer supported
01-01 00:00:22.843   273   273 D installd: Upgrading to /data/misc/user directories
01-01 00:00:22.845   256   256 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/android.hardware.camera.provider@2.4-impl.so from the current namespace instead.
01-01 00:00:22.875   284   284 D MagDaemon: init_sensors
01-01 00:00:22.908   284   284 D MagDaemon: couldn't find 'FreescaleAccelerometer' input device
01-01 00:00:22.908   284   284 D MagDaemon: inital sensor error
01-01 00:00:22.967   258   258 I ServiceManagement: Removing namespace from process name android.hardware.graphics.allocator@2.0-service to allocator@2.0-s.
01-01 00:00:22.974   288   288 I /system/bin/tombstoned: tombstoned successfully initialized
01-01 00:00:22.979   258   258 I android.hardware.graphics.allocator@2.0-service: Registration complete for android.hardware.graphics.allocator@2.0::IAllocator/default.
01-01 00:00:23.256   256   256 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/camera.imx6.so from the current namespace instead.
01-01 00:00:23.372   281   281 I wificond: wificond is starting up...
01-01 00:00:23.390   264   264 I android.hardware.wifi@1.0-service: Wifi Hal is booting up...
01-01 00:00:23.474   285   285 I gatekeeperd: Starting gatekeeperd...
01-01 00:00:23.500   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.gatekeeper@1.0::IGatekeeper/default in either framework or device manifest.
01-01 00:00:23.501   285   285 W gatekeeperd: falling back to software GateKeeper
01-01 00:00:23.506   269   276 I adbd    : functionfs successfully initialized
01-01 00:00:23.507   269   276 I adbd    : registering usb transport
01-01 00:00:23.936   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.keymaster@3.0::IKeymasterDevice/default in either framework or device manifest.
01-01 00:00:23.939   274   274 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/android.hardware.keymaster@3.0-impl.so from the current namespace instead.
01-01 00:00:23.967   274   274 I android.hardware.keymaster@3.0-impl: Fetching keymaster device name default
01-01 00:00:24.030   274   274 I android.hardware.keymaster@3.0-impl: Found keymaster0 module Keymaster OpenSSL HAL, version 2
01-01 00:00:24.030   274   274 I android.hardware.keymaster@3.0-impl: Keymaster0 module is software-only.  Using SoftKeymasterDevice instead.
01-01 00:00:24.050   275   275 I mediaserver: ServiceManager: 0xb30974c0
01-01 00:00:24.263   256   256 I FslCameraHAL: enumSensorSet
01-01 00:00:24.264   256   256 I FslCameraHAL: matchDevNodes
01-01 00:00:24.264   256   256 I FslCameraHAL: getNodeName: dev path:/dev/video17
01-01 00:00:24.283   256   256 W FslCameraHAL: getNodeName dev path:/dev/video17 is not capture
01-01 00:00:24.285   256   256 I FslCameraHAL: getNodeName: dev path:/dev/video0
01-01 00:00:24.285   256   256 W FslCameraHAL: getNodeName open dev path:/dev/video0 failed:Try again
01-01 00:00:24.285   256   256 I FslCameraHAL: getNodeName: dev path:/dev/video16
01-01 00:00:24.285   256   256 W FslCameraHAL: getNodeName open dev path:/dev/video16 failed:Permission denied
01-01 00:00:24.285   256   256 I FslCameraHAL: matchPropertyName: index:0, ov5640_mipi,ov5642_camera,ov5640_camera
01-01 00:00:24.285   256   256 I FslCameraHAL: index:0, propName:ov5640_mipi
01-01 00:00:24.285   256   256 I FslCameraHAL: matchNodeName
01-01 00:00:24.285   256   256 I FslCameraHAL: index:0, propName:ov5642_camera
01-01 00:00:24.285   256   256 I FslCameraHAL: index:0, propName:ov5640_camera
01-01 00:00:24.285   256   256 I FslCameraHAL: matchPropertyName: index:1, uvc,ov5642_camera,ov5640_camera
01-01 00:00:24.286   256   256 I FslCameraHAL: index:1, propName:uvc
01-01 00:00:24.286   256   256 I FslCameraHAL: matchNodeName
01-01 00:00:24.286   256   256 I FslCameraHAL: index:1, propName:ov5642_camera
01-01 00:00:24.286   256   256 I FslCameraHAL: index:1, propName:ov5640_camera
01-01 00:00:24.286   256   256 I FslCameraHAL: camera number is 0
01-01 00:00:24.286   256   256 I CamProvider@2.4-impl: Loaded "Default Camera HAL" camera module
01-01 00:00:24.288   256   256 I ServiceManagement: Removing namespace from process name android.hardware.camera.provider@2.4-service to provider@2.4-se.
01-01 00:00:24.290   256   256 I android.hardware.camera.provider@2.4-service: Registration complete for android.hardware.camera.provider@2.4::ICameraProvider/legacy/0.
01-01 00:00:24.480   254   254 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/android.hardware.audio@2.0-impl.so from the current namespace instead.
01-01 00:00:24.522   254   254 I ServiceManagement: Removing namespace from process name android.hardware.audio@2.0-service to audio@2.0-servi.
01-01 00:00:24.533   254   254 I audiohalservice: Registration complete for android.hardware.audio@2.0::IDevicesFactory/default.
01-01 00:00:24.537   254   254 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/android.hardware.audio.effect@2.0-impl.so from the current namespace instead.
01-01 00:00:24.697   254   254 I audiohalservice: Registration complete for android.hardware.audio.effect@2.0::IEffectsFactory/default.
01-01 00:00:24.699   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.soundtrigger@2.0::ISoundTriggerHw/default in either framework or device manifest.
01-01 00:00:24.702   282   282 I /vendor/bin/hw/android.hardware.media.omx@1.0-service: mediacodecservice starting
01-01 00:00:24.703   254   254 E audiohalservice: Could not get passthrough implementation for android.hardware.soundtrigger@2.0::ISoundTriggerHw/default.
01-01 00:00:24.703   254   254 E audiohalservice: Error while registering soundtrigger service: 1
01-01 00:00:24.704   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.broadcastradio@1.0::IBroadcastRadioFactory/default in either framework or device manifest.
01-01 00:00:24.705   254   254 E audiohalservice: Could not get passthrough implementation for android.hardware.broadcastradio@1.0::IBroadcastRadioFactory/default.
01-01 00:00:24.705   254   254 E audiohalservice: Error while registering fm radio service: 1
01-01 00:00:24.721   282   282 W /vendor/bin/hw/android.hardware.media.omx@1.0-service: libminijail[282]: allowing syscall: clock_gettime
01-01 00:00:24.721   282   282 W /vendor/bin/hw/android.hardware.media.omx@1.0-service: libminijail[282]: allowing syscall: connect
01-01 00:00:24.721   282   282 W /vendor/bin/hw/android.hardware.media.omx@1.0-service: libminijail[282]: allowing syscall: fcntl64
01-01 00:00:24.721   282   282 W /vendor/bin/hw/android.hardware.media.omx@1.0-service: libminijail[282]: allowing syscall: socket
01-01 00:00:24.722   282   282 W /vendor/bin/hw/android.hardware.media.omx@1.0-service: libminijail[282]: allowing syscall: writev
01-01 00:00:24.723   282   282 W /vendor/bin/hw/android.hardware.media.omx@1.0-service: libminijail[282]: logging seccomp filter failures
01-01 00:00:24.724   282   282 I ServiceManagement: Removing namespace from process name android.hardware.media.omx@1.0-service to omx@1.0-service.
01-01 00:00:24.730   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.configstore@1.0::ISurfaceFlingerConfigs/default in either framework or device manifest.
01-01 00:00:24.738   267   267 I /system/bin/surfaceflinger: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::maxFrameBufferAcquiredBuffers retrieved: 3
01-01 00:00:24.754   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.configstore@1.0::ISurfaceFlingerConfigs/default in either framework or device manifest.
01-01 00:00:24.764   267   267 I /system/bin/surfaceflinger: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::startGraphicsAllocatorService retrieved: 0
01-01 00:00:24.774   267   267 I SurfaceFlinger: SurfaceFlinger is starting
01-01 00:00:24.782   267   267 I /system/bin/surfaceflinger: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::vsyncEventPhaseOffsetNs retrieved: 1000000 (default)
01-01 00:00:24.783   267   267 I /system/bin/surfaceflinger: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::vsyncSfEventPhaseOffsetNs retrieved: 1000000 (default)
01-01 00:00:24.788   267   267 I /system/bin/surfaceflinger: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasSyncFramework retrieved: 1
01-01 00:00:24.788   267   267 I /system/bin/surfaceflinger: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::useContextPriority retrieved: 0 (default)
01-01 00:00:24.798   267   267 I /system/bin/surfaceflinger: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::presentTimeOffsetFromVSyncNs retrieved: 0
01-01 00:00:24.798   267   267 I /system/bin/surfaceflinger: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::useHwcForRGBtoYUV retrieved: 0
01-01 00:00:24.808   267   267 I /system/bin/surfaceflinger: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::maxVirtualDisplaySize retrieved: 0 (default)
01-01 00:00:24.808   267   267 I /system/bin/surfaceflinger: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::useVrFlinger retrieved: 0 (default)
01-01 00:00:24.808   267   267 I /system/bin/surfaceflinger: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::maxFrameBufferAcquiredBuffers retrieved: 3
01-01 00:00:24.809   267   267 I /system/bin/surfaceflinger: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
01-01 00:00:24.809   267   267 I SurfaceFlinger: Enabling HWC virtual displays
01-01 00:00:24.810   267   267 I SurfaceFlinger: Disabling Triple Buffering
01-01 00:00:24.811   267   267 I SurfaceFlinger: SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
01-01 00:00:24.811   267   267 I SurfaceFlinger: Phase offest NS: 1000000
01-01 00:00:24.818   267   267 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/egl/libEGL_VIVANTE.so from the current namespace instead.
01-01 00:00:24.825   267   267 D libEGL  : loaded /vendor/lib/egl/libEGL_VIVANTE.so
01-01 00:00:24.917   267   267 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/egl/libGLESv1_CM_VIVANTE.so from the current namespace instead.
01-01 00:00:24.918   267   267 D libEGL  : loaded /vendor/lib/egl/libGLESv1_CM_VIVANTE.so
01-01 00:00:25.013   282   282 W MediaCodecsXmlParser: unable to open media codecs configuration xml file: /data/misc/media/media_codecs_profiling_results.xml
01-01 00:00:25.013   282   282 I ServiceManagement: Removing namespace from process name android.hardware.media.omx@1.0-service to omx@1.0-service.
01-01 00:00:25.015   282   282 I /vendor/bin/hw/android.hardware.media.omx@1.0-service: Treble OMX service created.
01-01 00:00:25.136   267   267 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/egl/libGLESv2_VIVANTE.so from the current namespace instead.
01-01 00:00:25.137   267   267 D libEGL  : loaded /vendor/lib/egl/libGLESv2_VIVANTE.so
01-01 00:00:25.478   280   309 E packagelistparser: Could not open: "/data/system/packages.list", error: "No such file or directory"
01-01 00:00:25.562   280   309 I /system/bin/storaged: storaged: Start
01-01 00:00:25.615   267   267 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/gralloc.imx6.so from the current namespace instead.
01-01 00:00:25.642   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.configstore@1.0::ISurfaceFlingerConfigs/default in either framework or device manifest.
01-01 00:00:25.648   267   267 I /system/bin/surfaceflinger: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
01-01 00:00:25.650   267   267 W SurfaceFlinger: no suitable EGLConfig found, trying a simpler query
01-01 00:00:25.650   267   267 I SurfaceFlinger: EGL information:
01-01 00:00:25.650   267   267 I SurfaceFlinger: vendor    : Android
01-01 00:00:25.650   267   267 I SurfaceFlinger: version   : 1.4 Android META-EGL
01-01 00:00:25.650   267   267 I SurfaceFlinger: extensions: EGL_KHR_get_all_proc_addresses EGL_ANDROID_presentation_time EGL_KHR_swap_buffers_with_damage EGL_ANDROID_get_native_client_buffer EGL_ANDROID_front_buffer_auto_refresh EGL_ANDROID_get_frame_timestamps EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_lock_surface EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_reusable_sync EGL_KHR_fence_sync EGL_KHR_create_context EGL_KHR_surfaceless_context EGL_ANDROID_image_native_buffer EGL_KHR_wait_sync EGL_ANDROID_recordable EGL_EXT_buffer_age
01-01 00:00:25.650   267   267 I SurfaceFlinger: Client API: OpenGL_ES
01-01 00:00:25.650   267   267 I SurfaceFlinger: EGLSurface: 8-8-8-8, config=0x15
01-01 00:00:25.689   267   267 I SurfaceFlinger: OpenGL ES informations:
01-01 00:00:25.689   267   267 I SurfaceFlinger: vendor    : Vivante Corporation
01-01 00:00:25.689   267   267 I SurfaceFlinger: renderer  : Vivante GC880
01-01 00:00:25.689   267   267 I SurfaceFlinger: version   : OpenGL ES 3.0 V6.2.2.P1.96445
01-01 00:00:25.689   267   267 I SurfaceFlinger: extensions: GL_EXT_debug_marker GL_OES_vertex_type_10_10_10_2 GL_OES_vertex_half_float GL_OES_element_index_uint GL_OES_mapbuffer GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_rgb8_rgba8 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_depth24 GL_OES_depth32 GL_OES_packed_depth_stencil GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_fragment_precision_high GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_required_internalformat GL_OES_surfaceless_context GL_OES_texture_half_float GL_OES_texture_float GL_EXT_texture_type_2_10_10_10_REV GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_read_format_bgra GL_EXT_multi_draw_arrays GL_EXT_frag_depth GL_EXT_discard_framebuffer GL_EXT_blend_minmax GL_EXT_multisampled_render_to_texture GL_EXT_robustness GL_EXT_texture_sRGB_decode GL_EXT_texture_rg GL_VIV_direct_texture
01-01 00:00:25.689   267   267 I SurfaceFlinger: GL_MAX_TEXTURE_SIZE = 8192
01-01 00:00:25.689   267   267 I SurfaceFlinger: GL_MAX_VIEWPORT_DIMS = 8192
01-01 00:00:25.693   267   267 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/android.hardware.graphics.composer@2.1-impl.so from the current namespace instead.
01-01 00:00:25.707   267   267 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/hwcomposer.imx6.so from the current namespace instead.
01-01 00:00:25.710   267   267 I hwcomposer: hwc_device_open,1229
01-01 00:00:25.713   267   267 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/android.hardware.graphics.mapper@2.0-impl.so from the current namespace instead.
01-01 00:00:25.719   267   267 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/gralloc.imx6.so from the current namespace instead.
01-01 00:00:25.780   267   267 W surfaceflinger: type=1400 audit(0.0:8): avc: denied { read } for name="dri" dev="tmpfs" ino=6769 scontext=u:r:surfaceflinger:s0 tcontext=u:object_r:device:s0 tclass=dir permissive=0
01-01 00:00:25.795   267   267 E display : enumKmsDisplays open /sys/class/graphics failed
01-01 00:00:25.795   267   267 I display : entry:fb1 get fb1
01-01 00:00:25.795   267   267 I display : fb1 is overlay device
01-01 00:00:25.795   267   267 I display : entry:fb0 get fb0
01-01 00:00:25.796   267   267 I display : fb0 is ldb
01-01 00:00:25.796   267   267 I display :  device
01-01 00:00:25.868   278   278 I mediametrics: ServiceManager: 0xb4697540
01-01 00:00:25.868   278   278 D MediaAnalyticsService: MediaAnalyticsService created
01-01 00:00:25.868   278   278 D MediaAnalyticsService: MediaAnalyticsService::newSummarizerSet
01-01 00:00:26.018   250   250 I Netd    : Creating child chains: 3254.1ms
01-01 00:00:26.018   250   250 I Netd    : Setting up OEM hooks: 0.3ms
01-01 00:00:26.091   250   250 I Netd    : Setting up FirewallController hooks: 73.0ms
01-01 00:00:26.098   250   250 I Netd    : Setting up NatController hooks: 7.1ms
01-01 00:00:26.112   250   250 I Netd    : Setting up BandwidthController hooks: 13.3ms
01-01 00:00:26.112   250   250 I Netd    : Setting up IdletimerController hooks: 0.1ms
01-01 00:00:26.158   250   250 I Netd    : Disabling bandwidth control: 46.5ms
01-01 00:00:26.161   250   250 E Netd    : cannot find interface dummy0
01-01 00:00:26.162   250   250 I Netd    : Initializing RouteController: 3.1ms
01-01 00:00:26.164   250   250 D MDnsDS  : MDnsSdListener::Hander starting up
01-01 00:00:26.200   250   250 I Netd    : Registering NetdNativeService: 1.9ms
01-01 00:00:26.200   250   250 I Netd    : Starting CommandListener: 0.3ms
01-01 00:00:26.206   250   250 I Netd    : Registering NetdHwService: 6.0ms
01-01 00:00:26.206   250   250 I Netd    : Netd started in 3448ms
01-01 00:00:26.249   250   339 D MDnsDS  : MDnsSdListener starting to monitor
01-01 00:00:26.250   250   339 D MDnsDS  : Going to poll with pollCount 1
01-01 00:00:26.447   277   277 V MediaUtils: physMem: 1042649088
01-01 00:00:26.447   277   277 V MediaUtils: requested limit: 208529800
01-01 00:00:26.447   277   277 V MediaUtils: actual limit: 3221225472
01-01 00:00:26.447   277   277 V MediaUtils: original limits: 4294967295/4294967295
01-01 00:00:26.447   277   277 V MediaUtils: new limits: 3221225472/4294967295
01-01 00:00:26.447   277   277 I vndksupport: sphal namespace is not configured for this process. Loading libutils.so from the current namespace instead.
01-01 00:00:26.459   277   277 W /system/bin/mediaextractor: libminijail[277]: allowing syscall: clock_gettime
01-01 00:00:26.459   277   277 W /system/bin/mediaextractor: libminijail[277]: allowing syscall: connect
01-01 00:00:26.459   277   277 W /system/bin/mediaextractor: libminijail[277]: allowing syscall: fcntl64
01-01 00:00:26.459   277   277 W /system/bin/mediaextractor: libminijail[277]: allowing syscall: socket
01-01 00:00:26.459   277   277 W /system/bin/mediaextractor: libminijail[277]: allowing syscall: writev
01-01 00:00:26.460   277   277 W /system/bin/mediaextractor: libminijail[277]: logging seccomp filter failures
01-01 00:00:26.506   251   251 D AndroidRuntime: >>>>>> START com.android.internal.os.ZygoteInit uid 0 <<<<<<
01-01 00:00:26.517   267   267 W display : xres         = 800 px
01-01 00:00:26.517   267   267 W display : yres         = 480 px
01-01 00:00:26.517   267   267 W display : fps          = 112.04 Hz
01-01 00:00:26.517   267   267 W display : bpp          = 32
01-01 00:00:26.517   267   267 W display : r            =  0:8
01-01 00:00:26.517   267   267 W display : g            =  8:8
01-01 00:00:26.517   267   267 W display : b            = 16:8
01-01 00:00:26.552   267   267 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/android.hardware.graphics.mapper@2.0-impl.so from the current namespace instead.
01-01 00:00:26.553   267   267 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/gralloc.imx6.so from the current namespace instead.
01-01 00:00:26.578   271   271 I cameraserver: ServiceManager: 0xad717500
01-01 00:00:26.578   271   271 I CameraService: CameraService started (pid=271)
01-01 00:00:26.578   271   271 I CameraService: CameraService process starting
01-01 00:00:26.579   271   271 W BatteryNotifier: batterystats service unavailable!
01-01 00:00:26.580   271   271 W BatteryNotifier: batterystats service unavailable!
01-01 00:00:26.586   271   271 I CameraProviderManager: Connecting to new camera provider: legacy/0, isRemote? 1
01-01 00:00:26.587   271   271 I CameraProviderManager: Camera provider legacy/0 ready with 0 camera devices
01-01 00:00:26.627   271   349 W CameraProviderManager: addProviderLocked: Camera provider HAL with name 'legacy/0' already registered
01-01 00:00:26.743   267   267 E gralloc : gralloc1_device_open invalid name:fb0
01-01 00:00:26.743   267   267 I v_egl   : FramebufferSurface: bufferCount=3
01-01 00:00:26.814   251   251 I zygote  : option[0]=-Xzygote
01-01 00:00:26.814   251   251 I zygote  : option[1]=-Xstacktracefile:/data/anr/traces.txt
01-01 00:00:26.814   251   251 I zygote  : option[2]=exit
01-01 00:00:26.814   251   251 I zygote  : option[3]=vfprintf
01-01 00:00:26.814   251   251 I zygote  : option[4]=sensitiveThread
01-01 00:00:26.814   251   251 I zygote  : option[5]=-verbose:gc
01-01 00:00:26.814   251   251 I zygote  : option[6]=-Xms8m
01-01 00:00:26.814   251   251 I zygote  : option[7]=-Xmx384m
01-01 00:00:26.814   251   251 I zygote  : option[8]=-XX:HeapGrowthLimit=128m
01-01 00:00:26.814   251   251 I zygote  : option[9]=-XX:HeapMinFree=512k
01-01 00:00:26.815   251   251 I zygote  : option[10]=-XX:HeapMaxFree=8m
01-01 00:00:26.815   251   251 I zygote  : option[11]=-XX:HeapTargetUtilization=0.75
01-01 00:00:26.815   251   251 I zygote  : option[12]=-Xusejit:true
01-01 00:00:26.815   251   251 I zygote  : option[13]=-Xjitsaveprofilinginfo
01-01 00:00:26.815   251   251 I zygote  : option[14]=-agentlib:jdwp=transport=dt_android_adb,suspend=n,server=y
01-01 00:00:26.815   251   251 I zygote  : option[15]=-Xlockprofthreshold:500
01-01 00:00:26.815   251   251 I zygote  : option[16]=-Ximage-compiler-option
01-01 00:00:26.815   251   251 I zygote  : option[17]=--runtime-arg
01-01 00:00:26.815   251   251 I zygote  : option[18]=-Ximage-compiler-option
01-01 00:00:26.815   251   251 I zygote  : option[19]=-Xms64m
01-01 00:00:26.815   251   251 I zygote  : option[20]=-Ximage-compiler-option
01-01 00:00:26.815   251   251 I zygote  : option[21]=--runtime-arg
01-01 00:00:26.815   251   251 I zygote  : option[22]=-Ximage-compiler-option
01-01 00:00:26.815   251   251 I zygote  : option[23]=-Xmx64m
01-01 00:00:26.815   251   251 I zygote  : option[24]=-Ximage-compiler-option
01-01 00:00:26.815   251   251 I zygote  : option[25]=--image-classes=/system/etc/preloaded-classes
01-01 00:00:26.815   251   251 I zygote  : option[26]=-Ximage-compiler-option
01-01 00:00:26.815   251   251 I zygote  : option[27]=--compiled-classes=/system/etc/compiled-classes
01-01 00:00:26.815   251   251 I zygote  : option[28]=-Xcompiler-option
01-01 00:00:26.815   251   251 I zygote  : option[29]=--runtime-arg
01-01 00:00:26.815   251   251 I zygote  : option[30]=-Xcompiler-option
01-01 00:00:26.815   251   251 I zygote  : option[31]=-Xms64m
01-01 00:00:26.815   251   251 I zygote  : option[32]=-Xcompiler-option
01-01 00:00:26.816   251   251 I zygote  : option[33]=--runtime-arg
01-01 00:00:26.816   251   251 I zygote  : option[34]=-Xcompiler-option
01-01 00:00:26.816   251   251 I zygote  : option[35]=-Xmx512m
01-01 00:00:26.816   251   251 I zygote  : option[36]=-Ximage-compiler-option
01-01 00:00:26.816   251   251 I zygote  : option[37]=--instruction-set-variant=cortex-a9
01-01 00:00:26.816   251   251 I zygote  : option[38]=-Xcompiler-option
01-01 00:00:26.816   251   251 I zygote  : option[39]=--instruction-set-variant=cortex-a9
01-01 00:00:26.816   251   251 I zygote  : option[40]=-Ximage-compiler-option
01-01 00:00:26.816   251   251 I zygote  : option[41]=--instruction-set-features=default
01-01 00:00:26.816   251   251 I zygote  : option[42]=-Xcompiler-option
01-01 00:00:26.816   251   251 I zygote  : option[43]=--instruction-set-features=default
01-01 00:00:26.816   251   251 I zygote  : option[44]=-Duser.locale=en-US
01-01 00:00:26.816   251   251 I zygote  : option[45]=--cpu-abilist=armeabi-v7a,armeabi
01-01 00:00:26.816   251   251 I zygote  : option[46]=-Xfingerprint:Android/sabresd_6dq/sabresd_6dq:8.0.0/1.0.0-rfp-rc4/20180205:userdebug/dev-keys
01-01 00:00:26.922   279   279 I mediaserver: ServiceManager: 0xafd17560
01-01 00:00:26.923   279   279 W BatteryNotifier: batterystats service unavailable!
01-01 00:00:26.978   251   251 W zygote  : Could not reserve sentinel fault page
01-01 00:00:27.024   251   251 I zygote  : Pruning dalvik-cache since we are relocating an image and will need to recompile
01-01 00:00:27.025   251   251 I zygote  : RelocateImage: /system/bin/patchoat --input-image-location=/system/framework/boot.art --output-image-file=/data/dalvik-cache/arm/system@framework@boot.art --instruction-set=arm --base-offset-delta=-1990656
01-01 00:00:27.096   358   358 W patchoat: Could not reserve sentinel fault page
01-01 00:00:27.170   270   270 I FastMixerState: sMaxFastTracks = 8
01-01 00:00:27.182   270   270 I audioserver: ServiceManager: 0xb24974c0
01-01 00:00:27.182   270   270 W BatteryNotifier: batterystats service unavailable!
01-01 00:00:27.205   270   270 I AudioFlinger: Using default 3000 mSec as standby time.
01-01 00:00:27.245   270   270 E APM::Serializer: deserialize: Could not parse /odm/etc/audio_policy_configuration.xml document.
01-01 00:00:27.268   267   267 D SurfaceFlinger: shader cache generated - 24 shaders in 497.742645 ms
01-01 00:00:27.272   267   267 D SurfaceFlinger: Set power mode=2, type=0 flinger=0xa87d1000
01-01 00:00:27.288   254   254 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/audio.primary.imx6.so from the current namespace instead.
01-01 00:00:27.351   254   254 E audio_hw_primary: no supported sound card found, aborting.
01-01 00:00:27.351   254   254 E DevicesFactoryHAL: loadAudioInterface couldn't open audio hw device in audio.primary (Invalid argument)
01-01 00:00:27.351   270   270 E AudioFlinger: loadHwModule() error -19 loading module primary
01-01 00:00:27.351   270   270 W APM_AudioPolicyManager: could not open HW module primary
01-01 00:00:27.482   270   270 I bt_a2dp_hw: adev_open:  adev_open in A2dp_hw module
01-01 00:00:27.482   270   270 I AudioFlinger: loadHwModule() Loaded a2dp audio interface, handle 10
01-01 00:00:27.483   254   359 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/audio.usb.default.so from the current namespace instead.
01-01 00:00:27.490   270   270 I AudioFlinger: loadHwModule() Loaded usb audio interface, handle 18
01-01 00:00:27.491   254   359 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/audio.r_submix.default.so from the current namespace instead.
01-01 00:00:27.523   254   359 I r_submix: adev_open(name=audio_hw_if)
01-01 00:00:27.526   254   359 I r_submix: adev_init_check()
01-01 00:00:27.526   254   254 W DeviceHAL: Device 0xaf9b3cc0 set_master_mute: Function not implemented
01-01 00:00:27.527   270   270 I AudioFlinger: loadHwModule() Loaded r_submix audio interface, handle 26
01-01 00:00:27.527   254   359 D r_submix: adev_open_input_stream(addr=0)
01-01 00:00:27.527   254   359 D r_submix: submix_audio_device_create_pipe_l(addr=0, idx=9)
01-01 00:00:27.527   254   359 D r_submix:   now using address 0 for route 9
01-01 00:00:27.537   270   370 I AudioFlinger: AudioFlinger's thread 0xb1c1b480 tid=370 ready to run
01-01 00:00:27.537   270   270 W APM_AudioPolicyManager: Output device 00000002 unreachable
01-01 00:00:27.537   270   270 W APM_AudioPolicyManager: Input device 80000004 unreachable
01-01 00:00:27.537   270   270 E APM_AudioPolicyManager: Default device 00000002 is unreachable
01-01 00:00:27.537   270   270 E APM_AudioPolicyManager: Failed to open primary output
01-01 00:00:27.545   270   270 I RadioService: RadioService
01-01 00:00:27.545   270   270 I RadioService: onFirstRef
01-01 00:00:27.547   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.broadcastradio@1.0::IBroadcastRadioFactory/default in either framework or device manifest.
01-01 00:00:27.549   270   270 E RadioService: could not read implementation properties
01-01 00:00:27.550   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.soundtrigger@2.0::ISoundTriggerHw/default in either framework or device manifest.
01-01 00:00:27.552   270   270 E SoundTriggerHwService: could not read implementation properties
01-01 00:00:27.553   254   254 D r_submix: adev_close_input_stream()
01-01 00:00:27.553   254   254 D r_submix: submix_audio_device_release_pipe_l(idx=9) addr=0
01-01 00:00:27.553   254   254 D r_submix: submix_audio_device_destroy_pipe_l(): pipe destroyed
01-01 00:00:28.703   366   372 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/egl/libEGL_VIVANTE.so from the current namespace instead.
01-01 00:00:28.710   366   372 D libEGL  : loaded /vendor/lib/egl/libEGL_VIVANTE.so
01-01 00:00:28.733   366   372 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/egl/libGLESv1_CM_VIVANTE.so from the current namespace instead.
01-01 00:00:28.734   366   372 D libEGL  : loaded /vendor/lib/egl/libGLESv1_CM_VIVANTE.so
01-01 00:00:28.907   366   372 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/egl/libGLESv2_VIVANTE.so from the current namespace instead.
01-01 00:00:28.908   366   372 D libEGL  : loaded /vendor/lib/egl/libGLESv2_VIVANTE.so
01-01 00:00:29.144   366   372 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/gralloc.imx6.so from the current namespace instead.
01-01 00:00:29.151   234   234 E SELinux : avc:  denied  { find } for interface=android.hardware.configstore::ISurfaceFlingerConfigs pid=366 scontext=u:r:bootanim:s0 tcontext=u:object_r:hal_configstore_ISurfaceFlingerConfigs:s0 tclass=hwservice_manager permissive=0
01-01 00:00:29.156   234   234 E SELinux : avc:  denied  { find } for interface=android.hardware.configstore::ISurfaceFlingerConfigs pid=366 scontext=u:r:bootanim:s0 tcontext=u:object_r:hal_configstore_ISurfaceFlingerConfigs:s0 tclass=hwservice_manager permissive=0
01-01 00:00:29.157   366   372 I /system/bin/bootanimation: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0 (default)
01-01 00:00:29.170   366   372 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/android.hardware.graphics.mapper@2.0-impl.so from the current namespace instead.
01-01 00:00:29.173   366   372 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/gralloc.imx6.so from the current namespace instead.
01-01 00:00:29.207   366   372 D BootAnimation: BootAnimationShownTiming start time: 19200ms
01-01 00:00:31.132   251   251 I SamplingProfilerIntegration: Profiling disabled.
01-01 00:00:31.141   251   251 D Zygote  : begin preload
01-01 00:00:31.150   251   251 I Zygote  : Installing ICU cache reference pinning...
01-01 00:00:31.150   251   251 I Zygote  : Preloading ICU data...
01-01 00:00:31.473   251   251 D Zygote32Timing: BeginIcuCachePinning took to complete: 323ms
01-01 00:00:31.474   251   251 I Zygote  : Preloading classes...
01-01 00:00:31.501   251   251 W Zygote  : Class not found for preloading: android.app.-$Lambda$FilBqgnXJrN9Mgyks1XHeAxzSTk
01-01 00:00:31.509   251   251 W Zygote  : Class not found for preloading: android.app.-$Lambda$c44uHH2WE4sJvw5tZZB6gRzEaHI$1
01-01 00:00:31.620   251   251 W Zygote  : Class not found for preloading: android.graphics.-$Lambda$ZrP-zejiEXAqfwV-MyP5lE9mYC8$4
01-01 00:00:31.620   251   251 W Zygote  : Class not found for preloading: android.graphics.-$Lambda$ZrP-zejiEXAqfwV-MyP5lE9mYC8$6
01-01 00:00:31.620   251   251 W Zygote  : Class not found for preloading: android.graphics.-$Lambda$ZrP-zejiEXAqfwV-MyP5lE9mYC8$7
01-01 00:00:31.621   251   251 W Zygote  : Class not found for preloading: android.graphics.-$Lambda$ZrP-zejiEXAqfwV-MyP5lE9mYC8$8
01-01 00:00:33.330   251   251 E ActivityRecognitionHardware: activity_recognition HAL is deprecated. class_init is effectively a no-op
01-01 00:00:33.498   251   251 I zygote  : Thread[1,tid=251,Native,Thread*=0xa4d84000,peer=0x12c01cf0,"main"] recursive attempt to load library "/system/lib/libmedia_jni.so"
01-01 00:00:33.503   251   251 D MtpDeviceJNI: register_android_mtp_MtpDevice
01-01 00:00:33.504   251   251 I zygote  : Thread[1,tid=251,Native,Thread*=0xa4d84000,peer=0x12c01cf0,"main"] recursive attempt to load library "/system/lib/libmedia_jni.so"
01-01 00:00:33.636   251   251 W Zygote  : Class not found for preloading: android.os.-$Lambda$6x30vPJhBKUfNY8tswxuZo3DCe0
01-01 00:00:33.648   251   251 W Zygote  : Class not found for preloading: android.os.Trace$1
01-01 00:00:33.664   251   251 W Zygote  : Class not found for preloading: android.provider.-$Lambda$87WmhkvObehVg0OMBzwa_MTVV8g
01-01 00:00:33.707   251   251 W Zygote  : Class not found for preloading: android.view.-$Lambda$6k_RnLLpNi5zg27ubDxN4lDdBbk$2
01-01 00:00:33.707   251   251 W Zygote  : Class not found for preloading: android.view.-$Lambda$6k_RnLLpNi5zg27ubDxN4lDdBbk$3
01-01 00:00:33.708   251   251 W Zygote  : Class not found for preloading: android.view.-$Lambda$iU_USrtPm1XIm5H9QYQvXfBGDE4$1
01-01 00:00:33.914   251   251 W Zygote  : Class not found for preloading: java.lang.-$Lambda$S9HjrJh0nDg7IyU6wZdPArnZWRQ$1
01-01 00:00:33.916   251   251 W Zygote  : Class not found for preloading: java.lang.JavaLangAccess
01-01 00:00:33.940   251   251 W Zygote  : Class not found for preloading: java.util.-$Lambda$4EqhxufgNKat19m0CB0-toH_lzo$1
01-01 00:00:33.940   251   251 W Zygote  : Class not found for preloading: java.util.-$Lambda$4EqhxufgNKat19m0CB0-toH_lzo$2
01-01 00:00:33.940   251   251 W Zygote  : Class not found for preloading: java.util.-$Lambda$4EqhxufgNKat19m0CB0-toH_lzo$3
01-01 00:00:33.941   251   251 W Zygote  : Class not found for preloading: java.util.-$Lambda$4EqhxufgNKat19m0CB0-toH_lzo$4
01-01 00:00:33.941   251   251 W Zygote  : Class not found for preloading: java.util.-$Lambda$4EqhxufgNKat19m0CB0-toH_lzo$5
01-01 00:00:33.942   251   251 W Zygote  : Class not found for preloading: java.util.-$Lambda$aUGKT4ItCOku5-JSG-x8Aqj2pJw$1
01-01 00:00:33.942   251   251 W Zygote  : Class not found for preloading: java.util.-$Lambda$aUGKT4ItCOku5-JSG-x8Aqj2pJw$2
01-01 00:00:33.942   251   251 W Zygote  : Class not found for preloading: java.util.-$Lambda$aUGKT4ItCOku5-JSG-x8Aqj2pJw$3
01-01 00:00:34.082   251   251 I Zygote  : ...preloaded 4548 classes in 2609ms.
01-01 00:00:34.082   251   251 I zygote  : VMRuntime.preloadDexCaches starting
01-01 00:00:34.345   251   251 I zygote  : VMRuntime.preloadDexCaches strings total=309918 before=2958 after=2958
01-01 00:00:34.345   251   251 I zygote  : VMRuntime.preloadDexCaches types total=26330 before=2599 after=3319
01-01 00:00:34.345   251   251 I zygote  : VMRuntime.preloadDexCaches fields total=125675 before=2110 after=1218
01-01 00:00:34.345   251   251 I zygote  : VMRuntime.preloadDexCaches methods total=222889 before=88049 after=88131
01-01 00:00:34.345   251   251 I zygote  : VMRuntime.preloadDexCaches finished
01-01 00:00:34.346   251   251 D Zygote32Timing: PreloadClasses took to complete: 2872ms
01-01 00:00:35.137   251   251 I Zygote  : Preloading resources...
01-01 00:00:35.232   251   251 W Resources: Preloaded drawable resource #0x1080264 (android:drawable/dialog_background_material) that varies with configuration!!
01-01 00:00:35.254   251   251 W Resources: Preloaded color resource #0x10600de (android:color/material_grey_800) that varies with configuration!!
01-01 00:00:35.254   251   251 W Resources: Preloaded drawable resource #0x10802d1 (android:drawable/floating_popup_background_dark) that varies with configuration!!
01-01 00:00:35.439   251   251 I Zygote  : ...preloaded 116 resources in 302ms.
01-01 00:00:35.449   251   251 W Resources: Preloaded color resource #0x1060036 (android:color/background_cache_hint_selector_material_dark) that varies with configuration!!
01-01 00:00:35.450   251   251 W Resources: Preloaded color resource #0x1060053 (android:color/btn_default_material_dark) that varies with configuration!!
01-01 00:00:35.453   251   251 I Zygote  : ...preloaded 41 resources in 15ms.
01-01 00:00:35.453   251   251 D Zygote32Timing: PreloadResources took to complete: 1108ms
01-01 00:00:35.454   251   251 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/android.hardware.graphics.mapper@2.0-impl.so from the current namespace instead.
01-01 00:00:35.457   251   251 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/egl/libEGL_VIVANTE.so from the current namespace instead.
01-01 00:00:35.462   251   251 D libEGL  : loaded /vendor/lib/egl/libEGL_VIVANTE.so
01-01 00:00:35.482   251   251 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/egl/libGLESv1_CM_VIVANTE.so from the current namespace instead.
01-01 00:00:35.483   251   251 D libEGL  : loaded /vendor/lib/egl/libGLESv1_CM_VIVANTE.so
01-01 00:00:35.633   251   251 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/egl/libGLESv2_VIVANTE.so from the current namespace instead.
01-01 00:00:35.635   251   251 D libEGL  : loaded /vendor/lib/egl/libGLESv2_VIVANTE.so
01-01 00:00:35.754   251   251 I Zygote  : Preloading shared libraries...
01-01 00:00:35.821   251   251 I Zygote  : Uninstalled ICU cache reference pinning...
01-01 00:00:35.851   251   251 I Zygote  : Installed AndroidKeyStoreProvider in 30ms.
01-01 00:00:35.879   251   251 I Zygote  : Warmed up JCA providers in 28ms.
01-01 00:00:35.879   251   251 D Zygote  : end preload
01-01 00:00:35.879   251   251 D Zygote32Timing: ZygotePreload took to complete: 4738ms
01-01 00:00:35.930   251   251 I zygote  : Explicit concurrent copying GC freed 30416(1671KB) AllocSpace objects, 4(104KB) LOS objects, 60% free, 1010KB/2MB, paused 131us total 49.620ms
01-01 00:00:35.986   251   251 I zygote  : Explicit concurrent copying GC freed 6147(223KB) AllocSpace objects, 0(0B) LOS objects, 65% free, 818KB/2MB, paused 184us total 30.517ms
01-01 00:00:35.986   251   251 D Zygote32Timing: PostZygoteInitGC took to complete: 106ms
01-01 00:00:35.986   251   251 D Zygote32Timing: ZygoteInit took to complete: 4854ms
01-01 00:00:36.018   251   251 I zygote  : Global filter of size 170 installed
01-01 00:00:36.114   251   251 I Zygote  : System server process 379 has been created
01-01 00:00:36.118   251   251 I Zygote  : Accepting command socket connections
01-01 00:00:36.469   379   379 I SystemServer: InitBeforeStartServices
01-01 00:00:36.469   379   379 W SystemServer: System clock is before 1970; setting to 1970.
01-01 00:00:36.471   379   379 W SystemServer: Timezone not set; setting to GMT.
01-01 00:00:36.479   379   379 I SystemServer: Entered the Android system server!
01-01 00:00:37.533   379   379 D SystemServerTiming: InitBeforeStartServices took to complete: 1063ms
01-01 00:00:37.533   379   379 I SystemServer: StartServices
01-01 00:00:37.533   379   379 I SystemServer: Reading configuration...
01-01 00:00:37.533   379   379 I SystemServer: ReadingSystemConfig
01-01 00:00:37.535   379   379 D SystemServerTiming: ReadingSystemConfig took to complete: 1ms
01-01 00:00:37.535   379   379 I SystemServer: StartInstaller
01-01 00:00:37.543   379   379 I SystemServiceManager: Starting com.android.server.pm.Installer
01-01 00:00:37.545   379   392 D SystemServerInitThreadPool: Started executing ReadingSystemConfig
01-01 00:00:37.564   273   273 D installd: Found quota mount /dev/block/by-name/userdata at /data
01-01 00:00:37.565   379   379 D SystemServerTiming: StartInstaller took to complete: 30ms
01-01 00:00:37.565   379   379 I SystemServer: DeviceIdentifiersPolicyService
01-01 00:00:37.572   379   379 I SystemServiceManager: Starting com.android.server.os.DeviceIdentifiersPolicyService
01-01 00:00:37.575   379   379 D SystemServerTiming: DeviceIdentifiersPolicyService took to complete: 9ms
01-01 00:00:37.575   379   379 I SystemServer: StartActivityManager
01-01 00:00:37.583   379   379 I SystemServiceManager: Starting com.android.server.am.ActivityManagerService$Lifecycle
01-01 00:00:37.666   379   392 D SystemServerInitThreadPool: Finished executing ReadingSystemConfig
01-01 00:00:37.777   379   379 I ActivityManager: Memory class: 128
01-01 00:00:37.779   379   394 I ServiceThread: Enabled StrictMode logging for ActivityManager looper.
01-01 00:00:37.782   379   395 I ServiceThread: Enabled StrictMode logging for android.ui looper.
01-01 00:00:37.900   379   379 D BatteryStatsImpl: Reading daily items from /data/system/batterystats-daily.xml
01-01 00:00:38.166   379   379 I AppOps  : No existing app ops /data/system/appops.xml; starting empty
01-01 00:00:38.242   379   379 I IntentFirewall: Read new rules (A:0 B:0 S:0)
01-01 00:00:38.259   379   401 I ServiceThread: Enabled StrictMode logging for android.display looper.
01-01 00:00:38.260   379   379 W zygote  : Failed to remove /acct/uid_1040/pid_277: Device or resource busy
01-01 00:00:38.260   379   379 W zygote  : Failed to remove /acct/uid_1040: Permission denied
01-01 00:00:38.261   379   379 W zygote  : Failed to remove /acct/uid_1002/pid_255: Device or resource busy
01-01 00:00:38.261   379   379 W zygote  : Failed to remove /acct/uid_1002: Permission denied
01-01 00:00:38.261   379   379 W zygote  : Failed to remove /acct/uid_1010/pid_264: Device or resource busy
01-01 00:00:38.261   379   379 W zygote  : Failed to remove /acct/uid_1010/pid_281: Device or resource busy
01-01 00:00:38.261   379   379 W zygote  : Failed to remove /acct/uid_1010: Permission denied
01-01 00:00:38.262   379   379 W zygote  : Failed to remove /acct/uid_1000/pid_258: Device or resource busy
01-01 00:00:38.262   379   379 W zygote  : Failed to remove /acct/uid_1000/pid_234: Device or resource busy
01-01 00:00:38.263   379   379 W zygote  : Failed to remove /acct/uid_1000/pid_262: Device or resource busy
01-01 00:00:38.264   379   379 W zygote  : Failed to remove /acct/uid_1000/pid_260: Device or resource busy
01-01 00:00:38.264   379   379 W zygote  : Failed to remove /acct/uid_1000/pid_259: Device or resource busy
01-01 00:00:38.264   379   379 W zygote  : Failed to remove /acct/uid_1000/pid_267: Device or resource busy
01-01 00:00:38.264   379   379 W zygote  : Failed to remove /acct/uid_1000/pid_257: Device or resource busy
01-01 00:00:38.265   379   379 W zygote  : Failed to remove /acct/uid_1000/pid_285: Device or resource busy
01-01 00:00:38.265   379   379 W zygote  : Failed to remove /acct/uid_1000/pid_235: Device or resource busy
01-01 00:00:38.265   379   379 W zygote  : Failed to remove /acct/uid_1000/pid_263: Device or resource busy
01-01 00:00:38.265   379   379 W zygote  : Failed to remove /acct/uid_1000/pid_253: Device or resource busy
01-01 00:00:38.265   379   379 W zygote  : Failed to remove /acct/uid_1000/pid_233: Device or resource busy
01-01 00:00:38.266   379   379 W zygote  : Failed to remove /acct/uid_1000/pid_261: Device or resource busy
01-01 00:00:38.266   379   379 W zygote  : Failed to remove /acct/uid_1000: Permission denied
01-01 00:00:38.266   379   379 W zygote  : Failed to remove /acct/uid_1019/pid_272: Device or resource busy
01-01 00:00:38.266   379   379 W zygote  : Failed to remove /acct/uid_1019: Permission denied
01-01 00:00:38.266   379   379 W zygote  : Failed to remove /acct/uid_1047/pid_256: Device or resource busy
01-01 00:00:38.266   379   379 W zygote  : Failed to remove /acct/uid_1047/pid_271: Device or resource busy
01-01 00:00:38.266   379   379 W zygote  : Failed to remove /acct/uid_1047: Permission denied
01-01 00:00:38.267   379   379 W zygote  : Failed to remove /acct/uid_1017/pid_274: Device or resource busy
01-01 00:00:38.267   379   379 W zygote  : Failed to remove /acct/uid_1017: Permission denied
01-01 00:00:38.267   379   379 W zygote  : Failed to remove /acct/uid_1013/pid_278: Device or resource busy
01-01 00:00:38.267   379   379 W zygote  : Failed to remove /acct/uid_1013/pid_279: Device or resource busy
01-01 00:00:38.267   379   379 W zygote  : Failed to remove /acct/uid_1013/pid_275: Device or resource busy
01-01 00:00:38.267   379   379 W zygote  : Failed to remove /acct/uid_1013: Permission denied
01-01 00:00:38.268   379   379 W zygote  : Failed to remove /acct/uid_1041/pid_254: Device or resource busy
01-01 00:00:38.268   379   379 W zygote  : Failed to remove /acct/uid_1041/pid_270: Device or resource busy
01-01 00:00:38.268   379   379 W zygote  : Failed to remove /acct/uid_1041: Permission denied
01-01 00:00:38.268   379   379 W zygote  : Failed to remove /acct/uid_1003/pid_366: Device or resource busy
01-01 00:00:38.268   379   379 W zygote  : Failed to remove /acct/uid_1003: Permission denied
01-01 00:00:38.268   379   379 W zygote  : Failed to remove /acct/uid_1001/pid_283: Device or resource busy
01-01 00:00:38.268   379   379 W zygote  : Failed to remove /acct/uid_1001: Permission denied
01-01 00:00:38.269   379   379 W zygote  : Failed to remove /acct/uid_1058/pid_288: Device or resource busy
01-01 00:00:38.269   379   379 W zygote  : Failed to remove /acct/uid_1058: Permission denied
01-01 00:00:38.269   379   379 W zygote  : Failed to remove /acct/uid_1046/pid_282: Device or resource busy
01-01 00:00:38.269   379   379 W zygote  : Failed to remove /acct/uid_1046: Permission denied
01-01 00:00:38.269   379   379 W zygote  : Failed to remove /acct/uid_1036/pid_232: Device or resource busy
01-01 00:00:38.269   379   379 W zygote  : Failed to remove /acct/uid_1036: Permission denied
01-01 00:00:38.270   379   379 W zygote  : Failed to remove /acct/uid_2000/pid_268: Device or resource busy
01-01 00:00:38.270   379   379 W zygote  : Failed to remove /acct/uid_2000: Permission denied
01-01 00:00:38.270   379   379 W zygote  : Failed to remove /acct/uid_0/pid_266: Device or resource busy
01-01 00:00:38.270   379   379 W zygote  : Failed to remove /acct/uid_0/pid_244: Device or resource busy
01-01 00:00:38.270   379   379 W zygote  : Failed to remove /acct/uid_0/pid_280: Device or resource busy
01-01 00:00:38.270   379   379 W zygote  : Failed to remove /acct/uid_0/pid_250: Device or resource busy
01-01 00:00:38.270   379   379 W zygote  : Failed to remove /acct/uid_0/pid_269: Device or resource busy
01-01 00:00:38.270   379   379 W zygote  : Failed to remove /acct/uid_0/pid_200: Device or resource busy
01-01 00:00:38.271   379   379 W zygote  : Failed to remove /acct/uid_0/pid_265: Device or resource busy
01-01 00:00:38.271   379   379 W zygote  : Failed to remove /acct/uid_0/pid_273: Device or resource busy
01-01 00:00:38.271   379   379 W zygote  : Failed to remove /acct/uid_0/pid_251: Device or resource busy
01-01 00:00:38.271   379   379 W zygote  : Failed to remove /acct/uid_0: Permission denied
01-01 00:00:38.287   379   379 D AppOps  : AppOpsService published
01-01 00:00:38.288   379   379 D SystemServerTiming: StartActivityManager took to complete: 714ms
01-01 00:00:38.288   379   379 I SystemServer: StartPowerManager
01-01 00:00:38.288   379   379 I SystemServiceManager: Starting com.android.server.power.PowerManagerService
01-01 00:00:38.300   379   403 I ServiceThread: Enabled StrictMode logging for PowerManagerService looper.
01-01 00:00:38.307   379   379 I PowerManagerService-JNI: Loaded power HAL service
01-01 00:00:38.308   379   379 I libsuspend: Selected wakeup count
01-01 00:00:38.313   379   379 D SystemServerTiming: StartPowerManager took to complete: 24ms
01-01 00:00:38.313   379   379 I SystemServer: InitPowerManagement
01-01 00:00:38.346   379   379 D SystemServerTiming: InitPowerManagement took to complete: 34ms
01-01 00:00:38.347   379   379 I SystemServer: StartRecoverySystemService
01-01 00:00:38.348   379   379 I SystemServiceManager: Starting com.android.server.RecoverySystemService
01-01 00:00:38.359   379   379 D SystemServerTiming: StartRecoverySystemService took to complete: 12ms
01-01 00:00:38.362   379   379 W RescueParty: Noticed 1 events for UID 0 in last 28 sec
01-01 00:00:38.362   379   379 I SystemServer: StartLightsService
01-01 00:00:38.362   379   379 I SystemServiceManager: Starting com.android.server.lights.LightsService
01-01 00:00:38.377   379   379 D SystemServerTiming: StartLightsService took to complete: 14ms
01-01 00:00:38.377   379   379 I SystemServer: StartDisplayManager
01-01 00:00:38.387   379   379 I SystemServiceManager: Starting com.android.server.display.DisplayManagerService
01-01 00:00:38.407   379   379 D SystemServerTiming: StartDisplayManager took to complete: 29ms
01-01 00:00:38.407   379   379 I SystemServer: WaitForDisplay
01-01 00:00:38.408   379   379 I SystemServiceManager: Starting phase 100
01-01 00:00:38.438   379   401 I DisplayManagerService: Display device added: DisplayDeviceInfo{"Built-in Screen": uniqueId="local:0", 800 x 480, modeId 1, defaultModeId 1, supportedModes [{id=1, width=800, height=480, fps=112.04201}], colorMode 0, supportedColorModes [0], HdrCapabilities android.view.Display$HdrCapabilities@1d6308, density 160, 160.0 x 160.421 dpi, appVsyncOff 1000000, presDeadline 8925224, touch INTERNAL, rotation 0, type BUILT_IN, state UNKNOWN, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
01-01 00:00:38.447   267   267 D SurfaceFlinger: Set power mode=2, type=0 flinger=0xa87d1000
01-01 00:00:38.452   379   379 D SystemServerTiming: WaitForDisplay took to complete: 44ms
01-01 00:00:38.453   379   379 I SystemServer: StartPackageManagerService
01-01 00:00:38.453   379   401 I DisplayManagerService: Display device changed state: "Built-in Screen", ON
01-01 00:00:38.607   379   379 W FileUtils: Failed to chmod(/data/system/packages.list): android.system.ErrnoException: chmod failed: ENOENT (No such file or directory)
01-01 00:00:38.705   379   379 D SELinuxMMAC: Using policy file /system/etc/selinux/plat_mac_permissions.xml
01-01 00:00:38.709   379   379 D SELinuxMMAC: Using policy file /vendor/etc/selinux/nonplat_mac_permissions.xml
01-01 00:00:38.740   379   379 I PackageManager: No settings file; creating initial state
01-01 00:00:38.804   379   379 I PackageManager: /vendor/overlay/SysuiDarkTheme changed; collecting certs
01-01 00:00:38.828   379   379 W PackageManager: Failed to parse /system/framework/arm: Missing base APK in /system/framework/arm
01-01 00:00:38.830   379   379 W PackageManager: Failed to parse /system/framework/oat: Missing base APK in /system/framework/oat
01-01 00:00:38.992   379   379 I PackageManager: /system/framework/framework-res.apk changed; collecting certs
01-01 00:00:41.013   379   379 E PackageManager: Adding duplicate shared id: 1000 name=android
01-01 00:00:41.069   379   379 I PackageManager: /system/priv-app/BlockedNumberProvider changed; collecting certs
01-01 00:00:41.079   379   379 I PackageManager: New shared user android.uid.shared: id=10001
01-01 00:00:41.079   379   379 E PackageManager: Adding duplicate user id: 10001 name=com.android.providers.blockednumber
01-01 00:00:41.098   379   379 I PackageManager: /system/priv-app/CalendarProvider changed; collecting certs
01-01 00:00:41.131   379   379 I PackageManager: New shared user android.uid.calendar: id=10002
01-01 00:00:41.131   379   379 E PackageManager: Adding duplicate user id: 10002 name=com.android.providers.calendar
01-01 00:00:41.134   379   379 I PackageManager: /system/priv-app/CallLogBackup changed; collecting certs
01-01 00:00:41.142   379   379 E PackageManager: Adding duplicate user id: 10001 name=com.android.calllogbackup
01-01 00:00:41.147   379   379 I PackageManager: /system/priv-app/BackupRestoreConfirmation changed; collecting certs
01-01 00:00:41.194   379   379 I PackageManager: /system/priv-app/CarrierConfig changed; collecting certs
01-01 00:00:41.232   379   379 I PackageManager: /system/priv-app/CtsShimPrivPrebuilt changed; collecting certs
01-01 00:00:41.261   379   379 I PackageManager: /system/priv-app/ContactsProvider changed; collecting certs
01-01 00:00:41.288   379   379 E PackageManager: Adding duplicate user id: 10001 name=com.android.providers.contacts
01-01 00:00:41.296   379   379 I PackageManager: /system/priv-app/DefaultContainerService changed; collecting certs
01-01 00:00:41.360   379   415 W PackageParser: No actions in intent filter at /system/priv-app/Contacts/Contacts.apk Binary XML file line #443
01-01 00:00:41.373   379   379 I PackageManager: /system/priv-app/Contacts changed; collecting certs
01-01 00:00:41.605   379   389 I zygote  : Background concurrent copying GC freed 8235(704KB) AllocSpace objects, 10(412KB) LOS objects, 55% free, 1226KB/2MB, paused 170us total 154.949ms
01-01 00:00:41.981   379   379 I PackageManager: /system/priv-app/DocumentsUI changed; collecting certs
01-01 00:00:42.069   379   379 I PackageManager: /system/priv-app/CellBroadcastReceiver changed; collecting certs
01-01 00:00:42.395   379   379 I PackageManager: /system/priv-app/DownloadProvider changed; collecting certs
01-01 00:00:42.428   379   379 I PackageManager: New shared user android.media: id=10010
01-01 00:00:42.428   379   379 E PackageManager: Adding duplicate user id: 10010 name=com.android.providers.downloads
01-01 00:00:42.435   379   379 I PackageManager: /system/priv-app/ExtServices changed; collecting certs
01-01 00:00:42.444   379   379 I PackageManager: /system/priv-app/ExternalStorageProvider changed; collecting certs
01-01 00:00:42.454   379   379 I PackageManager: /system/priv-app/FusedLocation changed; collecting certs
01-01 00:00:42.463   379   379 E PackageManager: Adding duplicate shared id: 1000 name=com.android.location.fused
01-01 00:00:42.467   379   379 I PackageManager: /system/priv-app/InputDevices changed; collecting certs
01-01 00:00:42.491   379   379 E PackageManager: Adding duplicate shared id: 1000 name=com.android.inputdevices
01-01 00:00:42.496   379   379 I PackageManager: /system/priv-app/Launcher3 changed; collecting certs
01-01 00:00:42.609   379   379 I PackageManager: /system/priv-app/ManagedProvisioning changed; collecting certs
01-01 00:00:42.646   379   412 W PackageParser: Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.INSTALL_GRANT_RUNTIME_PERMISSIONS in package: com.android.shell at: Binary XML file line #105
01-01 00:00:42.723   379   379 I PackageManager: /system/priv-app/MediaProvider changed; collecting certs
01-01 00:00:42.745   379   379 E PackageManager: Adding duplicate user id: 10010 name=com.android.providers.media
01-01 00:00:42.752   379   379 I PackageManager: /system/priv-app/EmergencyInfo changed; collecting certs
01-01 00:00:43.003   379   379 I PackageManager: New shared user com.android.emergency.uid: id=10015
01-01 00:00:43.003   379   379 E PackageManager: Adding duplicate user id: 10015 name=com.android.emergency
01-01 00:00:43.009   379   379 I PackageManager: /system/priv-app/MmsService changed; collecting certs
01-01 00:00:43.020   379   379 E PackageManager: Adding duplicate shared id: 1001 name=com.android.mms.service
01-01 00:00:43.025   379   379 I PackageManager: /system/priv-app/MtpDocumentsProvider changed; collecting certs
01-01 00:00:43.042   379   379 E PackageManager: Adding duplicate user id: 10010 name=com.android.mtp
01-01 00:00:43.048   379   379 I PackageManager: /system/priv-app/Dialer changed; collecting certs
01-01 00:00:43.512   379   412 W PackageParser: Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.CONFIGURE_WIFI_DISPLAY in package: com.android.systemui at: Binary XML file line #130
01-01 00:00:43.882   379   379 I PackageManager: /system/priv-app/MusicFX changed; collecting certs
01-01 00:00:43.895   379   379 I PackageManager: /system/priv-app/OneTimeInitializer changed; collecting certs
01-01 00:00:43.908   379   379 I PackageManager: /system/priv-app/Provision changed; collecting certs
01-01 00:00:43.919   379   379 I PackageManager: /system/priv-app/ProxyHandler changed; collecting certs
01-01 00:00:43.928   379   379 I PackageManager: /system/priv-app/SettingsProvider changed; collecting certs
01-01 00:00:43.962   379   379 E PackageManager: Adding duplicate shared id: 1000 name=com.android.providers.settings
01-01 00:00:43.967   379   379 I PackageManager: /system/priv-app/SharedStorageBackup changed; collecting certs
01-01 00:00:43.975   379   379 I PackageManager: /system/priv-app/PackageInstaller changed; collecting certs
01-01 00:00:44.309   379   379 I PackageManager: /system/priv-app/Shell changed; collecting certs
01-01 00:00:44.322   379   379 E PackageManager: Adding duplicate shared id: 2000 name=com.android.shell
01-01 00:00:44.326   379   379 I PackageManager: /system/priv-app/StatementService changed; collecting certs
01-01 00:00:44.334   379   379 I PackageManager: /system/priv-app/StorageManager changed; collecting certs
01-01 00:00:44.555   379   379 I PackageManager: /system/priv-app/Telecom changed; collecting certs
01-01 00:00:44.762   379   379 E PackageManager: Adding duplicate shared id: 1000 name=com.android.server.telecom
01-01 00:00:44.766   379   379 I PackageManager: /system/priv-app/TeleService changed; collecting certs
01-01 00:00:45.162   379   379 E PackageManager: Adding duplicate shared id: 1001 name=com.android.phone
01-01 00:00:45.167   379   379 I PackageManager: /system/priv-app/SystemUI changed; collecting certs
01-01 00:00:45.751   379   379 I PackageManager: New shared user android.uid.systemui: id=10025
01-01 00:00:45.751   379   379 E PackageManager: Adding duplicate user id: 10025 name=com.android.systemui
01-01 00:00:45.757   379   379 I PackageManager: /system/priv-app/TelephonyProvider changed; collecting certs
01-01 00:00:45.768   379   379 E PackageManager: Adding duplicate shared id: 1001 name=com.android.providers.telephony
01-01 00:00:45.772   379   379 I PackageManager: /system/priv-app/VpnDialogs changed; collecting certs
01-01 00:00:45.798   379   379 I PackageManager: /system/priv-app/WallpaperCropper changed; collecting certs
01-01 00:00:45.806   379   379 I PackageManager: /system/priv-app/Settings changed; collecting certs
01-01 00:00:47.630   379   379 E PackageManager: Adding duplicate shared id: 1000 name=com.android.settings
01-01 00:00:47.702   379   379 I PackageManager: /system/app/BluetoothMidiService changed; collecting certs
01-01 00:00:47.728   379   379 I PackageManager: /system/app/BasicDreams changed; collecting certs
01-01 00:00:47.746   379   379 I PackageManager: /system/app/BookmarkProvider changed; collecting certs
01-01 00:00:47.765   379   379 I PackageManager: /system/app/Browser2 changed; collecting certs
01-01 00:00:47.776   379   379 I PackageManager: /system/app/BuiltInPrintService changed; collecting certs
01-01 00:00:47.784   379   417 W PackageParser: Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.READ_CONTACTS in package: com.android.bluetooth at: Binary XML file line #61
01-01 00:00:47.789   379   417 W PackageParser: No actions in intent filter at /system/app/Bluetooth/Bluetooth.apk Binary XML file line #224
01-01 00:00:47.806   379   379 I PackageManager: /system/app/Bluetooth changed; collecting certs
01-01 00:00:47.843   379   417 W PackageParser: No actions in intent filter at /system/app/CarrierDefaultApp/CarrierDefaultApp.apk Binary XML file line #50
01-01 00:00:47.917   379   379 E PackageManager: Adding duplicate shared id: 1002 name=com.android.bluetooth
01-01 00:00:47.932   379   379 I PackageManager: /system/app/CaptivePortalLogin changed; collecting certs
01-01 00:00:47.954   379   379 I PackageManager: /system/app/CarrierDefaultApp changed; collecting certs
01-01 00:00:47.995   379   379 I PackageManager: /system/app/CompanionDeviceManager changed; collecting certs
01-01 00:00:48.004   379   379 I PackageManager: /system/app/CtsShimPrebuilt changed; collecting certs
01-01 00:00:48.021   379   379 I PackageManager: /system/app/CertInstaller changed; collecting certs
01-01 00:00:48.063   379   379 I PackageManager: /system/app/CubeLiveWallpapers changed; collecting certs
01-01 00:00:48.091   379   379 I PackageManager: /system/app/Calendar changed; collecting certs
01-01 00:00:48.304   379   419 W PackageParser: Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.WRITE_CONTACTS in package: com.android.email at: Binary XML file line #40
01-01 00:00:48.330   379   379 I PackageManager: /system/app/EasterEgg changed; collecting certs
01-01 00:00:48.340   379   379 I PackageManager: /system/app/Camera2 changed; collecting certs
01-01 00:00:48.459   379   419 W PackageParser: Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.CHANGE_WIFI_STATE in package: com.android.nfc at: Binary XML file line #47
01-01 00:00:48.459   379   419 W PackageParser: Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.ACCESS_WIFI_STATE in package: com.android.nfc at: Binary XML file line #48
01-01 00:00:48.982   379   379 I PackageManager: /system/app/DownloadProviderUi changed; collecting certs
01-01 00:00:48.999   379   379 E PackageManager: Adding duplicate user id: 10010 name=com.android.providers.downloads.ui
01-01 00:00:49.004   379   379 I PackageManager: /system/app/ExtShared changed; collecting certs
01-01 00:00:49.014   379   379 I PackageManager: /system/app/ExactCalculator changed; collecting certs
01-01 00:00:49.057   379   379 I PackageManager: /system/app/FSLOta changed; collecting certs
01-01 00:00:49.065   379   379 E PackageManager: Adding duplicate shared id: 1000 name=com.fsl.android.ota
01-01 00:00:49.072   379   379 I PackageManager: /system/app/HTMLViewer changed; collecting certs
01-01 00:00:49.104   379   379 I PackageManager: /system/app/KeyChain changed; collecting certs
01-01 00:00:49.118   379   379 E PackageManager: Adding duplicate shared id: 1000 name=com.android.keychain
01-01 00:00:49.129   379   379 I PackageManager: /system/app/DeskClock changed; collecting certs
01-01 00:00:49.155   379   389 I zygote  : Background concurrent copying GC freed 13640(1112KB) AllocSpace objects, 9(248KB) LOS objects, 42% free, 2MB/3MB, paused 168us total 100.540ms
01-01 00:00:49.347   379   379 I PackageManager: /system/app/Gallery2 changed; collecting certs
01-01 00:00:49.727   379   379 I PackageManager: /system/app/Email changed; collecting certs
01-01 00:00:50.032   379   379 I PackageManager: /system/app/LiveWallpapersPicker changed; collecting certs
01-01 00:00:50.089   379   379 I PackageManager: /system/app/PacProcessor changed; collecting certs
01-01 00:00:50.100   379   379 I PackageManager: /system/app/NfcNci changed; collecting certs
01-01 00:00:50.126   379   379 E PackageManager: Adding duplicate shared id: 1027 name=com.android.nfc
01-01 00:00:50.132   379   379 I PackageManager: /system/app/Music changed; collecting certs
01-01 00:00:50.186   379   379 I PackageManager: /system/app/PrintSpooler changed; collecting certs
01-01 00:00:50.221   379   379 I PackageManager: /system/app/PicoTts changed; collecting certs
01-01 00:00:50.231   379   379 I PackageManager: /system/app/PrintRecommendationService changed; collecting certs
01-01 00:00:50.239   379   379 I PackageManager: /system/app/LatinIME changed; collecting certs
01-01 00:00:51.266   379   379 I PackageManager: /system/app/QuickSearchBox changed; collecting certs
01-01 00:00:51.300   379   379 I PackageManager: /system/app/SoundRecorder changed; collecting certs
01-01 00:00:51.316   379   379 I PackageManager: /system/app/UserDictionaryProvider changed; collecting certs
01-01 00:00:51.323   379   379 E PackageManager: Adding duplicate user id: 10001 name=com.android.providers.userdictionary
01-01 00:00:51.326   379   379 I PackageManager: /system/app/WallpaperBackup changed; collecting certs
01-01 00:00:51.333   379   379 E PackageManager: Adding duplicate shared id: 1000 name=com.android.wallpaperbackup
01-01 00:00:51.335   379   379 I PackageManager: /system/app/ethernet changed; collecting certs
01-01 00:00:51.360   379   379 E PackageManager: Adding duplicate shared id: 1000 name=com.fsl.ethernet
01-01 00:00:51.363   379   379 I PackageManager: /system/app/webview changed; collecting certs
01-01 00:00:54.812   379   379 I PackageManager: /vendor/app/CactusPlayer changed; collecting certs
01-01 00:00:54.823   379   379 D PackageManager: No files in app dir /oem/app
01-01 00:00:54.824   379   379 D PackageManager: No files in app dir /data/app
01-01 00:00:54.825   379   379 D PackageManager: No files in app dir /data/app-private
01-01 00:00:54.852   379   379 I PackageManager: Time to scan packages: 16.08 seconds
01-01 00:00:54.882   379   379 V PackageManager: reconcileAppsData for null u0 0x3 migrateAppData=true
01-01 00:00:54.892   273   290 I SELinux : SELinux: Loaded file_contexts
01-01 00:00:54.905   273   290 D installd: Applied hard quotas for 1001
01-01 00:00:54.908   273   273 W installd: Requested default storage /data/user_de/0/com.android.providers.telephony is not active; migrating from /data/data/com.android.providers.telephony
01-01 00:00:54.941   273   273 D installd: Applied hard quotas for 10006
01-01 00:00:54.944   273   290 W installd: Requested default storage /data/user_de/0/com.android.defcontainer is not active; migrating from /data/data/com.android.defcontainer
01-01 00:00:54.962   273   290 D installd: Applied hard quotas for 1000
01-01 00:00:54.964   273   421 W installd: Requested default storage /data/user_de/0/android is not active; migrating from /data/data/android
01-01 00:00:54.987   273   290 W installd: Requested default storage /data/user_de/0/com.android.providers.settings is not active; migrating from /data/data/com.android.providers.settings
01-01 00:00:55.005   273   290 W installd: Requested default storage /data/user_de/0/com.android.inputdevices is not active; migrating from /data/data/com.android.inputdevices
01-01 00:00:55.022   273   290 D installd: Applied hard quotas for 10042
01-01 00:00:55.024   273   421 W installd: Requested default storage /data/user_de/0/android.ext.shared is not active; migrating from /data/data/android.ext.shared
01-01 00:00:55.043   273   290 W installd: Requested default storage /data/user_de/0/com.android.server.telecom is not active; migrating from /data/data/com.android.server.telecom
01-01 00:00:55.065   273   290 D installd: Applied hard quotas for 10016
01-01 00:00:55.081   273   273 D installd: Applied hard quotas for 10011
01-01 00:00:55.083   273   290 W installd: Requested default storage /data/user_de/0/android.ext.services is not active; migrating from /data/data/android.ext.services
01-01 00:00:55.101   273   422 D installd: Applied hard quotas for 10022
01-01 00:00:55.103   273   290 W installd: Requested default storage /data/user_de/0/com.android.packageinstaller is not active; migrating from /data/data/com.android.packageinstaller
01-01 00:00:55.121   273   422 D installd: Applied hard quotas for 10020
01-01 00:00:55.123   273   290 W installd: Requested default storage /data/user_de/0/com.android.proxyhandler is not active; migrating from /data/data/com.android.proxyhandler
01-01 00:00:55.145   273   422 D installd: Applied hard quotas for 10054
01-01 00:00:55.149   273   290 W installd: Requested default storage /data/user_de/0/com.android.inputmethod.latin is not active; migrating from /data/data/com.android.inputmethod.latin
01-01 00:00:55.182   273   422 W installd: Requested default storage /data/user_de/0/com.android.settings is not active; migrating from /data/data/com.android.settings
01-01 00:00:55.200   273   421 D installd: Applied hard quotas for 10058
01-01 00:00:55.218   273   290 W installd: Requested default storage /data/user_de/0/com.android.phone is not active; migrating from /data/data/com.android.phone
01-01 00:00:55.236   273   422 D installd: Applied hard quotas for 2000
01-01 00:00:55.238   273   421 W installd: Requested default storage /data/user_de/0/com.android.shell is not active; migrating from /data/data/com.android.shell
01-01 00:00:55.256   273   422 W installd: Requested default storage /data/user_de/0/com.android.location.fused is not active; migrating from /data/data/com.android.location.fused
01-01 00:00:55.273   273   290 D installd: Applied hard quotas for 10025
01-01 00:00:55.276   273   421 W installd: Requested default storage /data/user_de/0/com.android.systemui is not active; migrating from /data/data/com.android.systemui
01-01 00:00:55.284   379   379 V PackageManager: reconcileAppsData finished 20 packages
01-01 00:00:55.285   379   423 D SystemServerInitThreadPool: Started executing prepareAppData
01-01 00:00:55.288   273   273 W installd: Ignoring /data/data/com.android.inputmethod.latin/lib with unexpected GID 0 instead of 10054
01-01 00:00:55.289   273   273 W installd: Ignoring /data/data/com.android.defcontainer/lib with unexpected GID 0 instead of 10006
01-01 00:00:55.292   273   273 W installd: Ignoring /data/user_de/0/com.android.inputmethod.latin/lib with unexpected GID 0 instead of 10054
01-01 00:00:55.293   273   273 W installd: Ignoring /data/user_de/0/com.android.defcontainer/lib with unexpected GID 0 instead of 10006
01-01 00:00:55.295   379   423 D SystemServerTimingAsync: AppDataFixup took to complete: 10ms
01-01 00:00:55.416   379   379 E PackageManager: There should probably be a verifier, but, none were found
01-01 00:00:55.425   379   379 D PackageManager: Ephemeral resolver not found with new action; try old one
01-01 00:00:55.426   379   379 D PackageManager: Ephemeral resolver NOT found; no matching intent filters
01-01 00:00:55.426   379   379 D PackageManager: Ephemeral installer not found with new action; try old one
01-01 00:00:55.426   379   379 D PackageManager: Clear ephemeral installer activity
01-01 00:00:55.448   273   290 D installd: Applied hard quotas for 10005
01-01 00:00:55.470   273   421 D installd: Applied hard quotas for 10038
01-01 00:00:55.506   273   421 D installd: Applied hard quotas for 10002
01-01 00:00:55.523   379   379 I zygote  : Explicit concurrent copying GC freed 24830(1447KB) AllocSpace objects, 10(196KB) LOS objects, 43% free, 1995KB/3MB, paused 176us total 85.207ms
01-01 00:00:55.525   273   273 D installd: Applied hard quotas for 10010
01-01 00:00:55.526   379   379 D FallbackCategoryProvider: Found 1 fallback categories
01-01 00:00:55.534   379   379 D SystemServerTiming: StartPackageManagerService took to complete: 17081ms
01-01 00:00:55.534   379   379 I SystemServer: StartOtaDexOptService
01-01 00:00:55.537   379   379 D OTADexopt: No upgrade, skipping A/B artifacts check.
01-01 00:00:55.537   379   379 D SystemServerTiming: StartOtaDexOptService took to complete: 2ms
01-01 00:00:55.537   379   379 I SystemServer: StartUserManagerService
01-01 00:00:55.538   379   379 I SystemServiceManager: Starting com.android.server.pm.UserManagerService$LifeCycle
01-01 00:00:55.539   379   379 D SystemServerTiming: StartUserManagerService took to complete: 1ms
01-01 00:00:55.539   379   379 I SystemServer: InitAttributerCache
01-01 00:00:55.540   379   379 D SystemServerTiming: InitAttributerCache took to complete: 0ms
01-01 00:00:55.540   379   379 I SystemServer: SetSystemProcess
01-01 00:00:55.547   273   421 D installd: Applied hard quotas for 10027
01-01 00:00:55.574   273   273 D installd: Applied hard quotas for 10008
01-01 00:00:55.592   273   421 D installd: Applied hard quotas for 10012
01-01 00:00:55.610   266   266 I lowmemorykiller: ActivityManager connected
01-01 00:00:55.612   273   422 D installd: Applied hard quotas for 10044
01-01 00:00:55.613   379   379 D SystemServerTiming: SetSystemProcess took to complete: 74ms
01-01 00:00:55.615   379   425 I ServiceThread: Enabled StrictMode logging for android.anim looper.
01-01 00:00:55.620   379   379 I SystemServer: StartOverlayManagerService
01-01 00:00:55.624   379   379 D SystemServerTiming: StartOverlayManagerService took to complete: 3ms
01-01 00:00:55.627   379   426 D SystemServerInitThreadPool: Started executing Init OverlayManagerService
01-01 00:00:55.629   379   379 I SystemServer: StartDropBoxManager
01-01 00:00:55.630   379   379 I SystemServiceManager: Starting com.android.server.DropBoxManagerService
01-01 00:00:55.639   379   379 D SystemServerTiming: StartDropBoxManager took to complete: 9ms
01-01 00:00:55.639   379   379 I SystemServer: StartBatteryService
01-01 00:00:55.640   379   379 I SystemServiceManager: Starting com.android.server.BatteryService
01-01 00:00:55.640   273   290 D installd: Applied hard quotas for 10035
01-01 00:00:55.643   379   427 D SystemServerInitThreadPool: Started executing StartSensorService
01-01 00:00:55.643   379   427 D SensorService: nuSensorService starting...
01-01 00:00:55.659   262   262 D         : AccelSensor enable 0 , handle 0 ,mEnabled 0
01-01 00:00:55.660   262   428 D         : AccelSensor enable 0 , handle 1 ,mEnabled 0
01-01 00:00:55.660   262   428 D         : MagSensor mEnabled 0, OrientaionSensor mEnabled 0
01-01 00:00:55.662   262   262 D         : AccelSensor enable 0 , handle 2 ,mEnabled 0
01-01 00:00:55.662   262   262 D         : MagSensor mEnabled 0, OrientaionSensor mEnabled 0
01-01 00:00:55.665   379   427 I SensorService: Generated new HMAC key.
01-01 00:00:55.667   379   430 D SensorService: nuSensorService thread starting...
01-01 00:00:55.671   379   427 D SystemServerTimingAsync: StartSensorService took to complete: 28ms
01-01 00:00:55.671   379   427 D SystemServerInitThreadPool: Finished executing StartSensorService
01-01 00:00:55.677   379   429 D SensorService: new thread SensorEventAckReceiver
01-01 00:00:55.689   379   379 D SystemServerTiming: StartBatteryService took to complete: 51ms
01-01 00:00:55.690   379   379 I SystemServer: StartUsageService
01-01 00:00:55.690   273   421 D installd: Applied hard quotas for 10055
01-01 00:00:55.700   379   379 I SystemServiceManager: Starting com.android.server.usage.UsageStatsService
01-01 00:00:55.709   379   390 E LightsService: Light requested not available on this device. 3
01-01 00:00:55.749   379   379 D SystemServerTiming: StartUsageService took to complete: 59ms
01-01 00:00:55.749   379   379 I SystemServer: StartWebViewUpdateService
01-01 00:00:55.759   273   422 D installd: Applied hard quotas for 10056
01-01 00:00:55.762   379   379 I SystemServiceManager: Starting com.android.server.webkit.WebViewUpdateService
01-01 00:00:55.793   379   379 D SystemServerTiming: StartWebViewUpdateService took to complete: 44ms
01-01 00:00:55.795   379   379 I SystemServer: StartKeyAttestationApplicationIdProviderService
01-01 00:00:55.795   379   392 D SystemServerInitThreadPool: Started executing SecondaryZygotePreload
01-01 00:00:55.795   379   392 I SystemServer: SecondaryZygotePreload
01-01 00:00:55.822   379   392 I Zygote  : Process: zygote socket zygote opened, supported ABIS: armeabi-v7a,armeabi
01-01 00:00:55.822   379   379 D SystemServerTiming: StartKeyAttestationApplicationIdProviderService took to complete: 28ms
01-01 00:00:55.822   379   379 I SystemServer: StartKeyChainSystemService
01-01 00:00:55.823   379   379 I SystemServiceManager: Starting com.android.server.security.KeyChainSystemService
01-01 00:00:55.824   379   379 D SystemServerTiming: StartKeyChainSystemService took to complete: 1ms
01-01 00:00:55.824   379   379 I SystemServer: StartSchedulingPolicyService
01-01 00:00:55.827   379   379 D SystemServerTiming: StartSchedulingPolicyService took to complete: 2ms
01-01 00:00:55.827   379   379 I SystemServer: StartTelecomLoaderService
01-01 00:00:55.827   379   379 I SystemServiceManager: Starting com.android.server.telecom.TelecomLoaderService
01-01 00:00:55.828   379   379 D SystemServerTiming: StartTelecomLoaderService took to complete: 2ms
01-01 00:00:55.829   379   379 I SystemServer: StartTelephonyRegistry
01-01 00:00:55.833   379   392 E SystemServer: Unable to preload default resources
01-01 00:00:55.833   379   392 D SystemServerTimingAsync: SecondaryZygotePreload took to complete: 38ms
01-01 00:00:55.833   379   392 D SystemServerInitThreadPool: Finished executing SecondaryZygotePreload
01-01 00:00:55.853   379   379 D SystemServerTiming: StartTelephonyRegistry took to complete: 24ms
01-01 00:00:55.853   379   379 I SystemServer: StartEntropyMixer
01-01 00:00:55.855   379   379 W EntropyMixer: No existing entropy file -- first boot?
01-01 00:00:55.857   379   379 I EntropyMixer: Added HW RNG output to entropy pool
01-01 00:00:55.857   379   379 I EntropyMixer: Writing entropy...
01-01 00:00:55.875   379   379 D SystemServerTiming: StartEntropyMixer took to complete: 22ms
01-01 00:00:55.875   379   379 I SystemServer: StartAccountManagerService
01-01 00:00:55.876   379   379 I SystemServiceManager: Starting com.android.server.accounts.AccountManagerService$Lifecycle
01-01 00:00:55.930   379   379 W SystemServiceManager: Service com.android.server.accounts.AccountManagerService$Lifecycle took 54 ms in onStart
01-01 00:00:55.930   379   379 D SystemServerTiming: StartAccountManagerService took to complete: 54ms
01-01 00:00:55.930   379   379 I SystemServer: StartContentService
01-01 00:00:55.939   379   379 I SystemServiceManager: Starting com.android.server.content.ContentService$Lifecycle
01-01 00:00:55.944   379   379 D SystemServerTiming: StartContentService took to complete: 14ms
01-01 00:00:55.945   379   379 I SystemServer: InstallSystemProviders
01-01 00:00:55.954   431   431 W ResourceType: CREATING STRING CACHE OF 23000 bytes
01-01 00:00:56.045   379   426 D SystemServerInitThreadPool: Finished executing Init OverlayManagerService
01-01 00:00:56.105   273   432 D installd: Applied hard quotas for 10049
01-01 00:00:56.130   273   421 D installd: Applied hard quotas for 10037
01-01 00:00:56.155   273   290 D installd: Applied hard quotas for 10004
01-01 00:00:56.176   273   421 D installd: Applied hard quotas for 10007
01-01 00:00:56.200   273   290 D installd: Applied hard quotas for 10041
01-01 00:00:56.235   379   379 I SettingsState: No settings state /data/system/users/0/settings_system.xml
01-01 00:00:56.244   273   290 D installd: Applied hard quotas for 10040
01-01 00:00:56.248   379   379 I SettingsState: No settings state /data/system/users/0/settings_secure.xml
01-01 00:00:56.252   379   379 D SettingsProvider: Generated and saved new ANDROID_ID [8bb5afa4a69ff1db] for user 0
01-01 00:00:56.278   379   379 I SettingsState: No settings state /data/system/users/0/settings_global.xml
01-01 00:00:56.288   273   290 D installd: Applied hard quotas for 1027
01-01 00:00:56.325   273   422 D installd: Applied hard quotas for 10013
01-01 00:00:56.349   379   379 D SettingsProvider: Setting [] as Autofill Service for user 0
01-01 00:00:56.355   273   421 D installd: Applied hard quotas for 10003
01-01 00:00:56.356   379   379 I SettingsState: No settings state /data/system/users/0/settings_ssaid.xml
01-01 00:00:56.375   379   379 D SystemServerTiming: InstallSystemProviders took to complete: 431ms
01-01 00:00:56.375   379   379 I SystemServer: StartVibratorService
01-01 00:00:56.378   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.vibrator@1.0::IVibrator/default in either framework or device manifest.
01-01 00:00:56.379   273   422 D installd: Applied hard quotas for 10019
01-01 00:00:56.382   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.vibrator@1.0::IVibrator/default in either framework or device manifest.
01-01 00:00:56.389   379   379 E VibratorService: vibratorOff command failed (1).
01-01 00:00:56.390   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.vibrator@1.0::IVibrator/default in either framework or device manifest.
01-01 00:00:56.397   379   379 D SystemServerTiming: StartVibratorService took to complete: 21ms
01-01 00:00:56.397   379   379 I SystemServer: StartConsumerIrService
01-01 00:00:56.400   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.ir@1.0::IConsumerIr/default in either framework or device manifest.
01-01 00:00:56.403   379   379 D SystemServerTiming: StartConsumerIrService took to complete: 7ms
01-01 00:00:56.404   379   379 I SystemServer: StartAlarmManagerService
01-01 00:00:56.404   379   379 I SystemServiceManager: Starting com.android.server.AlarmManagerService
01-01 00:00:56.413   273   432 D installd: Applied hard quotas for 10023
01-01 00:00:56.418   379   379 D AlarmManagerService: Kernel timezone updated to 0 minutes west of GMT
01-01 00:00:56.435   379   379 D SystemServerTiming: StartAlarmManagerService took to complete: 31ms
01-01 00:00:56.435   379   379 I SystemServer: InitWatchdog
01-01 00:00:56.436   379   379 D SystemServerTiming: InitWatchdog took to complete: 1ms
01-01 00:00:56.436   379   379 I SystemServer: StartInputManagerService
01-01 00:00:56.436   273   422 D installd: Applied hard quotas for 10039
01-01 00:00:56.447   379   379 I InputManager: Initializing input manager, mUseDevInputEventForAudioJack=false
01-01 00:00:56.452   379   379 D SystemServerTiming: StartInputManagerService took to complete: 17ms
01-01 00:00:56.452   379   379 I SystemServer: StartWindowManagerService
01-01 00:00:56.456   273   432 D installd: Applied hard quotas for 10000
01-01 00:00:56.475   273   422 D installd: Applied hard quotas for 10021
01-01 00:00:56.498   273   290 D installd: Applied hard quotas for 10051
01-01 00:00:56.522   273   421 D installd: Applied hard quotas for 10029
01-01 00:00:56.544   273   432 D installd: Applied hard quotas for 10057
01-01 00:00:56.569   273   432 D installd: Applied hard quotas for 10032
01-01 00:00:56.590   273   421 D installd: Applied hard quotas for 10017
01-01 00:00:56.620   273   290 D installd: Applied hard quotas for 10009
01-01 00:00:56.623   273   273 W installd: Requested default storage /data/user_de/0/com.android.cellbroadcastreceiver is not active; migrating from /data/data/com.android.cellbroadcastreceiver
01-01 00:00:56.663   273   421 D installd: Applied hard quotas for 10018
01-01 00:00:56.668   379   401 I WindowManager: No existing display settings /data/system/display_settings.xml; starting empty
01-01 00:00:56.709   273   432 D installd: Applied hard quotas for 10053
01-01 00:00:56.742   273   422 D installd: Applied hard quotas for 10046
01-01 00:00:56.772   273   421 D installd: Applied hard quotas for 10001
01-01 00:00:56.791   273   432 D installd: Applied hard quotas for 10034
01-01 00:00:56.814   273   422 D installd: Applied hard quotas for 10052
01-01 00:00:56.833   379   379 D SystemServerTiming: StartWindowManagerService took to complete: 381ms
01-01 00:00:56.834   379   379 I SystemServer: StartVrManagerService
01-01 00:00:56.834   379   379 I SystemServiceManager: Starting com.android.server.vr.VrManagerService
01-01 00:00:56.837   379   427 D SystemServerInitThreadPool: Started executing StartHidlServices
01-01 00:00:56.837   379   427 I SystemServer: StartHidlServices
01-01 00:00:56.838   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.vr@1.0::IVr/default in either framework or device manifest.
01-01 00:00:56.841   273   273 D installd: Applied hard quotas for 10031
01-01 00:00:56.845   379   427 D SystemServerTiming: StartHidlServices took to complete: 8ms
01-01 00:00:56.845   379   427 D SystemServerInitThreadPool: Finished executing StartHidlServices
01-01 00:00:56.851   379   379 W VrManagerService: init_native: Could not open IVr interface
01-01 00:00:56.853   379   379 D SystemServerTiming: StartVrManagerService took to complete: 20ms
01-01 00:00:56.854   379   379 I SystemServer: SetWindowManagerService
01-01 00:00:56.864   273   422 D installd: Applied hard quotas for 10014
01-01 00:00:56.876   379   379 D SystemServerTiming: SetWindowManagerService took to complete: 23ms
01-01 00:00:56.877   379   379 I SystemServer: StartInputManager
01-01 00:00:56.877   379   379 I InputManager: Starting input manager
01-01 00:00:56.884   379   444 E EventHub: could not get driver version for /dev/input/mice, Not a typewriter
01-01 00:00:56.885   273   432 D installd: Applied hard quotas for 10048
01-01 00:00:56.892   379   379 D SystemServerTiming: StartInputManager took to complete: 16ms
01-01 00:00:56.892   379   379 I SystemServer: DisplayManagerWindowManagerAndInputReady
01-01 00:00:56.893   379   379 D SystemServerTiming: DisplayManagerWindowManagerAndInputReady took to complete: 0ms
01-01 00:00:56.893   379   379 I SystemServer: StartBluetoothService
01-01 00:00:56.893   379   379 I SystemServiceManager: Starting com.android.server.BluetoothService
01-01 00:00:56.910   273   421 D installd: Applied hard quotas for 10024
01-01 00:00:56.920   379   379 D BluetoothManagerService: Loading stored name and address
01-01 00:00:56.920   379   379 D BluetoothManagerService: Stored bluetooth Name=null,Address=null
01-01 00:00:56.921   379   379 D BluetoothManagerService: Bluetooth persisted state: 0
01-01 00:00:56.922   379   379 D SystemServerTiming: StartBluetoothService took to complete: 29ms
01-01 00:00:56.922   379   379 I SystemServer: IpConnectivityMetrics
01-01 00:00:56.922   379   379 I SystemServiceManager: Starting com.android.server.connectivity.IpConnectivityMetrics
01-01 00:00:56.931   273   422 D installd: Applied hard quotas for 10030
01-01 00:00:56.950   379   379 D SystemServerTiming: IpConnectivityMetrics took to complete: 28ms
01-01 00:00:56.950   379   379 I SystemServer: PinnerService
01-01 00:00:56.950   379   379 I SystemServiceManager: Starting com.android.server.PinnerService
01-01 00:00:56.963   379   444 I InputReader: Device added: id=-1, name='Virtual', sources=0x00000301
01-01 00:00:56.973   379   379 D SystemServerTiming: PinnerService took to complete: 23ms
01-01 00:00:56.973   273   290 D installd: Applied hard quotas for 10043
01-01 00:00:56.974   379   379 I SystemServer: StartInputMethodManagerLifecycle
01-01 00:00:56.986   379   379 I SystemServiceManager: Starting com.android.server.InputMethodManagerService$Lifecycle
01-01 00:00:56.993   273   421 D installd: Applied hard quotas for 10036
01-01 00:00:57.028   273   422 D installd: Applied hard quotas for 10026
01-01 00:00:57.044   379   379 D SystemServerTiming: StartInputMethodManagerLifecycle took to complete: 71ms
01-01 00:00:57.044   379   379 I SystemServer: StartAccessibilityManagerService
01-01 00:00:57.059   273   421 D installd: Applied hard quotas for 10047
01-01 00:00:57.075   379   379 D SystemServerTiming: StartAccessibilityManagerService took to complete: 30ms
01-01 00:00:57.075   379   379 I SystemServer: MakeDisplayReady
01-01 00:00:57.081   273   422 D installd: Applied hard quotas for 10050
01-01 00:00:57.087   379   379 I ActivityManager: Config changes=5df8 {1.0 ?mcc?mnc [en_US] ldltr sw480dp w800dp h480dp 160dpi lrg long land ?uimode ?night -touch -keyb/h/h -nav/h appBounds=Rect(0, 0 - 800, 480) s.2}
01-01 00:00:57.095   379   393 I UsageStatsDatabase: Upgrading from version 0 to 3
01-01 00:00:57.095   379   393 I UsageStatsDatabase: Deleting all usage stats files
01-01 00:00:57.102   379   393 I UsageStatsService: User[0] Rollover scheduled @ 1970-01-02 00:00:57(86457089)
01-01 00:00:57.102   379   393 D UsageStatsService: Initializing defaults for system apps on user 0
01-01 00:00:57.114   379   389 I zygote  : Background concurrent copying GC freed 7303(856KB) AllocSpace objects, 13(260KB) LOS objects, 42% free, 2MB/4MB, paused 4.267ms total 190.352ms
01-01 00:00:57.116   379   393 E AppIdleHistory: Unable to read app idle file for user 0
01-01 00:00:57.116   379   379 I ActivityManager: Override config changes=40007dfc {1.0 ?mcc?mnc [en_US] ldltr sw480dp w800dp h480dp 160dpi lrg long land ?uimode ?night -touch -keyb/h/h -nav/h appBounds=Rect(0, 0 - 800, 480) s.2} for displayId=0
01-01 00:00:57.135   273   422 W installd: Requested default storage /data/user_de/0/com.android.providers.blockednumber is not active; migrating from /data/data/com.android.providers.blockednumber
01-01 00:00:57.142   379   444 I InputReader: Reconfiguring input devices.  changes=0x00000004
01-01 00:00:57.149   379   444 I chatty  : uid=1000(system) InputReader identical 2 lines
01-01 00:00:57.150   379   379 I ActivityManager: Config changes=500 {1.0 ?mcc?mnc [en_US] ldltr sw480dp w752dp h456dp 160dpi lrg land ?uimode ?night -touch -keyb/h/h -nav/h appBounds=Rect(0, 0 - 752, 480) s.3}
01-01 00:00:57.161   379   379 I ActivityManager: Override config changes=500 {1.0 ?mcc?mnc [en_US] ldltr sw480dp w752dp h456dp 160dpi lrg land ?uimode ?night -touch -keyb/h/h -nav/h appBounds=Rect(0, 0 - 752, 480) s.3} for displayId=0
01-01 00:00:57.187   379   379 D SystemServerTiming: MakeDisplayReady took to complete: 113ms
01-01 00:00:57.187   379   444 I InputReader: Reconfiguring input devices.  changes=0x00000004
01-01 00:00:57.189   379   379 I SystemServer: StartStorageManagerService
01-01 00:00:57.189   273   273 D installd: Applied hard quotas for 10015
01-01 00:00:57.189   379   379 I SystemServiceManager: Starting com.android.server.StorageManagerService$Lifecycle
01-01 00:00:57.192   273   422 W installd: Requested default storage /data/user_de/0/com.android.emergency is not active; migrating from /data/data/com.android.emergency
01-01 00:00:57.214   273   421 D installd: Applied hard quotas for 10045
01-01 00:00:57.219   379   379 D SystemServerTiming: StartStorageManagerService took to complete: 30ms
01-01 00:00:57.219   379   379 I SystemServer: StartStorageStatsService
01-01 00:00:57.220   379   379 I SystemServiceManager: Starting com.android.server.usage.StorageStatsService$Lifecycle
01-01 00:00:57.236   273   432 D installd: Found quota mount /dev/block/by-name/userdata at /data
01-01 00:00:57.236   273   432 E installd: Failed to enable USRQUOTA on /dev/block/by-name/userdata: File exists
01-01 00:00:57.236   273   432 E installd: Failed to enable GRPQUOTA on /dev/block/by-name/userdata: File exists
01-01 00:00:57.238   273   422 D installd: Found quota mount /dev/block/by-name/userdata at /data
01-01 00:00:57.238   273   422 E installd: Failed to enable USRQUOTA on /dev/block/by-name/userdata: File exists
01-01 00:00:57.238   273   422 E installd: Failed to enable GRPQUOTA on /dev/block/by-name/userdata: File exists
01-01 00:00:57.241   379   379 D SystemServerTiming: StartStorageStatsService took to complete: 22ms
01-01 00:00:57.242   379   379 I SystemServer: StartUiModeManager
01-01 00:00:57.242   379   379 I SystemServiceManager: Starting com.android.server.UiModeManagerService
01-01 00:00:57.244   379   445 D StorageManagerService: Thinking about init, mSystemReady=false, mDaemonConnected=true
01-01 00:00:57.244   379   445 D StorageManagerService: Thinking about reset, mSystemReady=false, mDaemonConnected=true
01-01 00:00:57.245   273   273 D installd: Applied hard quotas for 10028
01-01 00:00:57.249   379   445 D StorageManagerService: Thinking about init, mSystemReady=false, mDaemonConnected=true
01-01 00:00:57.249   379   445 D StorageManagerService: Thinking about reset, mSystemReady=false, mDaemonConnected=true
01-01 00:00:57.250   379   445 D CryptdConnector: SND -> {1 cryptfs getfield SystemLocale}
01-01 00:00:57.256   379   392 D SystemServerInitThreadPool: Started executing UiModeManager.onStart
01-01 00:00:57.257   379   392 I ActivityManager: Config changes=200 {1.0 ?mcc?mnc [en_US] ldltr sw480dp w752dp h456dp 160dpi lrg land -touch -keyb/h/h -nav/h appBounds=Rect(0, 0 - 752, 480) s.4}
01-01 00:00:57.258   379   379 D SystemServerTiming: StartUiModeManager took to complete: 16ms
01-01 00:00:57.258   379   379 I SystemServer: UpdatePackagesIfNeeded
01-01 00:00:57.269   379   447 D CryptdConnector: RCV <- {200 1 -1}
01-01 00:00:57.272   379   392 I ActivityManager: Override config changes=200 {1.0 ?mcc?mnc [en_US] ldltr sw480dp w752dp h456dp 160dpi lrg land -touch -keyb/h/h -nav/h appBounds=Rect(0, 0 - 752, 480) s.4} for displayId=0
01-01 00:00:57.275   379   445 W StorageManagerService: No primary storage mounted!
01-01 00:00:57.276   379   445 D VoldConnector: SND -> {1 asec list}
01-01 00:00:57.277   379   446 D VoldConnector: RCV <- {200 1 asec operation succeeded}
01-01 00:00:57.278   379   445 I PackageManager: No secure containers found
01-01 00:00:57.287   273   432 D installd: Applied hard quotas for 1002
01-01 00:00:57.288   379   392 D SystemServerInitThreadPool: Finished executing UiModeManager.onStart
01-01 00:00:57.401   379   445 W StorageManagerService: No primary storage defined yet; hacking together a stub
01-01 00:00:57.402   273   273 W installd: Requested default storage /data/user_de/0/com.android.bluetooth is not active; migrating from /data/data/com.android.bluetooth
01-01 00:00:57.404   379   445 W StorageManagerService: No primary storage defined yet; hacking together a stub
01-01 00:00:57.406   379   445 W StorageManagerService: No primary storage mounted!
01-01 00:00:57.406   379   445 D VoldConnector: SND -> {2 asec list}
01-01 00:00:57.407   379   446 D VoldConnector: RCV <- {200 2 asec operation succeeded}
01-01 00:00:57.439   273   421 D installd: Applied hard quotas for 10033
01-01 00:00:57.445   379   423 D SystemServerTimingAsync: AppDataPrepare took to complete: 2151ms
01-01 00:00:57.446   379   423 I PackageManager: Deferred reconcileAppsData finished 61 packages
01-01 00:00:57.446   379   423 D SystemServerInitThreadPool: Finished executing prepareAppData
01-01 00:00:57.673   379   379 I PackageManager.DexOptimizer: Running dexopt (dexoptNeeded=1) on: /vendor/app/CactusPlayer/CactusPlayer.apk pkg=com.freescale.cactusplayer isa=arm dexoptFlags=public target-filter=quicken oatDir=null sharedLibraries=null
01-01 00:00:57.753   448   448 W dex2oat : Using default instruction set features for ARM CPU variant (cortex-a9) using conservative defaults
01-01 00:00:57.755   448   448 I dex2oat : /system/bin/dex2oat --input-vdex-fd=-1 --output-vdex-fd=9 --compiler-filter=quicken --classpath-dir=/vendor/app/CactusPlayer
01-01 00:00:57.796   448   448 W dex2oat : Could not reserve sentinel fault page
01-01 00:00:58.187   448   448 I dex2oat : dex2oat took 434.237ms (312.679ms cpu) (threads: 2) arena alloc=6KB (6264B) java alloc=109KB (111720B) native alloc=1257KB (1287936B) free=1814KB (1857792B)
01-01 00:00:58.281   379   379 I PackageManager.DexOptimizer: Running dexopt (dexoptNeeded=1) on: /system/app/CubeLiveWallpapers/CubeLiveWallpapers.apk pkg=com.example.android.livecubes isa=arm dexoptFlags=public target-filter=quicken oatDir=null sharedLibraries=null
01-01 00:00:58.348   451   451 W dex2oat : Using default instruction set features for ARM CPU variant (cortex-a9) using conservative defaults
01-01 00:00:58.349   451   451 I dex2oat : /system/bin/dex2oat --input-vdex-fd=-1 --output-vdex-fd=9 --compiler-filter=quicken --classpath-dir=/system/app/CubeLiveWallpapers
01-01 00:00:58.355   451   451 W dex2oat : Could not reserve sentinel fault page
01-01 00:00:58.630   451   451 I dex2oat : dex2oat took 283.721ms (217.476ms cpu) (threads: 2) arena alloc=5KB (5152B) java alloc=54KB (55408B) native alloc=1170KB (1198320B) free=877KB (898832B)
01-01 00:00:59.538   379   379 D SystemServerTiming: UpdatePackagesIfNeeded took to complete: 2279ms
01-01 00:00:59.538   379   379 I SystemServer: PerformFstrimIfNeeded
01-01 00:00:59.539   379   379 D SystemServerTiming: PerformFstrimIfNeeded took to complete: 1ms
01-01 00:00:59.539   379   379 I SystemServer: StartLockSettingsService
01-01 00:00:59.540   379   379 I SystemServiceManager: Starting com.android.server.locksettings.LockSettingsService$Lifecycle
01-01 00:00:59.571   379   379 D SystemServerTiming: StartLockSettingsService took to complete: 32ms
01-01 00:00:59.572   379   379 I SystemServer: StartPersistentDataBlock
01-01 00:00:59.572   379   379 I SystemServiceManager: Starting com.android.server.PersistentDataBlockService
01-01 00:00:59.575   379   426 D SystemServerInitThreadPool: Started executing PersistentDataBlockService.onStart
01-01 00:00:59.575   379   379 D SystemServerTiming: StartPersistentDataBlock took to complete: 4ms
01-01 00:00:59.576   379   379 I SystemServer: StartOemLockService
01-01 00:00:59.577   379   379 I SystemServiceManager: Starting com.android.server.oemlock.OemLockService
01-01 00:00:59.593   379   426 E PersistentDataBlockService: not able to find package
01-01 00:00:59.593   379   426 E PersistentDataBlockService: android.content.pm.PackageManager$NameNotFoundException:
01-01 00:00:59.593   379   426 E PersistentDataBlockService:     at android.app.ApplicationPackageManager.getPackageUidAsUser(ApplicationPackageManager.java:281)
01-01 00:00:59.593   379   426 E PersistentDataBlockService:     at com.android.server.PersistentDataBlockService.getAllowedUid(PersistentDataBlockService.java:112)
01-01 00:00:59.593   379   426 E PersistentDataBlockService:     at com.android.server.PersistentDataBlockService.lambda$-com_android_server_PersistentDataBlockService_5033(PersistentDataBlockService.java:125)
01-01 00:00:59.593   379   426 E PersistentDataBlockService:     at com.android.server.-$Lambda$VaVGUZuNs2jqHMhhxPzwNl4zK-M.$m$3(Unknown Source:4)
01-01 00:00:59.593   379   426 E PersistentDataBlockService:     at com.android.server.-$Lambda$VaVGUZuNs2jqHMhhxPzwNl4zK-M.run(Unknown Source:23)
01-01 00:00:59.593   379   426 E PersistentDataBlockService:     at com.android.server.SystemServerInitThreadPool.lambda$-com_android_server_SystemServerInitThreadPool_2249(SystemServerInitThreadPool.java:64)
01-01 00:00:59.593   379   426 E PersistentDataBlockService:     at com.android.server.-$Lambda$Ganck_s9Kl5o2K6eVDoQTKLc-6g.$m$2(Unknown Source:8)
01-01 00:00:59.593   379   426 E PersistentDataBlockService:     at com.android.server.-$Lambda$Ganck_s9Kl5o2K6eVDoQTKLc-6g.run(Unknown Source:19)
01-01 00:00:59.593   379   426 E PersistentDataBlockService:     at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:457)
01-01 00:00:59.593   379   426 E PersistentDataBlockService:     at java.util.concurrent.FutureTask.run(FutureTask.java:266)
01-01 00:00:59.593   379   426 E PersistentDataBlockService:     at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162)
01-01 00:00:59.593   379   426 E PersistentDataBlockService:     at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636)
01-01 00:00:59.593   379   426 E PersistentDataBlockService:     at com.android.internal.util.ConcurrentUtils$1$1.run(ConcurrentUtils.java:59)
01-01 00:00:59.614   379   379 I zygote  : Looking for service android.hardware.oemlock@1.0::IOemLock/default
01-01 00:00:59.615   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.oemlock@1.0::IOemLock/default in either framework or device manifest.
01-01 00:00:59.617   379   379 I OemLock : OemLock HAL not present on device
01-01 00:00:59.617   379   379 I OemLock : Using persistent data block based lock
01-01 00:00:59.620   379   379 D SystemServerTiming: StartOemLockService took to complete: 44ms
01-01 00:00:59.620   379   379 I SystemServer: StartDeviceIdleController
01-01 00:00:59.621   379   379 I SystemServiceManager: Starting com.android.server.DeviceIdleController
01-01 00:00:59.628   379   379 D SystemServerTiming: StartDeviceIdleController took to complete: 9ms
01-01 00:00:59.629   379   379 I SystemServer: StartDevicePolicyManager
01-01 00:00:59.629   379   379 I SystemServiceManager: Starting com.android.server.devicepolicy.DevicePolicyManagerService$Lifecycle
01-01 00:00:59.688   379   426 I PersistentDataBlockService: Formatting FRP partition...
01-01 00:00:59.691   379   379 D SystemServerTiming: StartDevicePolicyManager took to complete: 62ms
01-01 00:00:59.691   379   379 I SystemServer: StartStatusBarManagerService
01-01 00:00:59.697   379   379 D SystemServerTiming: StartStatusBarManagerService took to complete: 6ms
01-01 00:00:59.698   379   379 I SystemServer: StartClipboardService
01-01 00:00:59.698   379   379 I SystemServiceManager: Starting com.android.server.clipboard.ClipboardService
01-01 00:00:59.703   379   379 D SystemServerTiming: StartClipboardService took to complete: 5ms
01-01 00:00:59.704   379   379 I SystemServer: StartNetworkManagementService
01-01 00:00:59.722   379   454 I NetworkManagement: onDaemonConnected()
01-01 00:00:59.732   379   379 D SystemServerTiming: StartNetworkManagementService took to complete: 29ms
01-01 00:00:59.733   379   379 I SystemServer: StartTextServicesManager
01-01 00:00:59.733   379   379 I SystemServiceManager: Starting com.android.server.TextServicesManagerService$Lifecycle
01-01 00:00:59.751   379   379 D SystemServerTiming: StartTextServicesManager took to complete: 19ms
01-01 00:00:59.752   379   379 I SystemServer: StartNetworkScoreService
01-01 00:00:59.756   379   379 D SystemServerTiming: StartNetworkScoreService took to complete: 4ms
01-01 00:00:59.756   379   379 I SystemServer: StartNetworkStatsService
01-01 00:00:59.837   379   426 D SystemServerInitThreadPool: Finished executing PersistentDataBlockService.onStart
01-01 00:00:59.884   379   379 D SystemServerTiming: StartNetworkStatsService took to complete: 127ms
01-01 00:00:59.884   379   379 I SystemServer: StartNetworkPolicyManagerService
01-01 00:00:59.896   379   457 I ServiceThread: Enabled StrictMode logging for NetworkPolicy.uid looper.
01-01 00:00:59.899   379   379 D SystemServerTiming: StartNetworkPolicyManagerService took to complete: 15ms
01-01 00:00:59.899   379   379 I SystemServer: StartWifi
01-01 00:01:00.000   379   379 I SystemServiceManager: Starting com.android.server.wifi.WifiService
01-01 00:01:00.192   379   379 D WifiApConfigStore: 2G band allowed channels are:1,6,11
01-01 00:01:00.193   379   379 E WifiApConfigStore: Error reading hotspot configuration java.io.FileNotFoundException: /data/misc/wifi/softap.conf (No such file or directory)
01-01 00:01:00.193   379   379 D WifiApConfigStore: Fallback to use default AP configuration
01-01 00:01:00.353   379   460 E IpManager.wlan0: ERROR Failed to disable IPv6: java.lang.IllegalStateException: command '1 interface ipv6 wlan0 disable' failed with '400 1 Failed to change IPv6 state (No such file or directory)'
01-01 00:01:00.355   250   343 D CommandListener: Clearing all IP addresses on wlan0
01-01 00:01:00.358   379   459 E HalDeviceManager: isSupported: called but mServiceManager is null!?
01-01 00:01:00.358   379   459 I WifiNative-wlan0: Vendor HAL not supported, Ignore stop...
01-01 00:01:00.358   379   459 D WificondControl: tearing down interfaces in wificond
01-01 00:01:00.368   379   379 D WifiController: isAirplaneModeOn = false, isWifiEnabled = false, isScanningAvailable = false
01-01 00:01:00.379   379   379 E SupplicantStaIfaceHal: Can't call setDebugParams, ISupplicant is null
01-01 00:01:00.380   379   379 W WifiDiags: no ring buffers found
01-01 00:01:00.380   379   379 W WifiDiags: Failed to start packet fate monitoring
01-01 00:01:00.380   379   379 I WifiService: Registering wifi
01-01 00:01:00.382   379   379 D SystemServerTiming: StartWifi took to complete: 482ms
01-01 00:01:00.382   379   379 I SystemServer: StartWifiScanning
01-01 00:01:00.392   379   379 I SystemServiceManager: Starting com.android.server.wifi.scanner.WifiScanningService
01-01 00:01:00.396   379   379 I WifiScanningService: Creating wifiscanner
01-01 00:01:00.399   379   379 I WifiScanningService: Publishing wifiscanner
01-01 00:01:00.400   379   379 D SystemServerTiming: StartWifiScanning took to complete: 18ms
01-01 00:01:00.400   379   379 I SystemServer: StartWifiRtt
01-01 00:01:00.403   379   379 I SystemServiceManager: Starting com.android.server.wifi.RttService
01-01 00:01:00.404   379   379 I RttService: Creating rttmanager
01-01 00:01:00.405   379   379 I RttService: Starting rttmanager
01-01 00:01:00.406   379   379 D SystemServerTiming: StartWifiRtt took to complete: 6ms
01-01 00:01:00.407   379   379 I SystemServer: No Wi-Fi Aware Service (Aware support Not Present)
01-01 00:01:00.407   379   379 I SystemServer: StartWifiP2P
01-01 00:01:00.408   379   379 I SystemServiceManager: Starting com.android.server.wifi.p2p.WifiP2pService
01-01 00:01:00.426   379   379 I WifiP2pService: Registering wifip2p
01-01 00:01:00.427   379   379 D SystemServerTiming: StartWifiP2P took to complete: 20ms
01-01 00:01:00.427   379   379 I SystemServer: StartEthernet
01-01 00:01:00.429   379   379 I SystemServiceManager: Starting com.android.server.ethernet.EthernetService
01-01 00:01:00.430   379   379 I EthernetServiceImpl: Creating EthernetConfigStore
01-01 00:01:00.431   379   379 E IpConfigStore: Error opening configuration file: java.io.FileNotFoundException: /data/misc/ethernet/ipconfig.txt (No such file or directory)
01-01 00:01:00.432   379   379 W EthernetConfigStore: No Ethernet configuration found. Using default.
01-01 00:01:00.432   379   379 I EthernetServiceImpl: Read stored IP configuration: IP assignment: DHCP
01-01 00:01:00.432   379   379 I EthernetServiceImpl: Proxy settings: NONE
01-01 00:01:00.440   379   379 I EthernetService: Registering service ethernet
01-01 00:01:00.441   379   379 D SystemServerTiming: StartEthernet took to complete: 13ms
01-01 00:01:00.441   379   379 I SystemServer: StartConnectivityService
01-01 00:01:00.455   379   379 D ConnectivityService: ConnectivityService starting up
01-01 00:01:00.469   379   379 D ConnectivityService: wifiOnly=true
01-01 00:01:00.470   379   379 E ConnectivityService: Ignoring protectedNetwork 10
01-01 00:01:00.470   379   379 E ConnectivityService: Ignoring protectedNetwork 11
01-01 00:01:00.470   379   379 E ConnectivityService: Ignoring protectedNetwork 12
01-01 00:01:00.470   379   379 E ConnectivityService: Ignoring protectedNetwork 14
01-01 00:01:00.470   379   379 E ConnectivityService: Ignoring protectedNetwork 15
01-01 00:01:00.517   379   379 D SystemServerTiming: StartConnectivityService took to complete: 75ms
01-01 00:01:00.517   379   379 I SystemServer: StartNsdService
01-01 00:01:00.522   379   379 D NsdService: Network service discovery is enabled
01-01 00:01:00.527   379   379 D SystemServerTiming: StartNsdService took to complete: 10ms
01-01 00:01:00.527   379   379 I SystemServer: StartUpdateLockService
01-01 00:01:00.530   379   379 D SystemServerTiming: StartUpdateLockService took to complete: 4ms
01-01 00:01:00.530   379   379 I SystemServer: WaitForAsecScan
01-01 00:01:00.531   379   379 D SystemServerTiming: WaitForAsecScan took to complete: 0ms
01-01 00:01:00.531   379   379 I SystemServer: StartNotificationManager
01-01 00:01:00.533   379   379 I SystemServiceManager: Starting com.android.server.notification.NotificationManagerService
01-01 00:01:00.558   379   389 I zygote  : Background concurrent copying GC freed 22854(1502KB) AllocSpace objects, 6(120KB) LOS objects, 42% free, 2MB/4MB, paused 246us total 102.150ms
01-01 00:01:00.615   379   379 D ConditionProviders.SCP: new ScheduleConditionProvider()
01-01 00:01:00.621   379   379 D ZenLog  : set_zen_mode: off,init
01-01 00:01:00.626   379   379 W SystemServiceManager: Service com.android.server.notification.NotificationManagerService took 60 ms in onStart
01-01 00:01:00.633   379   379 D SystemServerTiming: StartNotificationManager took to complete: 103ms
01-01 00:01:00.633   379   379 I SystemServer: StartDeviceMonitor
01-01 00:01:00.634   379   379 I SystemServiceManager: Starting com.android.server.storage.DeviceStorageMonitorService
01-01 00:01:00.638   379   379 D SystemServerTiming: StartDeviceMonitor took to complete: 4ms
01-01 00:01:00.638   379   379 I SystemServer: StartLocationManagerService
01-01 00:01:00.643   379   379 D SystemServerTiming: StartLocationManagerService took to complete: 5ms
01-01 00:01:00.643   379   379 I SystemServer: StartCountryDetectorService
01-01 00:01:00.652   379   379 D SystemServerTiming: StartCountryDetectorService took to complete: 9ms
01-01 00:01:00.653   379   379 I SystemServer: StartSearchManagerService
01-01 00:01:00.653   379   379 I SystemServiceManager: Starting com.android.server.search.SearchManagerService$Lifecycle
01-01 00:01:00.658   379   379 D SystemServerTiming: StartSearchManagerService took to complete: 5ms
01-01 00:01:00.658   379   379 I SystemServer: StartWallpaperManagerService
01-01 00:01:00.659   379   379 I SystemServiceManager: Starting com.android.server.wallpaper.WallpaperManagerService$Lifecycle
01-01 00:01:00.664   379   379 I WallpaperManagerService: No static wallpaper imagery; defaults will be shown
01-01 00:01:00.664   379   379 W WallpaperManagerService: no current wallpaper -- first boot?
01-01 00:01:00.666   379   379 D SystemServerTiming: StartWallpaperManagerService took to complete: 7ms
01-01 00:01:00.666   379   379 I SystemServer: StartAudioService
01-01 00:01:00.666   379   379 I SystemServiceManager: Starting com.android.server.audio.AudioService$Lifecycle
01-01 00:01:00.696   270   368 D PermissionCache: checking android.permission.MODIFY_AUDIO_SETTINGS for uid=1000 => granted (6040 us)
01-01 00:01:00.707   379   379 W TelecomManager: Telecom Service not found.
01-01 00:01:00.744   379   379 D SystemServerTiming: StartAudioService took to complete: 79ms
01-01 00:01:00.744   379   379 I SystemServer: StartDockObserver
01-01 00:01:00.745   379   379 I SystemServiceManager: Starting com.android.server.DockObserver
01-01 00:01:00.746   379   379 W DockObserver: This kernel does not have dock station support
01-01 00:01:00.749   379   379 D SystemServerTiming: StartDockObserver took to complete: 4ms
01-01 00:01:00.749   379   379 I SystemServer: StartWiredAccessoryManager
01-01 00:01:00.751   379   379 W WiredAccessoryManager: This kernel does not have wired headset support
01-01 00:01:00.752   379   379 W WiredAccessoryManager: This kernel does not have usb audio support
01-01 00:01:00.752   379   379 W WiredAccessoryManager: This kernel does not have HDMI audio support
01-01 00:01:00.752   379   379 D SystemServerTiming: StartWiredAccessoryManager took to complete: 4ms
01-01 00:01:00.753   379   379 I SystemServer: StartUsbService
01-01 00:01:00.753   379   379 I SystemServiceManager: Starting com.android.server.usb.UsbService$Lifecycle
01-01 00:01:00.774   379   379 E AlsaCardRecord: Failed to parse line 0 of /proc/asound/cards: ---
01-01 00:01:00.777   379   379 E UsbDeviceManager: failed to write to /sys/class/android_usb/android0/f_rndis/ethaddr
01-01 00:01:00.798   379   379 I zygote  : Looking for service android.hidl.manager@1.0::IServiceManager/default
01-01 00:01:00.801   379   379 I zygote  : Starting thread pool.
01-01 00:01:00.804   379   441 I UsbPortManager: Usb hal service started android.hardware.usb@1.0::IUsb default
01-01 00:01:00.804   379   441 I zygote  : Looking for service android.hardware.usb@1.0::IUsb/default
01-01 00:01:00.806   379   441 I zygote  : Starting thread pool.
01-01 00:01:00.808   263   263 I android.hardware.usb@1.0-service: registering callback
01-01 00:01:00.809   263   263 E android.hardware.usb@1.0-service: Failed to open /sys/class/dual_role_usb
01-01 00:01:00.815   263   474 E android.hardware.usb@1.0-service: creating thread
01-01 00:01:00.816   379   379 W SystemServiceManager: Service com.android.server.usb.UsbService$Lifecycle took 62 ms in onStart
01-01 00:01:00.816   379   379 D SystemServerTiming: StartUsbService took to complete: 63ms
01-01 00:01:00.816   379   379 I SystemServer: StartSerialService
01-01 00:01:00.819   379   379 D SystemServerTiming: StartSerialService took to complete: 3ms
01-01 00:01:00.819   379   379 I SystemServer: StartHardwarePropertiesManagerService
01-01 00:01:00.821   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.thermal@1.0::IThermal/default in either framework or device manifest.
01-01 00:01:00.822   379   379 E HardwarePropertiesManagerService-JNI: Unable to get Thermal service.
01-01 00:01:00.824   379   379 D SystemServerTiming: StartHardwarePropertiesManagerService took to complete: 5ms
01-01 00:01:00.824   379   379 I SystemServer: StartTwilightService
01-01 00:01:00.824   379   379 I SystemServiceManager: Starting com.android.server.twilight.TwilightService
01-01 00:01:00.825   379   379 D SystemServerTiming: StartTwilightService took to complete: 1ms
01-01 00:01:00.825   379   379 I SystemServer: StartJobScheduler
01-01 00:01:00.826   379   379 I SystemServiceManager: Starting com.android.server.job.JobSchedulerService
01-01 00:01:00.843   379   379 D ConnectivityService: requestNetwork for uid/pid:1000/379 NetworkRequest [ TRACK_DEFAULT id=3, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ]
01-01 00:01:00.851   379   379 D SystemServerTiming: StartJobScheduler took to complete: 26ms
01-01 00:01:00.852   379   379 I SystemServer: StartSoundTrigger
01-01 00:01:00.852   379   379 I SystemServiceManager: Starting com.android.server.soundtrigger.SoundTriggerService
01-01 00:01:00.855   379   379 D SystemServerTiming: StartSoundTrigger took to complete: 3ms
01-01 00:01:00.855   379   379 I SystemServer: StartTrustManager
01-01 00:01:00.856   379   379 I SystemServiceManager: Starting com.android.server.trust.TrustManagerService
01-01 00:01:00.865   379   379 D SystemServerTiming: StartTrustManager took to complete: 10ms
01-01 00:01:00.866   379   379 I SystemServer: StartBackupManager
01-01 00:01:00.866   379   379 I SystemServiceManager: Starting com.android.server.backup.BackupManagerService$Lifecycle
01-01 00:01:00.893   379   379 D SystemServerTiming: StartBackupManager took to complete: 27ms
01-01 00:01:00.893   379   379 I SystemServer: StartAppWidgerService
01-01 00:01:00.894   379   379 I SystemServiceManager: Starting com.android.server.appwidget.AppWidgetService
01-01 00:01:00.924   379   379 D SystemServerTiming: StartAppWidgerService took to complete: 30ms
01-01 00:01:00.924   379   379 I SystemServer: StartVoiceRecognitionManager
01-01 00:01:00.924   379   379 I SystemServiceManager: Starting com.android.server.voiceinteraction.VoiceInteractionManagerService
01-01 00:01:00.932   379   379 D SystemServerTiming: StartVoiceRecognitionManager took to complete: 9ms
01-01 00:01:00.933   379   379 I SystemServer: StartGestureLauncher
01-01 00:01:00.933   379   379 I SystemServiceManager: Starting com.android.server.GestureLauncherService
01-01 00:01:00.934   379   379 D SystemServerTiming: StartGestureLauncher took to complete: 1ms
01-01 00:01:00.934   379   379 I SystemServer: StartSensorNotification
01-01 00:01:00.935   379   379 I SystemServiceManager: Starting com.android.server.SensorNotificationService
01-01 00:01:00.935   379   379 D SystemServerTiming: StartSensorNotification took to complete: 0ms
01-01 00:01:00.935   379   379 I SystemServer: StartContextHubSystemService
01-01 00:01:00.935   379   379 I SystemServiceManager: Starting com.android.server.ContextHubSystemService
01-01 00:01:00.936   379   379 D SystemServerTiming: StartContextHubSystemService took to complete: 0ms
01-01 00:01:00.936   379   427 D SystemServerInitThreadPool: Started executing Init ContextHubSystemService
01-01 00:01:00.936   379   379 I SystemServer: StartDiskStatsService
01-01 00:01:00.940   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.contexthub@1.0::IContexthub/default in either framework or device manifest.
01-01 00:01:00.940   379   379 D SystemServerTiming: StartDiskStatsService took to complete: 5ms
01-01 00:01:00.941   379   379 I SystemServer: StartSamplingProfilerService
01-01 00:01:00.942   379   427 E ContextHubService: Could not load context hub hal
01-01 00:01:00.942   379   427 W ContextHubService: No Context Hub Module present
01-01 00:01:00.942   379   427 D SystemServerInitThreadPool: Finished executing Init ContextHubSystemService
01-01 00:01:00.956   379   379 D SystemServerTiming: StartSamplingProfilerService took to complete: 15ms
01-01 00:01:00.956   379   379 I SystemServer: StartNetworkTimeUpdateService
01-01 00:01:00.958   379   379 D SystemServerTiming: StartNetworkTimeUpdateService took to complete: 3ms
01-01 00:01:00.958   379   379 I SystemServer: StartCommonTimeManagementService
01-01 00:01:00.962   379   379 D SystemServerTiming: StartCommonTimeManagementService took to complete: 3ms
01-01 00:01:00.962   379   379 I SystemServer: CertBlacklister
01-01 00:01:00.964   379   379 D SystemServerTiming: CertBlacklister took to complete: 1ms
01-01 00:01:00.964   379   379 I SystemServer: StartEmergencyAffordanceService
01-01 00:01:00.965   379   379 I SystemServiceManager: Starting com.android.server.emergency.EmergencyAffordanceService
01-01 00:01:00.965   379   379 D SystemServerTiming: StartEmergencyAffordanceService took to complete: 1ms
01-01 00:01:00.966   379   379 I SystemServer: StartDreamManager
01-01 00:01:00.966   379   379 I SystemServiceManager: Starting com.android.server.dreams.DreamManagerService
01-01 00:01:00.972   379   379 D SystemServerTiming: StartDreamManager took to complete: 6ms
01-01 00:01:00.972   379   379 I SystemServer: AddGraphicsStatsService
01-01 00:01:00.975   379   379 D SystemServerTiming: AddGraphicsStatsService took to complete: 4ms
01-01 00:01:00.978   379   379 I SystemServer: StartPrintManager
01-01 00:01:00.978   379   379 I SystemServiceManager: Starting com.android.server.print.PrintManagerService
01-01 00:01:00.986   379   379 D SystemServerTiming: StartPrintManager took to complete: 9ms
01-01 00:01:00.987   379   379 I SystemServer: StartCompanionDeviceManager
01-01 00:01:00.988   379   379 I SystemServiceManager: Starting com.android.server.companion.CompanionDeviceManagerService
01-01 00:01:00.993   379   379 D SystemServerTiming: StartCompanionDeviceManager took to complete: 6ms
01-01 00:01:00.993   379   379 I SystemServer: StartRestrictionManager
01-01 00:01:00.994   379   379 I SystemServiceManager: Starting com.android.server.restrictions.RestrictionsManagerService
01-01 00:01:00.997   379   379 D SystemServerTiming: StartRestrictionManager took to complete: 3ms
01-01 00:01:00.997   379   379 I SystemServer: StartMediaSessionService
01-01 00:01:00.998   379   379 I SystemServiceManager: Starting com.android.server.media.MediaSessionService
01-01 00:01:01.011   379   379 D SystemServerTiming: StartMediaSessionService took to complete: 14ms
01-01 00:01:01.012   379   379 I SystemServer: StartMediaResourceMonitor
01-01 00:01:01.012   379   379 I SystemServiceManager: Starting com.android.server.media.MediaResourceMonitorService
01-01 00:01:01.014   379   379 D SystemServerTiming: StartMediaResourceMonitor took to complete: 2ms
01-01 00:01:01.014   379   379 I SystemServer: StartMediaRouterService
01-01 00:01:01.018   379   379 D SystemServerTiming: StartMediaRouterService took to complete: 5ms
01-01 00:01:01.018   379   379 I SystemServer: StartBackgroundDexOptService
01-01 00:01:01.020   379   379 D SystemServerTiming: StartBackgroundDexOptService took to complete: 1ms
01-01 00:01:01.020   379   379 I SystemServer: StartPruneInstantAppsJobService
01-01 00:01:01.021   379   379 D SystemServerTiming: StartPruneInstantAppsJobService took to complete: 1ms
01-01 00:01:01.021   379   379 I SystemServer: StartShortcutServiceLifecycle
01-01 00:01:01.022   379   379 I SystemServiceManager: Starting com.android.server.pm.ShortcutService$Lifecycle
01-01 00:01:01.032   379   379 D SystemServerTiming: StartShortcutServiceLifecycle took to complete: 10ms
01-01 00:01:01.032   379   379 I SystemServer: StartLauncherAppsService
01-01 00:01:01.032   379   379 I SystemServiceManager: Starting com.android.server.pm.LauncherAppsService
01-01 00:01:01.036   379   379 D SystemServerTiming: StartLauncherAppsService took to complete: 4ms
01-01 00:01:01.036   379   379 I SystemServer: StartMediaProjectionManager
01-01 00:01:01.036   379   379 I SystemServiceManager: Starting com.android.server.media.projection.MediaProjectionManagerService
01-01 00:01:01.058   379   379 V MediaRouter: Adding route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO  groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
01-01 00:01:01.066   379   379 V MediaRouter: Selecting route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO  groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
01-01 00:01:01.077   379   379 D SystemServerTiming: StartMediaProjectionManager took to complete: 41ms
01-01 00:01:01.077   379   379 I SystemServer: StartCameraServiceProxy
01-01 00:01:01.078   379   379 I SystemServiceManager: Starting com.android.server.camera.CameraServiceProxy
01-01 00:01:01.080   379   478 I ServiceThread: Enabled StrictMode logging for CameraService_proxy looper.
01-01 00:01:01.084   379   379 D SystemServerTiming: StartCameraServiceProxy took to complete: 6ms
01-01 00:01:01.085   379   379 I WindowManager: SAFE MODE not enabled
01-01 00:01:01.085   379   379 I SystemServer: StartJitCompilation
01-01 00:01:01.085   379   379 D SystemServerTiming: StartJitCompilation took to complete: 0ms
01-01 00:01:01.085   379   379 I SystemServer: StartMmsService
01-01 00:01:01.086   379   379 I SystemServiceManager: Starting com.android.server.MmsServiceBroker
01-01 00:01:01.089   379   379 D SystemServerTiming: StartMmsService took to complete: 4ms
01-01 00:01:01.090   379   379 I SystemServer: StartAutoFillService
01-01 00:01:01.090   379   379 I SystemServiceManager: Starting com.android.server.autofill.AutofillManagerService
01-01 00:01:01.096   379   379 I AutofillManagerService: Setting debug to true
01-01 00:01:01.101   379   379 D SystemServerTiming: StartAutoFillService took to complete: 12ms
01-01 00:01:01.102   379   379 I SystemServer: MakeVibratorServiceReady
01-01 00:01:01.104   379   379 D SystemServerTiming: MakeVibratorServiceReady took to complete: 3ms
01-01 00:01:01.105   379   379 I SystemServer: MakeLockSettingsServiceReady
01-01 00:01:01.161   379   379 E SQLiteLog: (1) no such table: locksettings
01-01 00:01:01.177   379   379 I LockSettingsService: Migrated lock settings to new location
01-01 00:01:01.188   379   379 I LockSettingsService: Migrated per-user lock settings to new location
01-01 00:01:01.207   379   379 I LockSettingsService: Migrated biometric weak to use the fallback instead
01-01 00:01:01.217   379   379 I LockSettingsService: Migrated lockscreen disabled flag
01-01 00:01:01.226   379   379 I zygote  : Looking for service android.hardware.weaver@1.0::IWeaver/default
01-01 00:01:01.227   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.weaver@1.0::IWeaver/default in either framework or device manifest.
01-01 00:01:01.229   379   379 I SyntheticPasswordManager: Device does not support weaver
01-01 00:01:01.229   379   379 I LockSettingsService: FRP credential disabled, reporting device setup complete to Gatekeeper immediately
01-01 00:01:01.232   285   285 D PermissionCache: checking android.permission.ACCESS_KEYGUARD_SECURE_STORAGE for uid=1000 => granted (2504 us)
01-01 00:01:01.233   285   285 I gatekeeperd: cold boot: clearing state
01-01 00:01:01.236   379   379 E LockSettingsStorage: Cannot read file java.io.FileNotFoundException: /data/system/gatekeeper.password.key: open failed: ENOENT (No such file or directory)
01-01 00:01:01.236   379   379 E LockSettingsStorage: Cannot read file java.io.FileNotFoundException: /data/system/password.key: open failed: ENOENT (No such file or directory)
01-01 00:01:01.238   379   379 E LockSettingsStorage: Cannot read file java.io.FileNotFoundException: /data/system/gatekeeper.pattern.key: open failed: ENOENT (No such file or directory)
01-01 00:01:01.239   379   379 E LockSettingsStorage: Cannot read file java.io.FileNotFoundException: /data/system/gatekeeper.gesture.key: open failed: ENOENT (No such file or directory)
01-01 00:01:01.241   379   379 E LockSettingsStorage: Cannot read file java.io.FileNotFoundException: /data/system/gesture.key: open failed: ENOENT (No such file or directory)
01-01 00:01:01.241   379   379 D SystemServerTiming: MakeLockSettingsServiceReady took to complete: 136ms
01-01 00:01:01.241   379   379 I SystemServer: StartBootPhaseLockSettingsReady
01-01 00:01:01.241   379   379 I SystemServiceManager: Starting phase 480
01-01 00:01:01.263   379   379 D SystemServerTiming: StartBootPhaseLockSettingsReady took to complete: 22ms
01-01 00:01:01.264   379   379 I SystemServer: StartBootPhaseSystemServicesReady
01-01 00:01:01.264   379   379 I SystemServiceManager: Starting phase 500
01-01 00:01:01.273   379   379 I VrManagerService: No default vr listener service found.
01-01 00:01:01.285   379   379 I WifiService: WifiService starting up with Wi-Fi disabled
01-01 00:01:01.294   379   459 I zygote  : Looking for service android.hidl.manager@1.0::IServiceManager/default
01-01 00:01:01.296   379   459 I zygote  : Starting thread pool.
01-01 00:01:01.299   379   442 D HalDeviceManager: IWifi registration notification: fqName=android.hardware.wifi@1.0::IWifi, name=default, preexisting=true
01-01 00:01:01.300   379   442 I zygote  : Looking for service android.hardware.wifi@1.0::IWifi/default
01-01 00:01:01.302   379   442 I zygote  : Starting thread pool.
01-01 00:01:01.326   379   379 I WifiScanningService: Starting wifiscanner
01-01 00:01:01.331   379   379 I RttService: Registering rttmanager
01-01 00:01:01.334   379   379 I EthernetServiceImpl: Starting Ethernet service
01-01 00:01:01.338   379   379 D Ethernet: Registering NetworkFactory
01-01 00:01:01.338   379   464 D ConnectivityService: Got NetworkFactory Messenger for Ethernet
01-01 00:01:01.339   379   480 D Ethernet: got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
01-01 00:01:01.340   379   480 D Ethernet: got request NetworkRequest [ TRACK_DEFAULT id=3, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
01-01 00:01:01.344   379   480 D EthernetNetworkFactory: Started tracking interface eth0
01-01 00:01:01.345   379   379 D ZenLog  : config: cleanUpZenRules,ZenModeConfig[user=0,allowCalls=true,allowRepeatCallers=false,allowMessages=false,allowCallsFrom=contacts,allowMessagesFrom=contacts,allowReminders=true,allowEvents=true,allowWhenScreenOff=true,allowWhenScreenOn=true,automaticRules={6544c6929f4146d7b057d79a1d9f40bf=ZenRule[enabled=false,snoozing=false,name=Event,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/event?userId=-10000&calendar=&reply=1,condition=null,component=ComponentInfo{android/com.android.server.notification.EventConditionProvider},id=6544c6929f4146d7b057d79a1d9f40bf,creationTime=60606,enabler=null], ca859dcc4d0342d1a0d99345ea03a260=ZenRule[enabled=false,snoozing=false,name=Weeknight,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,condition=null,component=ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider},id=ca859dcc4d0342d1a0d99345ea03a260,creationTime=60604,enabler=null], b93582e5a95c453b9f64fb4f95f5e62c=ZenRule[enabled=false,snoozing=false,name=Weekend,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false,condition=null,component=ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider},id=b93582e5a95c453b9f64fb4f95f5e62c,creationTime=60604,enabler=null]},manualRule=null],Diff[]
01-01 00:01:01.346   379   379 D ZenLog  : set_zen_mode: off,onSystemReady
01-01 00:01:01.348   250   343 D CommandListener: Setting iface cfg
01-01 00:01:01.348   250   343 D CommandListener: Trying to bring up eth0
01-01 00:01:01.355   270   368 D PermissionCache: checking android.permission.CAPTURE_AUDIO_HOTWORD for uid=1000 => granted (282 us)
01-01 00:01:01.355   379   379 W SoundTriggerHelper: listModules status=0, # of modules=0
01-01 00:01:01.357   379   379 D ContextHubSystemService: onBootPhase: PHASE_SYSTEM_SERVICES_READY
01-01 00:01:01.359   379   379 D SystemServerTiming: StartBootPhaseSystemServicesReady took to complete: 95ms
01-01 00:01:01.359   379   379 I SystemServer: MakeWindowManagerServiceReady
01-01 00:01:01.385   379   379 I zygote  : Looking for service android.hardware.configstore@1.0::ISurfaceFlingerConfigs/default
01-01 00:01:01.387   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.configstore@1.0::ISurfaceFlingerConfigs/default in either framework or device manifest.
01-01 00:01:01.388   379   379 I zygote  : Starting thread pool.
01-01 00:01:01.390   379   379 D SystemServerTiming: MakeWindowManagerServiceReady took to complete: 31ms
01-01 00:01:01.392   379   379 I SystemServer: MakePowerManagerServiceReady
01-01 00:01:01.419   379   403 W KeyguardServiceDelegate: onScreenTurningOn(): no keyguard service!
01-01 00:01:01.430   379   379 D SystemServerTiming: MakePowerManagerServiceReady took to complete: 38ms
01-01 00:01:01.430   379   379 I SystemServer: MakePackageManagerServiceReady
01-01 00:01:01.442   379   379 I DefaultPermGrantPolicy: Granting permissions to platform components for user 0
01-01 00:01:01.445   379   379 D VoldConnector: SND -> {3 volume remount_uid 1001 none}
01-01 00:01:01.445   244   247 D vold    : Remounting 1001 as mode none
01-01 00:01:01.454   244   247 D vold    : Found matching PID 283
01-01 00:01:01.455   244   247 W vold    : Skipping due to root namespace
01-01 00:01:01.460   379   446 D VoldConnector: RCV <- {200 3 Command succeeded}
01-01 00:01:01.462   379   379 D VoldConnector: SND -> {4 volume remount_uid 1001 none}
01-01 00:01:01.463   244   247 D vold    : Remounting 1001 as mode none
01-01 00:01:01.470   244   247 D vold    : Found matching PID 283
01-01 00:01:01.470   244   247 W vold    : Skipping due to root namespace
01-01 00:01:01.471   379   446 D VoldConnector: RCV <- {200 4 Command succeeded}
01-01 00:01:01.475   379   379 D VoldConnector: SND -> {5 volume remount_uid 1027 none}
01-01 00:01:01.476   244   247 D vold    : Remounting 1027 as mode none
01-01 00:01:01.485   379   446 D VoldConnector: RCV <- {200 5 Command succeeded}
01-01 00:01:01.487   379   379 D VoldConnector: SND -> {6 volume remount_uid 1027 none}
01-01 00:01:01.488   244   247 D vold    : Remounting 1027 as mode none
01-01 00:01:01.495   379   446 D VoldConnector: RCV <- {200 6 Command succeeded}
01-01 00:01:01.499   379   379 D VoldConnector: SND -> {7 volume remount_uid 1000 none}
01-01 00:01:01.500   244   247 D vold    : Remounting 1000 as mode none
01-01 00:01:01.506   244   247 D vold    : Found matching PID 233
01-01 00:01:01.506   244   247 W vold    : Skipping due to root namespace
01-01 00:01:01.506   244   247 D vold    : Found matching PID 234
01-01 00:01:01.506   244   247 D vold    : Found matching PID 235
01-01 00:01:01.506   244   247 D vold    : Found matching PID 253
01-01 00:01:01.507   244   247 W vold    : Skipping due to root namespace
01-01 00:01:01.507   244   247 D vold    : Found matching PID 257
01-01 00:01:01.507   244   247 D vold    : Found matching PID 258
01-01 00:01:01.508   244   247 D vold    : Found matching PID 259
01-01 00:01:01.508   244   247 W vold    : Skipping due to root namespace
01-01 00:01:01.508   244   247 D vold    : Found matching PID 260
01-01 00:01:01.508   244   247 D vold    : Found matching PID 261
01-01 00:01:01.508   244   247 D vold    : Found matching PID 262
01-01 00:01:01.509   244   247 W vold    : Skipping due to root namespace
01-01 00:01:01.509   244   247 D vold    : Found matching PID 263
01-01 00:01:01.509   244   247 D vold    : Found matching PID 267
01-01 00:01:01.510   244   247 D vold    : Found matching PID 285
01-01 00:01:01.510   244   247 W vold    : Skipping due to root namespace
01-01 00:01:01.510   244   247 D vold    : Found matching PID 379
01-01 00:01:01.519   379   480 D EthernetNetworkFactory: updateInterface: eth0 link down
01-01 00:01:01.609   379   446 D VoldConnector: RCV <- {200 7 Command succeeded}
01-01 00:01:01.611   379   379 D VoldConnector: SND -> {8 volume remount_uid 1000 none}
01-01 00:01:01.611   244   247 D vold    : Remounting 1000 as mode none
01-01 00:01:01.617   244   247 D vold    : Found matching PID 233
01-01 00:01:01.617   244   247 W vold    : Skipping due to root namespace
01-01 00:01:01.618   244   247 D vold    : Found matching PID 234
01-01 00:01:01.618   244   247 W vold    : Skipping due to root namespace
01-01 00:01:01.618   244   247 D vold    : Found matching PID 235
01-01 00:01:01.618   244   247 D vold    : Found matching PID 253
01-01 00:01:01.618   244   247 D vold    : Found matching PID 257
01-01 00:01:01.618   244   247 D vold    : Found matching PID 258
01-01 00:01:01.619   244   247 W vold    : Skipping due to root namespace
01-01 00:01:01.619   244   247 D vold    : Found matching PID 259
01-01 00:01:01.619   244   247 D vold    : Found matching PID 260
01-01 00:01:01.619   244   247 D vold    : Found matching PID 261
01-01 00:01:01.619   244   247 D vold    : Found matching PID 262
01-01 00:01:01.619   244   247 D vold    : Found matching PID 263
01-01 00:01:01.620   244   247 D vold    : Found matching PID 267
01-01 00:01:01.620   244   247 W vold    : Skipping due to root namespace
01-01 00:01:01.620   244   247 D vold    : Found matching PID 285
01-01 00:01:01.620   244   247 D vold    : Found matching PID 379
01-01 00:01:01.625   379   446 D VoldConnector: RCV <- {200 8 Command succeeded}
01-01 00:01:01.640   379   379 D VoldConnector: SND -> {9 volume remount_uid 2000 none}
01-01 00:01:01.641   244   247 D vold    : Remounting 2000 as mode none
01-01 00:01:01.647   244   247 D vold    : Found matching PID 268
01-01 00:01:01.648   244   247 W vold    : Skipping due to root namespace
01-01 00:01:01.648   244   247 D vold    : Found matching PID 269
01-01 00:01:01.650   379   446 D VoldConnector: RCV <- {200 9 Command succeeded}
01-01 00:01:01.652   379   379 D VoldConnector: SND -> {10 volume remount_uid 2000 none}
01-01 00:01:01.652   244   247 D vold    : Remounting 2000 as mode none
01-01 00:01:01.661   244   247 D vold    : Found matching PID 268
01-01 00:01:01.661   244   247 W vold    : Skipping due to root namespace
01-01 00:01:01.661   244   247 D vold    : Found matching PID 269
01-01 00:01:01.662   379   446 D VoldConnector: RCV <- {200 10 Command succeeded}
01-01 00:01:01.665   379   379 D VoldConnector: SND -> {11 volume remount_uid 10025 none}
01-01 00:01:01.665   244   247 D vold    : Remounting 10025 as mode none
01-01 00:01:01.673   379   446 D VoldConnector: RCV <- {200 11 Command succeeded}
01-01 00:01:01.674   379   379 D VoldConnector: SND -> {12 volume remount_uid 10025 none}
01-01 00:01:01.675   244   247 D vold    : Remounting 10025 as mode none
01-01 00:01:01.682   379   446 D VoldConnector: RCV <- {200 12 Command succeeded}
01-01 00:01:01.686   379   379 D VoldConnector: SND -> {13 volume remount_uid 1002 none}
01-01 00:01:01.687   244   247 D vold    : Remounting 1002 as mode none
01-01 00:01:01.694   244   247 D vold    : Found matching PID 255
01-01 00:01:01.694   244   247 W vold    : Skipping due to root namespace
01-01 00:01:01.695   379   446 D VoldConnector: RCV <- {200 13 Command succeeded}
01-01 00:01:01.696   379   379 D VoldConnector: SND -> {14 volume remount_uid 1002 none}
01-01 00:01:01.698   244   247 D vold    : Remounting 1002 as mode none
01-01 00:01:01.704   244   247 D vold    : Found matching PID 255
01-01 00:01:01.704   244   247 W vold    : Skipping due to root namespace
01-01 00:01:01.705   379   446 D VoldConnector: RCV <- {200 14 Command succeeded}
01-01 00:01:01.710   379   379 I DefaultPermGrantPolicy: Granting permissions to default platform handlers for user 0
01-01 00:01:01.710   379   379 W VoiceInteractionManagerService: no available voice interaction services found for user 0
01-01 00:01:01.711   379   379 W VoiceInteractionManagerService: no available voice recognition services found for user 0
01-01 00:01:01.751   379   379 I SyncManager: No initial accounts
01-01 00:01:01.752   379   379 I SyncManager: No initial status
01-01 00:01:01.752   379   379 I SyncManager: No initial statistics
01-01 00:01:01.820   379   379 D VoldConnector: SND -> {15 volume remount_uid 10022 none}
01-01 00:01:01.821   244   247 D vold    : Remounting 10022 as mode none
01-01 00:01:01.832   379   446 D VoldConnector: RCV <- {200 15 Command succeeded}
01-01 00:01:01.835   379   379 D VoldConnector: SND -> {16 volume remount_uid 10041 none}
01-01 00:01:01.837   244   247 D vold    : Remounting 10041 as mode none
01-01 00:01:01.844   379   446 D VoldConnector: RCV <- {200 16 Command succeeded}
01-01 00:01:01.845   379   379 D VoldConnector: SND -> {17 volume remount_uid 10041 none}
01-01 00:01:01.847   244   247 D vold    : Remounting 10041 as mode none
01-01 00:01:01.854   379   446 D VoldConnector: RCV <- {200 17 Command succeeded}
01-01 00:01:01.856   379   379 D VoldConnector: SND -> {18 volume remount_uid 10010 none}
01-01 00:01:01.857   244   247 D vold    : Remounting 10010 as mode none
01-01 00:01:01.865   379   446 D VoldConnector: RCV <- {200 18 Command succeeded}
01-01 00:01:01.867   379   379 D VoldConnector: SND -> {19 volume remount_uid 10010 none}
01-01 00:01:01.869   244   247 D vold    : Remounting 10010 as mode none
01-01 00:01:01.877   379   446 D VoldConnector: RCV <- {200 19 Command succeeded}
01-01 00:01:01.879   379   379 D VoldConnector: SND -> {20 volume remount_uid 10012 none}
01-01 00:01:01.887   244   247 D vold    : Remounting 10012 as mode none
01-01 00:01:01.896   379   446 D VoldConnector: RCV <- {200 20 Command succeeded}
01-01 00:01:01.898   379   379 D VoldConnector: SND -> {21 volume remount_uid 10012 none}
01-01 00:01:01.900   244   247 D vold    : Remounting 10012 as mode none
01-01 00:01:01.906   379   389 I zygote  : Background concurrent copying GC freed 22095(1599KB) AllocSpace objects, 6(120KB) LOS objects, 42% free, 3MB/5MB, paused 206us total 105.081ms
01-01 00:01:01.911   379   446 D VoldConnector: RCV <- {200 21 Command succeeded}
01-01 00:01:01.922   379   379 D VoldConnector: SND -> {22 volume remount_uid 10002 none}
01-01 00:01:01.922   244   247 D vold    : Remounting 10002 as mode none
01-01 00:01:01.930   379   446 D VoldConnector: RCV <- {200 22 Command succeeded}
01-01 00:01:01.932   379   379 D VoldConnector: SND -> {23 volume remount_uid 10002 none}
01-01 00:01:01.932   244   247 D vold    : Remounting 10002 as mode none
01-01 00:01:01.941   379   446 D VoldConnector: RCV <- {200 23 Command succeeded}
01-01 00:01:01.951   379   379 D VoldConnector: SND -> {24 volume remount_uid 10046 none}
01-01 00:01:01.951   244   247 D vold    : Remounting 10046 as mode none
01-01 00:01:01.959   379   446 D VoldConnector: RCV <- {200 24 Command succeeded}
01-01 00:01:01.960   379   379 D VoldConnector: SND -> {25 volume remount_uid 10046 none}
01-01 00:01:01.961   244   247 D vold    : Remounting 10046 as mode none
01-01 00:01:01.968   379   446 D VoldConnector: RCV <- {200 25 Command succeeded}
01-01 00:01:01.971   379   379 D VoldConnector: SND -> {26 volume remount_uid 10050 none}
01-01 00:01:01.972   244   247 D vold    : Remounting 10050 as mode none
01-01 00:01:01.979   379   446 D VoldConnector: RCV <- {200 26 Command succeeded}
01-01 00:01:01.980   379   379 D VoldConnector: SND -> {27 volume remount_uid 10050 none}
01-01 00:01:01.981   244   247 D vold    : Remounting 10050 as mode none
01-01 00:01:01.991   379   446 D VoldConnector: RCV <- {200 27 Command succeeded}
01-01 00:01:01.995   379   379 D VoldConnector: SND -> {28 volume remount_uid 10024 none}
01-01 00:01:01.996   244   247 D vold    : Remounting 10024 as mode none
01-01 00:01:02.003   379   446 D VoldConnector: RCV <- {200 28 Command succeeded}
01-01 00:01:02.005   379   379 D VoldConnector: SND -> {29 volume remount_uid 10024 none}
01-01 00:01:02.005   244   247 D vold    : Remounting 10024 as mode none
01-01 00:01:02.012   379   446 D VoldConnector: RCV <- {200 29 Command succeeded}
01-01 00:01:02.017   379   379 V UserDataPreparer: Found /data/user_de/0 with serial number -1
01-01 00:01:02.017   379   379 D UserDataPreparer: Serial number missing on /data/user_de/0; assuming current is valid
01-01 00:01:02.018   379   379 V UserDataPreparer: Found /data/user/0 with serial number -1
01-01 00:01:02.018   379   379 D UserDataPreparer: Serial number missing on /data/user/0; assuming current is valid
01-01 00:01:02.019   379   379 V UserDataPreparer: Found /data/system_de/0 with serial number -1
01-01 00:01:02.019   379   379 D UserDataPreparer: Serial number missing on /data/system_de/0; assuming current is valid
01-01 00:01:02.019   379   379 D SystemServerTiming: MakePackageManagerServiceReady took to complete: 589ms
01-01 00:01:02.019   379   379 I SystemServer: MakeDisplayManagerServiceReady
01-01 00:01:02.020   379   379 D SystemServerTiming: MakeDisplayManagerServiceReady took to complete: 0ms
01-01 00:01:02.023   379   379 I ActivityManager: System now ready
01-01 00:01:02.030   379   379 I SystemServer: Making services ready
01-01 00:01:02.030   379   379 I SystemServer: StartActivityManagerReadyPhase
01-01 00:01:02.030   379   379 I SystemServiceManager: Starting phase 550
01-01 00:01:02.036   379   379 D BluetoothManagerService: Bluetooth boot completed
01-01 00:01:02.037   379   379 D BluetoothManagerService: Getting adapter name and address
01-01 00:01:02.037   379   400 D BluetoothManagerService: MESSAGE_GET_NAME_AND_ADDRESS
01-01 00:01:02.037   379   400 D BluetoothManagerService: Binding to service to get name and address
01-01 00:01:02.067   379   400 I ActivityManager: Start proc 486:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
01-01 00:01:02.084   486   486 W zygote  : Using default instruction set features for ARM CPU variant (cortex-a9) using conservative defaults
01-01 00:01:02.232   379   379 I ActivityManager: Start proc 505:com.android.inputmethod.latin/u0a54 for service com.android.inputmethod.latin/.LatinIME
01-01 00:01:02.240   379   379 W SystemServiceManager: Service com.android.server.InputMethodManagerService$Lifecycle took 202 ms in onBootPhase
01-01 00:01:02.241   379   445 D StorageManagerService: Thinking about init, mSystemReady=true, mDaemonConnected=true
01-01 00:01:02.241   379   445 D StorageManagerService: Setting up emulation state, initlocked=false
01-01 00:01:02.241   379   445 D CryptdConnector: SND -> {2 cryptfs unlock_user_key 0 0 ! !}
01-01 00:01:02.244   244   248 D vold    : e4crypt_unlock_user_key 0 serial=0 token_present=0
01-01 00:01:02.244   244   248 E vold    : Failed to chmod /data/system_ce/0: No such file or directory
01-01 00:01:02.244   244   248 E vold    : Failed to chmod /data/misc_ce/0: No such file or directory
01-01 00:01:02.244   244   248 E vold    : Failed to chmod /data/media/0: No such file or directory
01-01 00:01:02.246   379   447 D CryptdConnector: RCV <- {200 2 Command succeeded}
01-01 00:01:02.246   379   445 D StorageManagerService: Thinking about reset, mSystemReady=true, mDaemonConnected=true
01-01 00:01:02.248   379   394 I ActivityManager: Force stopping com.android.providers.media appid=10010 user=-1: vold reset
01-01 00:01:02.248   379   445 D VoldConnector: SND -> {30 volume reset}
01-01 00:01:02.250   379   446 D VoldConnector: RCV <- {651 emulated 7}
01-01 00:01:02.250   379   446 D VoldConnector: RCV <- {659 emulated}
01-01 00:01:02.251   379   446 D VoldConnector: RCV <- {650 emulated 2 "" ""}
01-01 00:01:02.252   379   446 D VoldConnector: RCV <- {651 emulated 0}
01-01 00:01:02.252   379   446 D VoldConnector: RCV <- {200 30 Command succeeded}
01-01 00:01:02.253   379   445 D VoldConnector: SND -> {31 volume user_added 0 0}
01-01 00:01:02.253   379   399 V StorageManagerService: Found primary storage at VolumeInfo{emulated}:
01-01 00:01:02.253   379   399 V StorageManagerService:     type=EMULATED diskId=null partGuid=null mountFlags=0 mountUserId=-1
01-01 00:01:02.253   379   399 V StorageManagerService:     state=UNMOUNTED
01-01 00:01:02.253   379   399 V StorageManagerService:     fsType=null fsUuid=null fsLabel=null
01-01 00:01:02.253   379   399 V StorageManagerService:     path=null internalPath=null
01-01 00:01:02.254   379   446 D VoldConnector: RCV <- {200 31 Command succeeded}
01-01 00:01:02.256   379   471 D BluetoothManagerService: Trying to bind to profile: 1, while Bluetooth was disabled
01-01 00:01:02.260   379   445 D VoldConnector: SND -> {32 volume mount emulated 3 -1}
01-01 00:01:02.264   263   263 E android.hardware.usb@1.0-service: Failed to open /sys/class/dual_role_usb
01-01 00:01:02.264   244   247 V vold    : Waiting for FUSE to spin up...
01-01 00:01:02.266   379   446 D VoldConnector: RCV <- {651 emulated 1}
01-01 00:01:02.267   379   446 D VoldConnector: RCV <- {656 emulated /data/media}
01-01 00:01:02.267   379   446 D VoldConnector: RCV <- {655 emulated /storage/emulated}
01-01 00:01:02.280   270   367 I AudioFlinger: systemReady
01-01 00:01:02.283   379   379 D SystemServerTiming: StartActivityManagerReadyPhase took to complete: 253ms
01-01 00:01:02.283   379   379 I SystemServer: StartObservingNativeCrashes
01-01 00:01:02.289   379   379 D SystemServerTiming: StartObservingNativeCrashes took to complete: 5ms
01-01 00:01:02.290   379   392 D SystemServerInitThreadPool: Started executing WebViewFactoryPreparation
01-01 00:01:02.290   379   392 I SystemServer: WebViewFactoryPreparation
01-01 00:01:02.292   505   505 W zygote  : Using default instruction set features for ARM CPU variant (cortex-a9) using conservative defaults
01-01 00:01:02.292   379   379 I SystemServer: StartSystemUI
01-01 00:01:02.315   244   247 V vold    : Waiting for FUSE to spin up...
01-01 00:01:02.339   379   379 I ActivityManager: Start proc 518:com.android.systemui/u0a25 for service com.android.systemui/.SystemUIService
01-01 00:01:02.341   379   379 D SystemServerTiming: StartSystemUI took to complete: 48ms
01-01 00:01:02.347   379   379 I SystemServer: MakeNetworkScoreReady
01-01 00:01:02.349   379   379 D SystemServerTiming: MakeNetworkScoreReady took to complete: 2ms
01-01 00:01:02.349   379   379 I SystemServer: MakeNetworkManagementServiceReady
01-01 00:01:02.349   379   379 D NetworkManagement: enabling bandwidth control
01-01 00:01:02.365   244   247 V vold    : Waiting for FUSE to spin up...
01-01 00:01:02.378   379   392 D WebViewFactory: Setting new address space to 104857600
01-01 00:01:02.392   518   518 W zygote  : Using default instruction set features for ARM CPU variant (cortex-a9) using conservative defaults
01-01 00:01:02.399   379   397 E BatteryStatsService: no controller energy info supplied
01-01 00:01:02.415   244   247 V vold    : Waiting for FUSE to spin up...
01-01 00:01:02.421   511   511 W /system/bin/sdcard: Device explicitly enabled sdcardfs
01-01 00:01:02.441   379   379 W NetworkManagement: setDataSaverMode(): already false
01-01 00:01:02.445   379   379 D SystemServerTiming: MakeNetworkManagementServiceReady took to complete: 97ms
01-01 00:01:02.445   379   379 I SystemServer: MakeNetworkStatsServiceReady
01-01 00:01:02.466   244   247 V vold    : Waiting for FUSE to spin up...
01-01 00:01:02.468   379   456 D NetworkPolicy: setRestrictBackgroundUL(): false
01-01 00:01:02.482   379   392 W ActivityManager: Slow operation: 91ms so far, now at startProcess: returned from zygote!
01-01 00:01:02.482   379   392 W ActivityManager: Slow operation: 91ms so far, now at startProcess: done updating battery stats
01-01 00:01:02.482   379   392 W ActivityManager: Slow operation: 91ms so far, now at startProcess: building log message
01-01 00:01:02.482   379   392 I ActivityManager: Start proc 530:WebViewLoader-armeabi-v7a/1037 [android.webkit.WebViewFactory$RelroFileCreator] for
01-01 00:01:02.482   379   392 W ActivityManager: Slow operation: 92ms so far, now at startProcess: starting to update pids map
01-01 00:01:02.482   379   392 W ActivityManager: Slow operation: 92ms so far, now at startProcess: done updating pids map
01-01 00:01:02.482   379   392 W ActivityManager: Slow operation: 93ms so far, now at startProcess: done starting proc!
01-01 00:01:02.496   379   456 W NetworkManagement: setDataSaverMode(): already false
01-01 00:01:02.504   379   392 D SystemServerTimingAsync: WebViewFactoryPreparation took to complete: 213ms
01-01 00:01:02.504   379   392 D SystemServerInitThreadPool: Finished executing WebViewFactoryPreparation
01-01 00:01:02.517   244   247 V vold    : Waiting for FUSE to spin up...
01-01 00:01:02.520   379   379 D SystemServerTiming: MakeNetworkStatsServiceReady took to complete: 74ms
01-01 00:01:02.520   379   379 I SystemServer: MakeConnectivityServiceReady
01-01 00:01:02.531   379   480 D Ethernet: got request NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
01-01 00:01:02.531   379   379 D PermissionMonitor: Monitoring
01-01 00:01:02.541   530   530 W zygote  : Using default instruction set features for ARM CPU variant (cortex-a9) using conservative defaults
01-01 00:01:02.551   379   379 D PermissionMonitor: Users: 1, Apps: 64
01-01 00:01:02.567   244   247 V vold    : Waiting for FUSE to spin up...
01-01 00:01:02.570   379   379 D SystemServerTiming: MakeConnectivityServiceReady took to complete: 49ms
01-01 00:01:02.570   379   379 I SystemServer: MakeNetworkPolicyServiceReady
01-01 00:01:02.586   530   530 V WebViewFactory: RelroFileCreator (64bit = false),  32-bit lib: /system/app/webview/webview.apk!/lib/armeabi-v7a/libwebviewchromium.so, 64-bit lib:
01-01 00:01:02.599   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:02.601   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:02.604   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:02.605   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:02.606   282   310 I OMXMaster: makeComponentInstance(OMX.google.gsm.decoder) in omx@1.0-service process
01-01 00:01:02.617   244   247 V vold    : Waiting for FUSE to spin up...
01-01 00:01:02.639   379   379 D SystemServerTiming: MakeNetworkPolicyServiceReady took to complete: 69ms
01-01 00:01:02.639   379   379 I SystemServer: StartWatchdog
01-01 00:01:02.640   379   379 D SystemServerTiming: StartWatchdog took to complete: 0ms
01-01 00:01:02.640   379   379 I SystemServer: PhaseThirdPartyAppsCanStart
01-01 00:01:02.640   379   379 I SystemServiceManager: Starting phase 600
01-01 00:01:02.645   379   379 E LightsService: Light requested not available on this device. 4
01-01 00:01:02.672   244   247 V vold    : Waiting for FUSE to spin up...
01-01 00:01:02.675   379   379 V WallpaperManagerService: bindWallpaperComponentLocked: componentName=null
01-01 00:01:02.675   379   379 V WallpaperManagerService: No default component; using image wallpaper
01-01 00:01:02.722   379   379 W SystemServiceManager: Service com.android.server.wallpaper.WallpaperManagerService$Lifecycle took 56 ms in onBootPhase
01-01 00:01:02.723   379   446 D VoldConnector: RCV <- {651 emulated 2}
01-01 00:01:02.724   379   446 D VoldConnector: RCV <- {200 32 Command succeeded}
01-01 00:01:02.768   379   379 D SystemServerTiming: PhaseThirdPartyAppsCanStart took to complete: 129ms
01-01 00:01:02.768   379   379 I SystemServer: MakeLocationServiceReady
01-01 00:01:02.794   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.gnss@1.0::IGnss/default in either framework or device manifest.
01-01 00:01:02.799   379   379 E GnssLocationProvider: Unable to get GPS service
01-01 00:01:02.802   379   379 W LocationManagerService: no network location provider found
01-01 00:01:02.829   379   379 E LocationManagerService: no geocoder provider found
01-01 00:01:02.831   379   379 D LocationManagerService: FLP HAL not supported
01-01 00:01:02.868   379   379 D LocationManagerService: Unable to bind FLP Geofence proxy.
01-01 00:01:02.868   379   379 E ActivityRecognitionHardware: activity_recognition HAL is deprecated. is_supported is effectively a no-op
01-01 00:01:02.868   379   379 D LocationManagerService: Hardware Activity-Recognition not supported.
01-01 00:01:02.869   379   379 E ActivityRecognitionProxy: ServiceWatcher could not start.
01-01 00:01:02.870   379   379 D LocationManagerService: Unable to bind ActivityRecognitionProxy.
01-01 00:01:02.875   379   379 D SystemServerTiming: MakeLocationServiceReady took to complete: 107ms
01-01 00:01:02.875   379   379 I SystemServer: MakeCountryDetectionServiceReady
01-01 00:01:02.876   379   379 D SystemServerTiming: MakeCountryDetectionServiceReady took to complete: 0ms
01-01 00:01:02.876   379   379 I SystemServer: MakeNetworkTimeUpdateReady
01-01 00:01:02.904   379   379 D ConnectivityService: requestNetwork for uid/pid:1000/379 NetworkRequest [ TRACK_DEFAULT id=4, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ]
01-01 00:01:02.906   379   379 D SystemServerTiming: MakeNetworkTimeUpdateReady took to complete: 30ms
01-01 00:01:02.906   379   379 I SystemServer: MakeCommonTimeManagementServiceReady
01-01 00:01:02.906   379   480 D Ethernet: got request NetworkRequest [ TRACK_DEFAULT id=4, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
01-01 00:01:02.907   379   379 I CommonTimeManagementService: No common time service detected on this platform.  Common time services will be unavailable.
01-01 00:01:02.907   379   379 D SystemServerTiming: MakeCommonTimeManagementServiceReady took to complete: 1ms
01-01 00:01:02.907   379   379 I SystemServer: MakeInputManagerServiceReady
01-01 00:01:02.920   379   444 I InputReader: Reconfiguring input devices.  changes=0x00000020
01-01 00:01:02.925   379   379 D SystemServerTiming: MakeInputManagerServiceReady took to complete: 19ms
01-01 00:01:02.926   379   379 I SystemServer: MakeTelephonyRegistryReady
01-01 00:01:02.927   379   379 D SystemServerTiming: MakeTelephonyRegistryReady took to complete: 1ms
01-01 00:01:02.933   379   379 I SystemServer: MakeMediaRouterServiceReady
01-01 00:01:02.934   379   444 I InputReader: Reconfiguring input devices.  changes=0x00000010
01-01 00:01:02.935   379   379 D SystemServerTiming: MakeMediaRouterServiceReady took to complete: 1ms
01-01 00:01:02.935   379   379 I SystemServer: MakeMmsServiceReady
01-01 00:01:02.935   379   379 I MmsServiceBroker: Delay connecting to MmsService until an API is called
01-01 00:01:02.935   379   379 D SystemServerTiming: MakeMmsServiceReady took to complete: 0ms
01-01 00:01:02.936   379   379 I SystemServer: MakeNetworkScoreServiceReady
01-01 00:01:02.936   379   379 D SystemServerTiming: MakeNetworkScoreServiceReady took to complete: 0ms
01-01 00:01:02.936   379   379 I SystemServer: IncidentDaemonReady
01-01 00:01:02.937   379   379 D SystemServerTiming: IncidentDaemonReady took to complete: 1ms
01-01 00:01:02.937   379   379 I SystemServiceManager: Calling onStartUser u0
01-01 00:01:02.989   379   379 W VoiceInteractionManagerService: no available voice interaction services found for user 0
01-01 00:01:02.989   379   379 W VoiceInteractionManagerService: no available voice recognition services found for user 0
01-01 00:01:03.014   530   530 I zygote  : System.exit called, status: 0
01-01 00:01:03.015   530   530 I AndroidRuntime: VM exiting with result code 0, cleanup skipped.
01-01 00:01:03.106   379   379 W ActivityManager: Slow operation: 75ms so far, now at startProcess: returned from zygote!
01-01 00:01:03.107   379   379 W ActivityManager: Slow operation: 75ms so far, now at startProcess: done updating battery stats
01-01 00:01:03.107   379   379 W ActivityManager: Slow operation: 75ms so far, now at startProcess: building log message
01-01 00:01:03.107   379   379 I ActivityManager: Start proc 566:com.android.phone/1001 for added application com.android.phone
01-01 00:01:03.107   379   379 W ActivityManager: Slow operation: 75ms so far, now at startProcess: starting to update pids map
01-01 00:01:03.107   379   379 W ActivityManager: Slow operation: 76ms so far, now at startProcess: done updating pids map
01-01 00:01:03.111   379   379 I ActivityManager: START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000100 cmp=com.android.settings/.CryptKeeper} from uid 0
01-01 00:01:03.150   566   566 W zygote  : Using default instruction set features for ARM CPU variant (cortex-a9) using conservative defaults
01-01 00:01:03.160   379   379 I ActivityManager: Loaded persisted task ids for user 0
01-01 00:01:03.207   505   505 I LatinIME: Hardware accelerated drawing: true
01-01 00:01:03.295   575   575 W zygote  : Using default instruction set features for ARM CPU variant (cortex-a9) using conservative defaults
01-01 00:01:03.310   379   379 W ActivityManager: Slow operation: 98ms so far, now at startProcess: returned from zygote!
01-01 00:01:03.311   379   379 W ActivityManager: Slow operation: 98ms so far, now at startProcess: done updating battery stats
01-01 00:01:03.311   379   379 W ActivityManager: Slow operation: 98ms so far, now at startProcess: building log message
01-01 00:01:03.311   379   379 I ActivityManager: Start proc 575:com.android.settings:CryptKeeper/1000 for activity com.android.settings/.CryptKeeper
01-01 00:01:03.311   379   379 W ActivityManager: Slow operation: 98ms so far, now at startProcess: starting to update pids map
01-01 00:01:03.311   379   379 W ActivityManager: Slow operation: 99ms so far, now at startProcess: done updating pids map
01-01 00:01:03.311   379   379 W ActivityManager: Slow operation: 99ms so far, now at startProcess: done starting proc!
01-01 00:01:03.319   379   379 D SystemServerTiming: ActivityManagerStartApps took to complete: 381ms
01-01 00:01:03.319   379   379 D SystemServerTiming: PhaseActivityManagerReady took to complete: 1299ms
01-01 00:01:03.336   379   379 D SystemServerInitThreadPool: Shutdown successful
01-01 00:01:03.340   379   379 D SystemServerTiming: StartServices took to complete: 25804ms
01-01 00:01:03.344   379   379 I SystemServer: Enabled StrictMode for system server main thread.
01-01 00:01:03.348   486   486 D AdapterServiceConfig: Adding HeadsetService
01-01 00:01:03.348   486   486 D AdapterServiceConfig: Adding A2dpService
01-01 00:01:03.348   486   486 D AdapterServiceConfig: Adding HidService
01-01 00:01:03.349   486   486 D AdapterServiceConfig: Adding HealthService
01-01 00:01:03.349   486   486 D AdapterServiceConfig: Adding PanService
01-01 00:01:03.349   486   486 D AdapterServiceConfig: Adding GattService
01-01 00:01:03.349   486   486 D AdapterServiceConfig: Adding BluetoothMapService
01-01 00:01:03.349   486   486 D AdapterServiceConfig: Adding AvrcpControllerService
01-01 00:01:03.350   486   486 W AdapterServiceConfig: Could not find profile bit mask
01-01 00:01:03.358   379   395 W Looper  : Dispatch took 327ms on android.ui, h=Handler (com.android.server.am.ActivityManagerService$UiHandler) {b2b6791} cb=null msg=53
01-01 00:01:03.378   486   486 D AdapterServiceConfig: Adding BluetoothOppService
01-01 00:01:03.378   486   486 W AdapterServiceConfig: Could not find profile bit mask
01-01 00:01:03.378   486   486 D AdapterServiceConfig: Adding BluetoothPbapService
01-01 00:01:03.385   379   379 D ConditionProviders.SCP: onConnected
01-01 00:01:03.517   379   399 I UsbDeviceManager: Setting USB config to mtp,adb
01-01 00:01:03.518   379   461 I WifiScanningService: wifi driver unloaded
01-01 00:01:03.519   379   379 D RttService: SCAN_AVAILABLE : 1
01-01 00:01:03.520   379   462 D RttService: DefaultState got{ when=0 what=160513 target=com.android.internal.util.StateMachine$SmHandler }
01-01 00:01:03.574   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:03.583   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:03.583   282   312 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_encoder.mpeg4.hw-based) in omx@1.0-service process
01-01 00:01:03.593   379   586 W ActivityManager: Slow operation: 85ms so far, now at attachApplicationLocked: after mServices.attachApplicationLocked
01-01 00:01:03.595   379   379 D ZenLog  : set_zen_mode: off,cleanUpZenRules
01-01 00:01:03.603   379   379 D ConditionProviders: Subscribing to condition://android/event?userId=-10000&calendar=&reply=1 with ComponentInfo{android/com.android.server.notification.EventConditionProvider}
01-01 00:01:03.604   379   379 D ZenLog  : subscribe: condition://android/event?userId=-10000&calendar=&reply=1,ok
01-01 00:01:03.604   379   379 D ConditionProviders: Subscribing to condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false with ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider}
01-01 00:01:03.604   379   379 D ZenLog  : subscribe: condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,ok
01-01 00:01:03.605   379   379 D ConditionProviders: Subscribing to condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false with ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider}
01-01 00:01:03.605   379   379 D ZenLog  : subscribe: condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false,ok
01-01 00:01:03.641   575   589 E zygote  : Weird, can't send JDWP process pid to ADB: Connection reset by peer
01-01 00:01:03.665   518   518 V SystemUIService: Starting SystemUI services for user 0.
01-01 00:01:03.843   282   312 I vpu-lib : Product Info: i.MX6Q/D/S
01-01 00:01:03.849   279   279 W OMXUtils: do not know color format 0x7f000789 = 2130708361
01-01 00:01:03.850   282   312 I OMXPlayer: LEVEL: 1 FUNCTION: GetConfig LINE: 1838
01-01 00:01:03.850   282   312 I OMXPlayer: GetConfig: failure: unsupported index: 0x6F60000A
01-01 00:01:03.850   282   312 E OMXNodeInstance: getConfig(0xb4a78000:Freescale.std._encoder.mpeg4.hw-based, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:03.850   282   310 I OMXPlayer: LEVEL: 1 FUNCTION: DeInitFilterComponent LINE: 2015
01-01 00:01:03.851   282   310 I OMXPlayer: DeInitFilterComponent: vpu close failure: ret=0x3
01-01 00:01:03.854   608   609 I adbd    : initializing functionfs
01-01 00:01:03.855   608   609 I adbd    : opening control endpoint /dev/usb-ffs/adb/ep0
01-01 00:01:03.874   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:03.875   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:03.876   282   310 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_encoder.h263.hw-based) in omx@1.0-service process
01-01 00:01:03.929   505   505 W InputAttributes: No editor info for this field. Bug?
01-01 00:01:03.942   486   486 D BluetoothAdapterService: onCreate()
01-01 00:01:03.952   486   486 D BluetoothAdapterState: make() - Creating AdapterState
01-01 00:01:03.957   282   310 I vpu-lib : Product Info: i.MX6Q/D/S
01-01 00:01:03.959   486   486 I bt_btif : init
01-01 00:01:03.959   486   613 I BluetoothAdapterState: Entering OffState
01-01 00:01:03.994   379   389 I zygote  : Background concurrent copying GC freed 30124(2MB) AllocSpace objects, 7(156KB) LOS objects, 42% free, 5MB/8MB, paused 4.089ms total 1.086s
01-01 00:01:04.003   279   279 W OMXUtils: do not know color format 0x7f000789 = 2130708361
01-01 00:01:04.003   282   310 I OMXPlayer: LEVEL: 1 FUNCTION: GetConfig LINE: 1838
01-01 00:01:04.003   282   310 I OMXPlayer: GetConfig: failure: unsupported index: 0x6F60000A
01-01 00:01:04.008   282   310 E OMXNodeInstance: getConfig(0xb4a78000:Freescale.std._encoder.h263.hw-based, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:04.017   282   312 I OMXPlayer: LEVEL: 1 FUNCTION: DeInitFilterComponent LINE: 2015
01-01 00:01:04.017   282   312 I OMXPlayer: DeInitFilterComponent: vpu close failure: ret=0x3
01-01 00:01:04.023   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:04.024   486   486 D bt_osi_allocation_tracker: canary initialized
01-01 00:01:04.026   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:04.026   282   312 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_encoder.avc.hw-based) in omx@1.0-service process
01-01 00:01:04.045   486   615 I bt_osi_thread: run_thread: thread id 615, thread name stack_manager started
01-01 00:01:04.050   486   615 I bt_stack_manager: event_init_stack is initializing the stack
01-01 00:01:04.053   379   379 I AccountsDb: Creating DE database for user 0
01-01 00:01:04.077   486   615 E bt_osi_config: config_new unable to open file '/data/misc/bluedroid/bt_config.conf': No such file or directory
01-01 00:01:04.078   486   615 W bt_btif_config: init unable to load config file: /data/misc/bluedroid/bt_config.conf; using backup.
01-01 00:01:04.078   486   615 E bt_osi_config: config_new unable to open file '/data/misc/bluedroid/bt_config.bak': No such file or directory
01-01 00:01:04.078   486   615 W bt_btif_config: init unable to load backup; attempting to transcode legacy file.
01-01 00:01:04.085   282   312 I vpu-lib : Product Info: i.MX6Q/D/S
01-01 00:01:04.086   486   615 E bt_btif_config_transcode: btif_config_transcode unable to load XML file '/data/misc/bluedroid/bt_config.xml': 3
01-01 00:01:04.086   486   615 E bt_btif_config: init unable to transcode legacy file; creating empty config.
01-01 00:01:04.123   279   279 W OMXUtils: do not know color format 0x7f000789 = 2130708361
01-01 00:01:04.124   282   611 I OMXPlayer: LEVEL: 1 FUNCTION: GetConfig LINE: 1838
01-01 00:01:04.124   282   611 I OMXPlayer: GetConfig: failure: unsupported index: 0x6F60000A
01-01 00:01:04.124   282   611 E OMXNodeInstance: getConfig(0xb4a78000:Freescale.std._encoder.avc.hw-based, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:04.124   282   310 I OMXPlayer: LEVEL: 1 FUNCTION: DeInitFilterComponent LINE: 2015
01-01 00:01:04.124   282   310 I OMXPlayer: DeInitFilterComponent: vpu close failure: ret=0x3
01-01 00:01:04.128   486   621 I bt_osi_thread: run_thread: thread id 621, thread name alarm_default_ca started
01-01 00:01:04.131   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:04.134   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:04.134   282   310 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.avc.v3.hw-based) in omx@1.0-service process
01-01 00:01:04.140   518   518 V MediaRouter: Adding route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO  groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
01-01 00:01:04.145   486   623 I bt_osi_thread: run_thread: thread id 623, thread name alarm_dispatcher started
01-01 00:01:04.158   486   615 I bt_stack_config: init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
01-01 00:01:04.172   505   622 I LatinIME:LogUtils: Dictionary info: dictionary = UserHistoryDictionary.en_US ; version = 64 ; date = ?
01-01 00:01:04.193   505   622 I LatinIME:LogUtils: Dictionary info: dictionary = userunigram.en_US ; version = 64 ; date = ?
01-01 00:01:04.205   505   622 E ActivityThread: Failed to find provider info for user_dictionary
01-01 00:01:04.207   486   626 I bt_osi_thread: run_thread: thread id 626, thread name bt_jni_workqueue started
01-01 00:01:04.216   518   518 V MediaRouter: Selecting route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=System types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO  groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
01-01 00:01:04.223   486   615 I bt_stack_manager: event_init_stack finished
01-01 00:01:04.247   486   486 I bt_osi_wakelock: wakelock_set_os_callouts set to non-native
01-01 00:01:04.247   486   486 I bt_btif : get_profile_interface: id = socket
01-01 00:01:04.247   486   486 W bt_btif : do_in_jni_thread: Dropped message, message_loop not initialized yet!
01-01 00:01:04.270   379   379 W Binder:379_4: type=1400 audit(0.0:9): avc: denied { write } for name="timerslack_ns" dev="proc" ino=14766 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:04.270   379   379 W Binder:379_4: type=1400 audit(0.0:10): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15578 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:04.270   379   379 W Binder:379_4: type=1400 audit(0.0:11): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15580 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:04.270   379   379 W Binder:379_4: type=1400 audit(0.0:12): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15582 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:04.270   379   379 W Binder:379_4: type=1400 audit(0.0:13): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15584 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:04.270   379   379 W Binder:379_4: type=1400 audit(0.0:14): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15586 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:04.270   379   379 W Binder:379_4: type=1400 audit(0.0:15): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15588 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:04.270   379   379 W Binder:379_4: type=1400 audit(0.0:16): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15590 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:04.270   379   379 W Binder:379_4: type=1400 audit(0.0:17): avc: denied { write } for name="timerslack_ns" dev="proc" ino=14805 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:04.270   379   379 W Binder:379_4: type=1400 audit(0.0:18): avc: denied { write } for name="timerslack_ns" dev="proc" ino=14221 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:04.270   379   379 W Binder:379_4: type=1400 audit(0.0:19): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15592 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:04.270   379   379 W Binder:379_4: type=1400 audit(0.0:20): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15541 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:04.270   379   379 W Binder:379_4: type=1400 audit(0.0:21): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15594 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:04.271   279   279 W ACodec  : [OMX.Freescale.std.video_decoder.avc.v3.hw-based] stopping checking profiles after 32: 8/1
01-01 00:01:04.276   282   310 E OMXNodeInstance: getExtensionIndex(0xb4a78000:Freescale.std._decoder.avc.v3.hw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006)
01-01 00:01:04.276   282   611 W OMXNodeInstance: [0xb4a78000:Freescale.std._decoder.avc.v3.hw-based] component does not support metadata mode; using fallback
01-01 00:01:04.282   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:04.311   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:04.312   282   611 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.mpeg4.hw-based) in omx@1.0-service process
01-01 00:01:04.330   486   486 I bt_btif : get_profile_interface: id = sdp
01-01 00:01:04.334   486   486 I BluetoothAdapterService: Phone policy enabled
01-01 00:01:04.346   486   486 D BluetoothAdapterService: setAdapterService() - set to: null
01-01 00:01:04.359   486   486 D BluetoothAdapterService: onBind()
01-01 00:01:04.365   282   310 E OMXNodeInstance: getExtensionIndex(0xb4a78600:Freescale.std._decoder.mpeg4.hw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006)
01-01 00:01:04.365   282   611 W OMXNodeInstance: [0xb4a78600:Freescale.std._decoder.mpeg4.hw-based] component does not support metadata mode; using fallback
01-01 00:01:04.397   575   575 D CryptKeeper: Disabling component ComponentInfo{com.android.settings/com.android.settings.CryptKeeper}
01-01 00:01:04.399   379   391 D PackageManager: Ephemeral installer not found with new action; try old one
01-01 00:01:04.399   379   391 D PackageManager: Clear ephemeral installer activity
01-01 00:01:04.430   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:04.443   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:04.446   379   391 I ActivityManager: START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000100 cmp=com.android.settings/.FallbackHome} from uid 0
01-01 00:01:04.448   282   310 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.h263.hw-based) in omx@1.0-service process
01-01 00:01:04.470   282   611 E OMXNodeInstance: getExtensionIndex(0xb4a78600:Freescale.std._decoder.h263.hw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006)
01-01 00:01:04.470   282   611 W OMXNodeInstance: [0xb4a78600:Freescale.std._decoder.h263.hw-based] component does not support metadata mode; using fallback
01-01 00:01:04.480   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:04.485   379   379 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1479 com.android.server.content.SyncManager$13.run:701 android.os.Handler.handleCallback:789 android.os.Handler.dispatchMessage:98 android.os.Looper.loop:164
01-01 00:01:04.488   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:04.489   282   312 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.mpeg2.hw-based) in omx@1.0-service process
01-01 00:01:04.553   282   310 E OMXNodeInstance: getExtensionIndex(0xb4a78600:Freescale.std._decoder.mpeg2.hw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006)
01-01 00:01:04.553   282   611 W OMXNodeInstance: [0xb4a78600:Freescale.std._decoder.mpeg2.hw-based] component does not support metadata mode; using fallback
01-01 00:01:04.581   505   622 I BinaryDictionaryFileDumper: reinitializeClientRecordInDictionaryContentProvider() : MetadataFileUri =
01-01 00:01:04.593   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:04.595   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:04.595   282   611 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.vpx.hw-based) in omx@1.0-service process
01-01 00:01:04.614   646   646 W zygote  : Using default instruction set features for ARM CPU variant (cortex-a9) using conservative defaults
01-01 00:01:04.622   282   310 E OMXNodeInstance: getExtensionIndex(0xb4a78600:Freescale.std._decoder.vpx.hw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006)
01-01 00:01:04.622   282   312 W OMXNodeInstance: [0xb4a78600:Freescale.std._decoder.vpx.hw-based] component does not support metadata mode; using fallback
01-01 00:01:04.632   379   391 W ActivityManager: Slow operation: 173ms so far, now at startProcess: returned from zygote!
01-01 00:01:04.632   379   391 W ActivityManager: Slow operation: 173ms so far, now at startProcess: done updating battery stats
01-01 00:01:04.632   379   391 W ActivityManager: Slow operation: 173ms so far, now at startProcess: building log message
01-01 00:01:04.632   379   391 I ActivityManager: Start proc 646:com.android.settings/1000 for activity com.android.settings/.FallbackHome
01-01 00:01:04.632   379   391 W ActivityManager: Slow operation: 174ms so far, now at startProcess: starting to update pids map
01-01 00:01:04.632   379   391 W ActivityManager: Slow operation: 174ms so far, now at startProcess: done updating pids map
01-01 00:01:04.632   379   391 W ActivityManager: Slow operation: 174ms so far, now at startProcess: done starting proc!
01-01 00:01:04.636   379   394 W zygote  : Long monitor contention with owner Binder:379_2 (391) at void com.android.server.am.ActivityManagerService.activityPaused(android.os.IBinder)(ActivityManagerService.java:7319) waiters=0 in void com.android.server.am.TaskChangeNotificationController.forAllRemoteListeners(com.android.server.am.TaskChangeNotificationController$TaskStackConsumer, android.os.Message) for 188ms
01-01 00:01:04.640   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:04.651   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:04.651   282   312 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.soft_hevc.sw-based) in omx@1.0-service process
01-01 00:01:04.716   282   611 E OMXNodeInstance: getParameter(0xb4a78600:Freescale.std._decoder.soft_hevc.sw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:04.718   282   310 E OMXNodeInstance: getExtensionIndex(0xb4a78600:Freescale.std._decoder.soft_hevc.sw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006)
01-01 00:01:04.718   282   611 W OMXNodeInstance: [0xb4a78600:Freescale.std._decoder.soft_hevc.sw-based] component does not support metadata mode; using fallback
01-01 00:01:04.736   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:04.738   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:04.739   282   611 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.wmv.sw-based) in omx@1.0-service process
01-01 00:01:04.778   282   611 I OMXPlayer: Can't open library: lib_WMV789_dec_v2_arm11_elinux.so
01-01 00:01:04.779   282   611 I OMXPlayer: dlopen failed: library "lib_WMV789_dec_v2_arm11_elinux.so" not found
01-01 00:01:04.791   282   611 I OMXPlayer: LEVEL: 1 FUNCTION: ConstructComponent LINE: 574
01-01 00:01:04.791   282   611 I OMXPlayer: Can't initialize component.
01-01 00:01:04.791   282   611 I OMXPlayer: LEVEL: 1 FUNCTION: OMX_GetHandle LINE: 498
01-01 00:01:04.791   282   611 I OMXPlayer: Load and call entry function fail.
01-01 00:01:04.791   282   611 E /vendor/bin/hw/android.hardware.media.omx@1.0-service: Failed to allocate omx component 'OMX.Freescale.std.video_decoder.wmv.sw-based'  err=ComponentNotFound(0x80001003)
01-01 00:01:04.796   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:04.804   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:04.804   282   310 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.wmv9.hw-based) in omx@1.0-service process
01-01 00:01:04.804   282   310 E /vendor/bin/hw/android.hardware.media.omx@1.0-service: Failed to allocate omx component 'OMX.Freescale.std.video_decoder.wmv9.hw-based'  err=InvalidComponentName(0x80001002)
01-01 00:01:04.807   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:04.810   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:04.811   282   312 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.rv.hw-based) in omx@1.0-service process
01-01 00:01:04.822   379   399 E UsbDeviceManager: waitForState(mtp,adb) FAILED: got none
01-01 00:01:04.822   379   399 E UsbDeviceManager: Failed to switch USB config to mtp,adb
01-01 00:01:04.822   379   399 E UsbDeviceManager: Failsafe 2: Restoring default USB functions.
01-01 00:01:04.823   379   399 I UsbDeviceManager: Setting USB config to adb
01-01 00:01:04.851   518   518 W SoundPool: Use of stream types is deprecated for operations other than volume control
01-01 00:01:04.851   518   518 W SoundPool: See the documentation of SoundPool() for what to use instead with android.media.AudioAttributes to qualify your playback use case
01-01 00:01:04.888   282   611 E OMXNodeInstance: getParameter(0xb4a78300:Freescale.std._decoder.rv.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:04.891   282   611 E OMXNodeInstance: getExtensionIndex(0xb4a78300:Freescale.std._decoder.rv.hw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006)
01-01 00:01:04.891   282   310 W OMXNodeInstance: [0xb4a78300:Freescale.std._decoder.rv.hw-based] component does not support metadata mode; using fallback
01-01 00:01:04.898   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:04.900   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:04.900   282   310 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.divx.hw-based) in omx@1.0-service process
01-01 00:01:04.928   282   611 E OMXNodeInstance: getParameter(0xb4a78300:Freescale.std._decoder.divx.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:04.949   282   611 E OMXNodeInstance: getExtensionIndex(0xb4a78300:Freescale.std._decoder.divx.hw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006)
01-01 00:01:04.950   282   312 W OMXNodeInstance: [0xb4a78300:Freescale.std._decoder.divx.hw-based] component does not support metadata mode; using fallback
01-01 00:01:04.959   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:04.962   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:04.963   282   310 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.div4.hw-based) in omx@1.0-service process
01-01 00:01:05.031   282   611 E OMXNodeInstance: getParameter(0xb4a78000:Freescale.std._decoder.div4.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:05.033   282   310 E OMXNodeInstance: getExtensionIndex(0xb4a78000:Freescale.std._decoder.div4.hw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006)
01-01 00:01:05.033   282   674 W OMXNodeInstance: [0xb4a78000:Freescale.std._decoder.div4.hw-based] component does not support metadata mode; using fallback
01-01 00:01:05.036   670   676 I adbd    : initializing functionfs
01-01 00:01:05.038   670   676 I adbd    : opening control endpoint /dev/usb-ffs/adb/ep0
01-01 00:01:05.038   379   400 E BluetoothManagerService: MESSAGE_TIMEOUT_BIND
01-01 00:01:05.060   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:05.061   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:05.062   282   312 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.div3.hw-based) in omx@1.0-service process
01-01 00:01:05.062   282   312 E /vendor/bin/hw/android.hardware.media.omx@1.0-service: Failed to allocate omx component 'OMX.Freescale.std.video_decoder.div3.hw-based'  err=InvalidComponentName(0x80001002)
01-01 00:01:05.064   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:05.066   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:05.066   282   310 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.xvid.hw-based) in omx@1.0-service process
01-01 00:01:05.075   282   312 E OMXNodeInstance: getParameter(0xb465e000:Freescale.std._decoder.xvid.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:05.079   282   312 E OMXNodeInstance: getExtensionIndex(0xb465e000:Freescale.std._decoder.xvid.hw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006)
01-01 00:01:05.080   282   611 W OMXNodeInstance: [0xb465e000:Freescale.std._decoder.xvid.hw-based] component does not support metadata mode; using fallback
01-01 00:01:05.096   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:05.098   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:05.099   282   310 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.mjpeg.hw-based) in omx@1.0-service process
01-01 00:01:05.111   505   622 I LatinIME:LogUtils: Dictionary info: dictionary = main:de ; version = 54 ; date = 1414726263
01-01 00:01:05.118   282   611 E OMXNodeInstance: getParameter(0xb465e300:Freescale.std._decoder.mjpeg.hw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:05.121   282   674 E OMXNodeInstance: getExtensionIndex(0xb465e300:Freescale.std._decoder.mjpeg.hw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006)
01-01 00:01:05.122   282   611 W OMXNodeInstance: [0xb465e300:Freescale.std._decoder.mjpeg.hw-based] component does not support metadata mode; using fallback
01-01 00:01:05.130   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:05.131   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:05.132   282   310 I OMXMaster: makeComponentInstance(OMX.Freescale.std.video_decoder.sorenson.sw-based) in omx@1.0-service process
01-01 00:01:05.140   282   312 E OMXNodeInstance: getParameter(0xb465e300:Freescale.std._decoder.sorenson.sw-based, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:05.142   282   312 E OMXNodeInstance: getExtensionIndex(0xb465e300:Freescale.std._decoder.sorenson.sw-based, OMX.google.android.index.configureVideoTunnelMode) ERROR: NotImplemented(0x80001006)
01-01 00:01:05.143   505   622 I LatinIME:LogUtils: Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273
01-01 00:01:05.143   282   310 W OMXNodeInstance: [0xb465e300:Freescale.std._decoder.sorenson.sw-based] component does not support metadata mode; using fallback
01-01 00:01:05.143   282   674 E OMXNodeInstance: setParameter(0xb465e300:Freescale.std._decoder.sorenson.sw-based, OMX.google.android.index.prepareForAdaptivePlayback(0x7f00003d): Output:1 en=1 max=1280x720) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:05.152   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:05.153   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:05.153   282   674 I OMXMaster: makeComponentInstance(OMX.Freescale.std.audio_decoder.ac3.sw-based) in omx@1.0-service process
01-01 00:01:05.170   282   674 I OMXPlayer: Can't open library: lib_ac3d_wrap_arm11_elinux_android.so
01-01 00:01:05.170   282   674 I OMXPlayer: dlopen failed: library "lib_ac3d_wrap_arm11_elinux_android.so" not found
01-01 00:01:05.170   282   674 I OMXPlayer: LEVEL: 1 FUNCTION: CreateDecoderInterface LINE: 293
01-01 00:01:05.170   282   674 I OMXPlayer: Fail to open Decoder library for ��#�
01-01 00:01:05.170   282   674 I OMXPlayer: LEVEL: 1 FUNCTION: CreateDecoderInterface LINE: 332
01-01 00:01:05.170   282   674 I OMXPlayer: UniaDecoder::CreateDecoderInterface ret=-2147479549
01-01 00:01:05.177   282   674 I OMXPlayer: LEVEL: 1 FUNCTION: ConstructComponent LINE: 574
01-01 00:01:05.177   282   674 I OMXPlayer: Can't initialize component.
01-01 00:01:05.177   282   674 I OMXPlayer: LEVEL: 1 FUNCTION: OMX_GetHandle LINE: 498
01-01 00:01:05.177   282   674 I OMXPlayer: Load and call entry function fail.
01-01 00:01:05.178   282   674 E /vendor/bin/hw/android.hardware.media.omx@1.0-service: Failed to allocate omx component 'OMX.Freescale.std.audio_decoder.ac3.sw-based'  err=ComponentNotFound(0x80001003)
01-01 00:01:05.181   505   622 I LatinIME:LogUtils: Dictionary info: dictionary = main:es ; version = 54 ; date = 1414726268
01-01 00:01:05.199   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:05.201   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:05.201   282   611 I OMXMaster: makeComponentInstance(OMX.Freescale.std.audio_decoder.ec3.sw-based) in omx@1.0-service process
01-01 00:01:05.206   282   611 I OMXPlayer: Unia -> EC3
01-01 00:01:05.207   282   611 I OMXPlayer: Can't open library: lib_ddpd_wrap_arm12_elinux_android.so
01-01 00:01:05.207   282   611 I OMXPlayer: dlopen failed: library "lib_ddpd_wrap_arm12_elinux_android.so" not found
01-01 00:01:05.207   282   611 I OMXPlayer: LEVEL: 1 FUNCTION: CreateDecoderInterface LINE: 293
01-01 00:01:05.207   282   611 I OMXPlayer: Fail to open Decoder library for 4� �
01-01 00:01:05.207   282   611 I OMXPlayer: LEVEL: 1 FUNCTION: CreateDecoderInterface LINE: 332
01-01 00:01:05.207   282   611 I OMXPlayer: UniaDecoder::CreateDecoderInterface ret=-2147479549
01-01 00:01:05.222   505   622 I LatinIME:LogUtils: Dictionary info: dictionary = main:fr ; version = 54 ; date = 1414726264
01-01 00:01:05.224   282   611 I OMXPlayer: LEVEL: 1 FUNCTION: ConstructComponent LINE: 574
01-01 00:01:05.224   282   611 I OMXPlayer: Can't initialize component.
01-01 00:01:05.224   282   611 I OMXPlayer: LEVEL: 1 FUNCTION: OMX_GetHandle LINE: 498
01-01 00:01:05.224   282   611 I OMXPlayer: Load and call entry function fail.
01-01 00:01:05.224   282   611 E /vendor/bin/hw/android.hardware.media.omx@1.0-service: Failed to allocate omx component 'OMX.Freescale.std.audio_decoder.ec3.sw-based'  err=ComponentNotFound(0x80001003)
01-01 00:01:05.226   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:05.228   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:05.229   282   674 I OMXMaster: makeComponentInstance(OMX.Freescale.std.audio_decoder.wma.sw-based) in omx@1.0-service process
01-01 00:01:05.241   282   674 I OMXPlayer: Can't open library: lib_wma10d_wrap_arm12_elinux_android.so
01-01 00:01:05.241   282   674 I OMXPlayer: dlopen failed: library "lib_wma10d_wrap_arm12_elinux_android.so" not found
01-01 00:01:05.241   282   674 I OMXPlayer: LEVEL: 1 FUNCTION: CreateDecoderInterface LINE: 293
01-01 00:01:05.241   282   674 I OMXPlayer: Fail to open Decoder library for �9��
01-01 00:01:05.241   282   674 I OMXPlayer: LEVEL: 1 FUNCTION: CreateDecoderInterface LINE: 332
01-01 00:01:05.242   282   674 I OMXPlayer: UniaDecoder::CreateDecoderInterface ret=-2147479549
01-01 00:01:05.249   379   379 W zygote  : Long monitor contention with owner PackageManager (407) at void com.android.server.pm.PackageManagerService$PackageHandler.doHandleMessage(android.os.Message)(PackageManagerService.java:1722) waiters=2 in android.content.pm.ApplicationInfo com.android.server.pm.PackageManagerService.getApplicationInfoInternal(java.lang.String, int, int, int) for 228ms
01-01 00:01:05.275   282   674 I OMXPlayer: LEVEL: 1 FUNCTION: ConstructComponent LINE: 574
01-01 00:01:05.275   282   674 I OMXPlayer: Can't initialize component.
01-01 00:01:05.275   282   674 I OMXPlayer: LEVEL: 1 FUNCTION: OMX_GetHandle LINE: 498
01-01 00:01:05.275   282   674 I OMXPlayer: Load and call entry function fail.
01-01 00:01:05.275   282   674 E /vendor/bin/hw/android.hardware.media.omx@1.0-service: Failed to allocate omx component 'OMX.Freescale.std.audio_decoder.wma.sw-based'  err=ComponentNotFound(0x80001003)
01-01 00:01:05.280   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:05.281   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:05.282   282   611 I OMXMaster: makeComponentInstance(OMX.Freescale.std.audio_decoder.flac.sw-based) in omx@1.0-service process
01-01 00:01:05.299   505   622 I LatinIME:LogUtils: Dictionary info: dictionary = main:it ; version = 54 ; date = 1414726258
01-01 00:01:05.319   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:05.326   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:05.326   282   310 I OMXMaster: makeComponentInstance(OMX.Freescale.std.audio_decoder.mp3.sw-based) in omx@1.0-service process
01-01 00:01:05.423   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:05.427   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:05.429   282   674 I OMXMaster: makeComponentInstance(OMX.Freescale.std.audio_decoder.amr.sw-based) in omx@1.0-service process
01-01 00:01:05.451   379   379 D BluetoothManagerService: Trying to bind to profile: 1, while Bluetooth was disabled
01-01 00:01:05.466   282   611 I OMXPlayer: SetRoleFormat AMR NB mode.
01-01 00:01:05.494   379   702 I Telecom : BluetoothRouteManager: getBluetoothAudioConnectedDevice: no headset service available.
01-01 00:01:05.499   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:05.506   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:05.507   282   611 I OMXMaster: makeComponentInstance(OMX.Freescale.std.audio_decoder.amrwb.sw-based) in omx@1.0-service process
01-01 00:01:05.512   379   379 I Telecom : SystemStateProvider: Registering car mode receiver: android.content.IntentFilter@98f9cfe: TS.init@AAA
01-01 00:01:05.512   282   312 I OMXPlayer: SetRoleFormat AMR WB mode.
01-01 00:01:05.514   646   703 D OpenGLRenderer: HWUI GL Pipeline
01-01 00:01:05.588   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:05.590   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:05.590   282   310 I OMXMaster: makeComponentInstance(OMX.Freescale.std.audio_decoder.aac.sw-based) in omx@1.0-service process
01-01 00:01:05.605   282   310 I OMXPlayer: Can't open library: lib_aacplusd_wrap_arm12_elinux_android.so
01-01 00:01:05.605   282   310 I OMXPlayer: dlopen failed: library "lib_aacplusd_wrap_arm12_elinux_android.so" not found
01-01 00:01:05.610   379   379 W Binder:379_3: type=1400 audit(0.0:22): avc: denied { write } for name="timerslack_ns" dev="proc" ino=14766 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:05.610   379   379 W Binder:379_3: type=1400 audit(0.0:23): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15578 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:05.610   379   379 W Binder:379_3: type=1400 audit(0.0:24): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15580 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:05.610   379   379 W Binder:379_3: type=1400 audit(0.0:25): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15582 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:05.610   379   379 W Binder:379_3: type=1400 audit(0.0:26): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15584 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:05.610   379   379 W Binder:379_3: type=1400 audit(0.0:27): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15586 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:05.610   379   379 W Binder:379_3: type=1400 audit(0.0:28): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15588 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:05.610   379   379 W Binder:379_3: type=1400 audit(0.0:29): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15590 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:05.610   379   379 W Binder:379_3: type=1400 audit(0.0:30): avc: denied { write } for name="timerslack_ns" dev="proc" ino=14805 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:05.610   379   379 W Binder:379_3: type=1400 audit(0.0:31): avc: denied { write } for name="timerslack_ns" dev="proc" ino=14221 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:05.610   379   379 W Binder:379_3: type=1400 audit(0.0:32): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15592 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:05.610   379   379 W Binder:379_3: type=1400 audit(0.0:33): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15594 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:05.624   505   622 I LatinIME:LogUtils: Dictionary info: dictionary = main:ru ; version = 54 ; date = 1414726277
01-01 00:01:05.640   379   379 W Binder:379_2: type=1400 audit(0.0:34): avc: denied { write } for name="timerslack_ns" dev="proc" ino=14766 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:05.640   379   379 W Binder:379_2: type=1400 audit(0.0:35): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15578 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:05.640   379   379 W Binder:379_2: type=1400 audit(0.0:36): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15580 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:05.640   379   379 W Binder:379_2: type=1400 audit(0.0:37): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15582 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:05.640   379   379 W Binder:379_2: type=1400 audit(0.0:38): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15584 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:05.640   379   379 W Binder:379_2: type=1400 audit(0.0:39): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15586 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:05.640   379   379 W Binder:379_2: type=1400 audit(0.0:40): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15588 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:05.640   379   379 W Binder:379_2: type=1400 audit(0.0:41): avc: denied { write } for name="timerslack_ns" dev="proc" ino=15590 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:05.640   379   379 W Binder:379_2: type=1400 audit(0.0:42): avc: denied { write } for name="timerslack_ns" dev="proc" ino=14805 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
01-01 00:01:05.648   379   706 I Telecom : Logging.Events: Non-call EVENT: AUDIO_ROUTE, Entering state QuiescentEarpieceRoute
01-01 00:01:05.655   505   505 I LatinIME: Hardware accelerated drawing: true
01-01 00:01:05.659   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:05.662   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:05.663   282   312 I OMXMaster: makeComponentInstance(OMX.Freescale.std.audio_decoder.ra.sw-based) in omx@1.0-service process
01-01 00:01:05.667   282   312 I OMXPlayer: Unia -> REAL
01-01 00:01:05.671   282   312 I OMXPlayer: Can't open library: lib_realad_wrap_arm11_elinux_android.so
01-01 00:01:05.671   282   312 I OMXPlayer: dlopen failed: library "lib_realad_wrap_arm11_elinux_android.so" not found
01-01 00:01:05.671   282   312 I OMXPlayer: LEVEL: 1 FUNCTION: CreateDecoderInterface LINE: 293
01-01 00:01:05.671   282   312 I OMXPlayer: Fail to open Decoder library for (i��
01-01 00:01:05.671   282   312 I OMXPlayer: LEVEL: 1 FUNCTION: CreateDecoderInterface LINE: 332
01-01 00:01:05.671   282   312 I OMXPlayer: UniaDecoder::CreateDecoderInterface ret=-2147479549
01-01 00:01:05.677   379   379 I Telecom : MissedCallNotifierImpl: Boot not yet complete -- call log db may not be available. Deferring loading until boot complete.: TS.init@AAA
01-01 00:01:05.692   379   712 I Telecom : CallAudioModeStateMachine: Message received: null.: TS.init->CAMSM.pM_1@AAA
01-01 00:01:05.701   282   312 I OMXPlayer: LEVEL: 1 FUNCTION: ConstructComponent LINE: 574
01-01 00:01:05.701   282   312 I OMXPlayer: Can't initialize component.
01-01 00:01:05.701   282   312 I OMXPlayer: LEVEL: 1 FUNCTION: OMX_GetHandle LINE: 498
01-01 00:01:05.701   282   312 I OMXPlayer: Load and call entry function fail.
01-01 00:01:05.701   282   312 E /vendor/bin/hw/android.hardware.media.omx@1.0-service: Failed to allocate omx component 'OMX.Freescale.std.audio_decoder.ra.sw-based'  err=ComponentNotFound(0x80001003)
01-01 00:01:05.703   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:05.705   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:05.705   282   674 I OMXMaster: makeComponentInstance(OMX.google.mpeg4.decoder) in omx@1.0-service process
01-01 00:01:05.733   505   505 W InputAttributes: No editor info for this field. Bug?
01-01 00:01:05.743   379   379 D BluetoothManagerService: Trying to bind to profile: 1, while Bluetooth was disabled
01-01 00:01:05.793   379   379 I Telecom : Class: TelecomSystem.INSTANCE being set
01-01 00:01:05.796   379   379 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1479 android.content.ContextWrapper.startService:649 com.android.server.telecom.components.TelecomService.initializeTelecomSystem:168 com.android.server.telecom.components.TelecomService.onBind:62 android.app.ActivityThread.handleBindService:3447
01-01 00:01:05.814   273   421 D installd: Found quota mount /dev/block/by-name/userdata at /data
01-01 00:01:05.814   273   421 E installd: Failed to enable USRQUOTA on /dev/block/by-name/userdata: File exists
01-01 00:01:05.814   273   421 E installd: Failed to enable GRPQUOTA on /dev/block/by-name/userdata: File exists
01-01 00:01:05.815   273   421 D installd: Found storage mount /data/media at /mnt/runtime/default/emulated
01-01 00:01:05.832   505   622 I BinaryDictionaryFileDumper: reinitializeClientRecordInDictionaryContentProvider() : Insert DictionaryInfo : Id = 'main:de' : Locale=de : Version=54
01-01 00:01:05.922   505   622 I BinaryDictionaryFileDumper: reinitializeClientRecordInDictionaryContentProvider() : Insert DictionaryInfo : Id = 'main:en' : Locale=en : Version=54
01-01 00:01:05.969   646   703 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/gralloc.imx6.so from the current namespace instead.
01-01 00:01:05.981   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.configstore@1.0::ISurfaceFlingerConfigs/default in either framework or device manifest.
01-01 00:01:05.987   646   703 I zygote  : android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
01-01 00:01:05.987   646   703 I OpenGLRenderer: Initialized EGL, version 1.4
01-01 00:01:05.988   646   703 D OpenGLRenderer: Swap behavior 2
01-01 00:01:06.036   646   703 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/android.hardware.graphics.mapper@2.0-impl.so from the current namespace instead.
01-01 00:01:06.038   646   703 I vndksupport: sphal namespace is not configured for this process. Loading /vendor/lib/hw/gralloc.imx6.so from the current namespace instead.
01-01 00:01:06.041   505   622 I BinaryDictionaryFileDumper: reinitializeClientRecordInDictionaryContentProvider() : Insert DictionaryInfo : Id = 'main:es' : Locale=es : Version=54
01-01 00:01:06.054   379   379 V WiredAccessoryManager: init()
01-01 00:01:06.078   670   676 I adbd    : functionfs successfully initialized
01-01 00:01:06.100   670   676 I adbd    : registering usb transport
01-01 00:01:06.199   379   394 W KeyguardServiceDelegate: onScreenTurningOn(): no keyguard service!
01-01 00:01:06.205   379   401 I ActivityManager: Displayed com.android.settings/.FallbackHome: +1s728ms (total +2s975ms)
01-01 00:01:06.206   379   444 I InputReader: Reconfiguring input devices.  changes=0x00000004
01-01 00:01:06.207   505   622 I BinaryDictionaryFileDumper: reinitializeClientRecordInDictionaryContentProvider() : Insert DictionaryInfo : Id = 'main:fr' : Locale=fr : Version=54
01-01 00:01:06.244   518   518 I vol.Events: writeEvent collection_started
01-01 00:01:06.273   505   622 I BinaryDictionaryFileDumper: reinitializeClientRecordInDictionaryContentProvider() : Insert DictionaryInfo : Id = 'main:it' : Locale=it : Version=54
01-01 00:01:06.310   518   731 I vol.Events: writeEvent external_ringer_mode_changed normal
01-01 00:01:06.311   518   731 I vol.Events: writeEvent internal_ringer_mode_changed normal
01-01 00:01:06.319   379   379 D ConditionProviders.SCP: onSubscribe condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false
01-01 00:01:06.321   379   379 D ConditionProviders.SCP: setRegistered true
01-01 00:01:06.322   379   379 D ConditionProviders.SCP: notifyCondition condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false STATE_TRUE reason=meetsSchedule
01-01 00:01:06.386   505   622 I BinaryDictionaryFileDumper: reinitializeClientRecordInDictionaryContentProvider() : Insert DictionaryInfo : Id = 'main:ru' : Locale=ru : Version=54
01-01 00:01:06.474   379   379 D ConditionProviders.SCP: Scheduling evaluate for Thu Jan 01 07:00:00 GMT+00:00 1970 (25200000), in +6h58m53s680ms, now=Thu Jan 01 00:01:06 GMT+00:00 1970 (66320)
01-01 00:01:06.476   505   622 I BinaryDictionaryFileDumper: reinitializeClientRecordInDictionaryContentProvider() : Insert DictionaryInfo : Id = 'main:en_us' : Locale=en_US : Version=-1
01-01 00:01:06.488   379   379 D ConditionProviders.SCP: onSubscribe condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false
01-01 00:01:06.489   379   379 D ConditionProviders.SCP: notifyCondition condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false STATE_FALSE reason=!meetsSchedule
01-01 00:01:06.489   379   379 D ConditionProviders.SCP: notifyCondition condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false STATE_TRUE reason=meetsSchedule
01-01 00:01:06.490   379   379 D ConditionProviders.SCP: Scheduling evaluate for Thu Jan 01 07:00:00 GMT+00:00 1970 (25200000), in +6h58m53s512ms, now=Thu Jan 01 00:01:06 GMT+00:00 1970 (66488)
01-01 00:01:06.492   379   379 D BluetoothManagerService: BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
01-01 00:01:06.493   379   400 D BluetoothManagerService: MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
01-01 00:01:06.493   379   400 D BluetoothManagerService: MESSAGE_GET_NAME_AND_ADDRESS
01-01 00:01:06.497   379   393 I SyncManager: Got SyncJobService instance.
01-01 00:01:06.519   379   400 D BluetoothManagerService: unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@49c8782 mBinding = false mUnbinding = false
01-01 00:01:06.527   486   486 D BluetoothAdapterService: onUnbind() - calling cleanup
01-01 00:01:06.527   486   486 D BluetoothAdapterService: cleanup()
01-01 00:01:06.535   505   622 W BinaryDictionaryFileDumper: Missing metadata.json resource
01-01 00:01:06.563   379   379 I Telecom : WiredHeadsetManager: ACTION_HEADSET_PLUG event, plugged in: false, : WHC.oADA@AAE
01-01 00:01:06.566   486   486 W BluetoothSdpJni: Cleaning up Bluetooth SDP Interface...
01-01 00:01:06.566   486   486 W BluetoothSdpJni: Cleaning up Bluetooth SDP object
01-01 00:01:06.566   486   486 D BluetoothAdapterService: cleanup() - Cleaning up adapter native
01-01 00:01:06.567   486   615 I bt_stack_manager: event_clean_up_stack is cleaning up the stack
01-01 00:01:06.573   486   615 E BluetoothServiceJni: Callback: 'callback_thread_event' is not called on the correct thread
01-01 00:01:06.603   486   615 I bt_btif_queue: btif_queue_release
01-01 00:01:06.603   486   626 W bt_osi_thread: run_thread: thread id 626, thread name bt_jni_workqueue exited
01-01 00:01:06.604   486   615 I bt_core_module: module_clean_up Cleaning up module "stack_config_module"
01-01 00:01:06.605   486   615 I bt_core_module: module_clean_up Cleanup of module "stack_config_module" completed
01-01 00:01:06.605   486   615 I bt_core_module: module_clean_up Cleaning up module "interop_module"
01-01 00:01:06.605   486   615 I bt_core_module: module_clean_up Cleanup of module "interop_module" completed
01-01 00:01:06.605   486   615 I bt_core_module: module_clean_up Cleaning up module "btif_config_module"
01-01 00:01:06.625   505   622 I LatinIME:LogUtils: Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273
01-01 00:01:06.631   486   615 I bt_core_module: module_clean_up Cleanup of module "btif_config_module" completed
01-01 00:01:06.631   486   615 I bt_core_module: module_clean_up Cleaning up module "bt_utils_module"
01-01 00:01:06.631   486   615 I bt_core_module: module_clean_up Cleanup of module "bt_utils_module" completed
01-01 00:01:06.632   486   615 I bt_core_module: module_clean_up Cleaning up module "osi_module"
01-01 00:01:06.632   486   623 D bt_osi_alarm: callback_dispatch Callback thread exited
01-01 00:01:06.632   486   623 W bt_osi_thread: run_thread: thread id 623, thread name alarm_dispatcher exited
01-01 00:01:06.633   486   621 W bt_osi_thread: run_thread: thread id 621, thread name alarm_default_ca exited
01-01 00:01:06.634   505   622 I LatinIME:LogUtils: Dictionary info: dictionary = userunigram.en_US ; version = 66 ; date = ?
01-01 00:01:06.636   486   615 I bt_core_module: module_clean_up Cleanup of module "osi_module" completed
01-01 00:01:06.636   486   615 I bt_stack_manager: event_clean_up_stack finished
01-01 00:01:06.636   486   486 I BluetoothServiceJni: cleanupNative: return from cleanup
01-01 00:01:06.638   486   486 D BluetoothAdapterService: onDestroy()
01-01 00:01:06.639   486   486 I BluetoothAdapterService: Force exit to cleanup internal state in Bluetooth stack
01-01 00:01:06.647   505   622 E ActivityThread: Failed to find provider info for user_dictionary
01-01 00:01:06.647   379   470 E ActivityThread: Failed to find provider info for com.android.calendar
01-01 00:01:06.669   379   470 E ActivityThread: Failed to find provider info for com.android.calendar
01-01 00:01:06.679   282   310 E OMXNodeInstance: getExtensionIndex(0xb4627ae0:google.mpeg4.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:06.679   282   674 E OMXNodeInstance: getExtensionIndex(0xb4627ae0:google.mpeg4.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:06.696   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:06.697   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:06.700   282   611 I OMXMaster: makeComponentInstance(OMX.google.h263.decoder) in omx@1.0-service process
01-01 00:01:06.719   486   486 I zygote  : System.exit called, status: 0
01-01 00:01:06.719   486   486 I AndroidRuntime: VM exiting with result code 0, cleanup skipped.
01-01 00:01:06.743   505   622 I LatinIME:LogUtils: Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273
01-01 00:01:06.745   379   379 I DefaultPermGrantPolicy: Granting permissions to default dialer app for user:0
01-01 00:01:06.759   379   379 I Telecom : PhoneAccountRegistrar: SimCallManager queried, returning: null: TSI.gSCM@AAM
01-01 00:01:06.803   379   379 D AutofillManagerService: Autofill restriction did not change for user 0: null
01-01 00:01:06.806   505   622 I LatinIME:LogUtils: Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273
01-01 00:01:06.821   379   379 D ZenLog  : config: conditionChanged,ZenModeConfig[user=0,allowCalls=true,allowRepeatCallers=false,allowMessages=false,allowCallsFrom=contacts,allowMessagesFrom=contacts,allowReminders=true,allowEvents=true,allowWhenScreenOff=true,allowWhenScreenOn=true,automaticRules={6544c6929f4146d7b057d79a1d9f40bf=ZenRule[enabled=false,snoozing=false,name=Event,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/event?userId=-10000&calendar=&reply=1,condition=null,component=ComponentInfo{android/com.android.server.notification.EventConditionProvider},id=6544c6929f4146d7b057d79a1d9f40bf,creationTime=60606,enabler=null], ca859dcc4d0342d1a0d99345ea03a260=ZenRule[enabled=false,snoozing=false,name=Weeknight,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,condition=Condition[id=condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,summary=...,line1=...,line2=...,icon=0,state=STATE_TRUE,flags=2],component=ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider},id=ca859dcc4d0342d1a0d99345ea03a260,creationTime=60604,enabler=null], b93582e5a95c453b9f64fb4f95f5e62c=ZenRule[enabled=false,snoozing=false,name=Weekend,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false,condition=null,component=ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider},id=b93582e5a95c453b9f64fb4f95f5e62c,creationTime=60604,enabler=null]},manualRule=null],Diff[automaticRule[ca859dcc4d0342d1a0d99345ea03a260].condition:null->Condition[id=condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,summary=...,line1=...,line2=...,icon=0,state=STATE_TRUE,flags=2]]
01-01 00:01:06.825   379   379 D ZenLog  : config: conditionChanged,ZenModeConfig[user=0,allowCalls=true,allowRepeatCallers=false,allowMessages=false,allowCallsFrom=contacts,allowMessagesFrom=contacts,allowReminders=true,allowEvents=true,allowWhenScreenOff=true,allowWhenScreenOn=true,automaticRules={6544c6929f4146d7b057d79a1d9f40bf=ZenRule[enabled=false,snoozing=false,name=Event,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/event?userId=-10000&calendar=&reply=1,condition=null,component=ComponentInfo{android/com.android.server.notification.EventConditionProvider},id=6544c6929f4146d7b057d79a1d9f40bf,creationTime=60606,enabler=null], ca859dcc4d0342d1a0d99345ea03a260=ZenRule[enabled=false,snoozing=false,name=Weeknight,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,condition=Condition[id=condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,summary=...,line1=...,line2=...,icon=0,state=STATE_TRUE,flags=2],component=ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider},id=ca859dcc4d0342d1a0d99345ea03a260,creationTime=60604,enabler=null], b93582e5a95c453b9f64fb4f95f5e62c=ZenRule[enabled=false,snoozing=false,name=Weekend,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false,condition=Condition[id=condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false,summary=...,line1=...,line2=...,icon=0,state=STATE_FALSE,flags=2],component=ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider},id=b93582e5a95c453b9f64fb4f95f5e62c,creationTime=60604,enabler=null]},manualRule=null],Diff[automaticRule[b93582e5a95c453b9f64fb4f95f5e62c].condition:null->Condition[id=condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false,summary=...,line1=...,line2=...,icon=0,state=STATE_FALSE,flags=2]]
01-01 00:01:06.835   379   401 W WindowManager: App freeze timeout expired.
01-01 00:01:06.836   379   379 I FusedLocation: engine started (com.android.location.fused)
01-01 00:01:06.843   379   379 D ZenLog  : config: conditionChanged,ZenModeConfig[user=0,allowCalls=true,allowRepeatCallers=false,allowMessages=false,allowCallsFrom=contacts,allowMessagesFrom=contacts,allowReminders=true,allowEvents=true,allowWhenScreenOff=true,allowWhenScreenOn=true,automaticRules={6544c6929f4146d7b057d79a1d9f40bf=ZenRule[enabled=false,snoozing=false,name=Event,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/event?userId=-10000&calendar=&reply=1,condition=Condition[id=condition://android/event?userId=-10000&calendar=&reply=1,summary=...,line1=...,line2=...,icon=0,state=STATE_FALSE,flags=2],component=ComponentInfo{android/com.android.server.notification.EventConditionProvider},id=6544c6929f4146d7b057d79a1d9f40bf,creationTime=60606,enabler=null], ca859dcc4d0342d1a0d99345ea03a260=ZenRule[enabled=false,snoozing=false,name=Weeknight,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,condition=Condition[id=condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,summary=...,line1=...,line2=...,icon=0,state=STATE_TRUE,flags=2],component=ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider},id=ca859dcc4d0342d1a0d99345ea03a260,creationTime=60604,enabler=null], b93582e5a95c453b9f64fb4f95f5e62c=ZenRule[enabled=false,snoozing=false,name=Weekend,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false,condition=Condition[id=condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false,summary=...,line1=...,line2=...,icon=0,state=STATE_FALSE,flags=2],component=ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider},id=b93582e5a95c453b9f64fb4f95f5e62c,creationTime=60604,enabler=null]},manualRule=null],Diff[automaticRule[6544c6929f4146d7b057d79a1d9f40bf].condition:null->Condition[id=condition://android/event?userId=-10000&calendar=&reply=1,summary=...,line1=...,line2=...,icon=0,state=STATE_FALSE,flags=2]]
01-01 00:01:06.844   379   379 D ZenLog  : set_zen_mode: off,conditionChanged
01-01 00:01:06.863   379   379 I chatty  : uid=1000 system_server identical 1 line
01-01 00:01:06.891   505   622 I LatinIME:LogUtils: Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273
01-01 00:01:06.942   379   379 D ZenLog  : set_zen_mode: off,conditionChanged
01-01 00:01:07.110   505   622 I chatty  : uid=10054(com.android.inputmethod.latin) ExecutorUtils identical 4 lines
01-01 00:01:07.145   505   622 I LatinIME:LogUtils: Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273
01-01 00:01:07.241   282   312 E OMXNodeInstance: getExtensionIndex(0xb4a22f60:google.h263.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:07.241   282   611 E OMXNodeInstance: getExtensionIndex(0xb4a22f60:google.h263.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:07.260   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:07.262   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:07.262   282   312 I OMXMaster: makeComponentInstance(OMX.google.h264.decoder) in omx@1.0-service process
01-01 00:01:07.318   379   586 I ActivityManager: Process com.android.bluetooth (pid 486) has died: fore SVC
01-01 00:01:07.319   379   396 W zygote  : kill(-486, 9) failed: No such process
01-01 00:01:07.360   379   396 W zygote  : kill(-486, 9) failed: No such process
01-01 00:01:07.361   379   396 I zygote  : Successfully killed process cgroup uid 1002 pid 486 in 42ms
01-01 00:01:07.448   540   540 D AndroidRuntime: >>>>>> START com.android.internal.os.WebViewZygoteInit uid 1053 <<<<<<
01-01 00:01:07.452   518   544 I zygote  : Background concurrent copying GC freed 9878(1369KB) AllocSpace objects, 1(20KB) LOS objects, 57% free, 1115KB/2MB, paused 267us total 209.626ms
01-01 00:01:07.476   540   540 I /system/bin/webview_zygote32: option[0]=-Xzygote
01-01 00:01:07.476   540   540 I /system/bin/webview_zygote32: option[1]=-Xstacktracefile:/data/anr/traces.txt
01-01 00:01:07.476   518   731 I vol.Events: writeEvent level_changed STREAM_VOICE_CALL 4
01-01 00:01:07.476   540   540 I /system/bin/webview_zygote32: option[2]=exit
01-01 00:01:07.476   540   540 I /system/bin/webview_zygote32: option[3]=vfprintf
01-01 00:01:07.476   540   540 I /system/bin/webview_zygote32: option[4]=sensitiveThread
01-01 00:01:07.476   540   540 I /system/bin/webview_zygote32: option[5]=-verbose:gc
01-01 00:01:07.476   540   540 I /system/bin/webview_zygote32: option[6]=-Xms8m
01-01 00:01:07.477   540   540 I /system/bin/webview_zygote32: option[7]=-Xmx384m
01-01 00:01:07.477   540   540 I /system/bin/webview_zygote32: option[8]=-XX:HeapGrowthLimit=128m
01-01 00:01:07.477   540   540 I /system/bin/webview_zygote32: option[9]=-XX:HeapMinFree=512k
01-01 00:01:07.477   540   540 I /system/bin/webview_zygote32: option[10]=-XX:HeapMaxFree=8m
01-01 00:01:07.477   540   540 I /system/bin/webview_zygote32: option[11]=-XX:HeapTargetUtilization=0.75
01-01 00:01:07.477   540   540 I /system/bin/webview_zygote32: option[12]=-Xusejit:true
01-01 00:01:07.477   540   540 I /system/bin/webview_zygote32: option[13]=-Xjitsaveprofilinginfo
01-01 00:01:07.477   540   540 I /system/bin/webview_zygote32: option[14]=-agentlib:jdwp=transport=dt_android_adb,suspend=n,server=y
01-01 00:01:07.477   540   540 I /system/bin/webview_zygote32: option[15]=-Xlockprofthreshold:500
01-01 00:01:07.477   540   540 I /system/bin/webview_zygote32: option[16]=-Ximage-compiler-option
01-01 00:01:07.477   540   540 I /system/bin/webview_zygote32: option[17]=--runtime-arg
01-01 00:01:07.477   540   540 I /system/bin/webview_zygote32: option[18]=-Ximage-compiler-option
01-01 00:01:07.477   540   540 I /system/bin/webview_zygote32: option[19]=-Xms64m
01-01 00:01:07.477   540   540 I /system/bin/webview_zygote32: option[20]=-Ximage-compiler-option
01-01 00:01:07.477   540   540 I /system/bin/webview_zygote32: option[21]=--runtime-arg
01-01 00:01:07.477   540   540 I /system/bin/webview_zygote32: option[22]=-Ximage-compiler-option
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[23]=-Xmx64m
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[24]=-Ximage-compiler-option
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[25]=--image-classes=/system/etc/preloaded-classes
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[26]=-Ximage-compiler-option
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[27]=--compiled-classes=/system/etc/compiled-classes
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[28]=-Xcompiler-option
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[29]=--runtime-arg
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[30]=-Xcompiler-option
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[31]=-Xms64m
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[32]=-Xcompiler-option
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[33]=--runtime-arg
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[34]=-Xcompiler-option
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[35]=-Xmx512m
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[36]=-Ximage-compiler-option
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[37]=--instruction-set-variant=cortex-a9
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[38]=-Xcompiler-option
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[39]=--instruction-set-variant=cortex-a9
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[40]=-Ximage-compiler-option
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[41]=--instruction-set-features=default
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[42]=-Xcompiler-option
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[43]=--instruction-set-features=default
01-01 00:01:07.478   540   540 I /system/bin/webview_zygote32: option[44]=-Duser.locale=en-US
01-01 00:01:07.479   540   540 I /system/bin/webview_zygote32: option[45]=--cpu-abilist=armeabi-v7a,armeabi
01-01 00:01:07.479   540   540 I /system/bin/webview_zygote32: option[46]=-Xfingerprint:Android/sabresd_6dq/sabresd_6dq:8.0.0/1.0.0-rfp-rc4/20180205:userdebug/dev-keys
01-01 00:01:07.479   518   731 I vol.Events: writeEvent level_changed STREAM_SYSTEM 5
01-01 00:01:07.482   518   731 I vol.Events: writeEvent level_changed STREAM_RING 5
01-01 00:01:07.485   518   731 I vol.Events: writeEvent level_changed STREAM_MUSIC 5
01-01 00:01:07.493   518   731 I vol.Events: writeEvent level_changed STREAM_ALARM 6
01-01 00:01:07.500   540   540 W /system/bin/webview_zygote32: Could not reserve sentinel fault page
01-01 00:01:07.502   518   731 I vol.Events: writeEvent level_changed STREAM_BLUETOOTH_SCO 7
01-01 00:01:07.704   518   771 D OpenGLRenderer: HWUI GL Pipeline
01-01 00:01:07.727   505   560 I zygote  : Waiting for a blocking GC ProfileSaver
01-01 00:01:07.738   282   312 E OMXNodeInstance: getExtensionIndex(0xb4a22f00:google.h264.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:07.738   282   611 E OMXNodeInstance: getExtensionIndex(0xb4a22f00:google.h264.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:07.742   566   579 I zygote  : Background concurrent copying GC freed 32333(1849KB) AllocSpace objects, 0(0B) LOS objects, 74% free, 528KB/2MB, paused 1.551ms total 215.371ms
01-01 00:01:07.746   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:07.747   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:07.748   282   674 I OMXMaster: makeComponentInstance(OMX.google.hevc.decoder) in omx@1.0-service process
01-01 00:01:07.787   505   560 I zygote  : WaitForGcToComplete blocked ProfileSaver on HeapTrim for 60.588ms
01-01 00:01:07.889   566   566 D TelephonyProvider: dbh.onCreate:+ db=SQLiteDatabase: /data/user_de/0/com.android.providers.telephony/databases/telephony.db
01-01 00:01:07.889   566   566 D TelephonyProvider: dbh.createSimInfoTable:+
01-01 00:01:07.894   566   566 D TelephonyProvider: dbh.createSimInfoTable:-
01-01 00:01:07.894   566   566 D TelephonyProvider: dbh.createCarriersTable: carriers
01-01 00:01:07.916   566   566 D TelephonyProvider: dbh.createCarriersTable:-
01-01 00:01:07.916   566   566 D TelephonyProvider: dbh.onCreate: Apply apns from xml.
01-01 00:01:07.917   566   566 D TelephonyProvider: No APNs in OEM image = /oem/telephony/apns-conf.xml Load APNs from system image
01-01 00:01:07.917   566   566 D TelephonyProvider: No APNs in OEM image = /data/misc/apns-conf.xml Load APNs from system image
01-01 00:01:07.918   566   566 D TelephonyProvider: confFile = /system/etc/apns-conf.xml
01-01 00:01:07.921   566   566 E TelephonyProvider: FileNotFoundException for /system/etc/apns-conf.xml:java.io.FileNotFoundException: /system/etc/apns-conf.xml (No such file or directory)
01-01 00:01:07.968   566   566 D TelephonyProvider: dbh.onCreate:- db=SQLiteDatabase: /data/user_de/0/com.android.providers.telephony/databases/telephony.db
01-01 00:01:08.004   566   566 D TelephonyProvider: dbh.onOpen: ok, queried table=siminfo
01-01 00:01:08.005   566   566 D TelephonyProvider: dbh.onOpen: ok, queried table=carriers
01-01 00:01:08.050   566   566 D TelephonyProvider: onCreate: build id changed from  to 1.0.0-rfp-rc4
01-01 00:01:08.051   566   566 D TelephonyProvider: No APNs in OEM image = /oem/telephony/apns-conf.xml Load APNs from system image
01-01 00:01:08.051   566   566 D TelephonyProvider: No APNs in OEM image = /data/misc/apns-conf.xml Load APNs from system image
01-01 00:01:08.053   566   566 E TelephonyProvider: FileNotFoundException for /system/etc/apns-conf.xml:java.io.FileNotFoundException: /system/etc/apns-conf.xml (No such file or directory)
01-01 00:01:08.053   566   566 D TelephonyProvider: newChecksum: -1
01-01 00:01:08.053   566   566 D TelephonyProvider: oldChecksum: -1
01-01 00:01:08.053   566   566 D TelephonyProvider: Skipping apn db update since apn-conf has not changed.
01-01 00:01:08.078   566   566 D CarrierProvider: onCreate
01-01 00:01:08.230   282   312 E OMXNodeInstance: getExtensionIndex(0xb4627840:google.hevc.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:08.231   282   310 E OMXNodeInstance: getExtensionIndex(0xb4627840:google.hevc.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:08.242   379   389 I zygote  : Background concurrent copying GC freed 46804(3MB) AllocSpace objects, 22(460KB) LOS objects, 42% free, 4MB/7MB, paused 238us total 688.287ms
01-01 00:01:08.277   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:08.279   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:08.279   282   611 I OMXMaster: makeComponentInstance(OMX.google.vp8.decoder) in omx@1.0-service process
01-01 00:01:08.447   566   566 I ImsResolver: Initializing cache and binding.
01-01 00:01:08.571   379   390 W WallpaperManagerService: Cannot extract colors because wallpaper could not be read.
01-01 00:01:08.582   379   586 W WallpaperManagerService: Cannot extract colors because wallpaper could not be read.
01-01 00:01:08.634   518   518 D StatusBar: disable<e i a s b h r c s q >
01-01 00:01:08.639   379   604 I StatusBarManagerService: registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@a5d24af
01-01 00:01:08.657   282   312 E OMXNodeInstance: getExtensionIndex(0xb4a23020:google.vp8.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:08.657   282   310 E OMXNodeInstance: getExtensionIndex(0xb4a23020:google.vp8.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:08.692   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:08.694   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:08.694   282   611 I OMXMaster: makeComponentInstance(OMX.google.vp9.decoder) in omx@1.0-service process
01-01 00:01:09.078   282   310 E OMXNodeInstance: getExtensionIndex(0xb4a232c0:google.vp9.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:09.078   282   312 E OMXNodeInstance: getExtensionIndex(0xb4a232c0:google.vp9.decoder, OMX.google.android.index.enableAndroidNativeBuffers) ERROR: UnsupportedIndex(0x8000101a)
01-01 00:01:09.080   518   776 I SecurityController: could not bind to KeyChainService
01-01 00:01:09.120   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:09.123   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:09.124   282   611 I OMXMaster: makeComponentInstance(OMX.google.h263.encoder) in omx@1.0-service process
01-01 00:01:09.124   518   544 I zygote  : Background concurrent copying GC freed 15947(1070KB) AllocSpace objects, 2(40KB) LOS objects, 49% free, 1779KB/3MB, paused 1.001ms total 275.229ms
01-01 00:01:09.295   566   566 D PhoneSwitcherNetworkRequstListener: Registering NetworkFactory
01-01 00:01:09.297   379   464 D ConnectivityService: Got NetworkFactory Messenger for PhoneSwitcherNetworkRequstListener
01-01 00:01:09.400   518   518 I CameraManagerGlobal: Connecting to camera service
01-01 00:01:09.408   379   464 D ConnectivityService: Got NetworkFactory Messenger for TelephonyNetworkFactory[0]
01-01 00:01:09.448   282   611 I SoftMPEG4Encoder: Construct SoftMPEG4Encoder
01-01 00:01:09.459   279   279 W OMXUtils: do not know color format 0x7f000789 = 2130708361
01-01 00:01:09.460   282   312 E OMXNodeInstance: getConfig(0xb4a23320:google.h263.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001)
01-01 00:01:09.495   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:09.496   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:09.496   282   611 I OMXMaster: makeComponentInstance(OMX.google.h264.encoder) in omx@1.0-service process
01-01 00:01:09.516   518   518 I StatusBar: isKeyguardShowing() called before startKeyguard(), returning true
01-01 00:01:09.517   518   518 W StatusBar: isKeyguardSecure() called before startKeyguard(), returning false
01-01 00:01:09.517   518   518 W StatusBar: java.lang.Throwable
01-01 00:01:09.517   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.StatusBar.isKeyguardSecure(StatusBar.java:7445)
01-01 00:01:09.517   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.StatusBar.isCameraAllowedByAdmin(StatusBar.java:5345)
01-01 00:01:09.517   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.KeyguardBottomAreaView$DefaultRightButton.getIcon(KeyguardBottomAreaView.java:858)
01-01 00:01:09.517   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.KeyguardBottomAreaView.updateCameraVisibility(KeyguardBottomAreaView.java:385)
01-01 00:01:09.517   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.KeyguardBottomAreaView.setStatusBar(KeyguardBottomAreaView.java:354)
01-01 00:01:09.517   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.NotificationPanelView.setStatusBar(NotificationPanelView.java:252)
01-01 00:01:09.517   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.StatusBar.makeStatusBarView(StatusBar.java:1018)
01-01 00:01:09.517   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.StatusBar.addStatusBarWindow(StatusBar.java:3593)
01-01 00:01:09.517   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.StatusBar.createAndAddWindows(StatusBar.java:3589)
01-01 00:01:09.517   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.StatusBar.start(StatusBar.java:887)
01-01 00:01:09.517   518   518 W StatusBar:     at com.android.systemui.SystemBars.createStatusBarFromConfig(SystemBars.java:71)
01-01 00:01:09.517   518   518 W StatusBar:     at com.android.systemui.SystemBars.start(SystemBars.java:42)
01-01 00:01:09.517   518   518 W StatusBar:     at com.android.systemui.SystemUIApplication.startServicesIfNeeded(SystemUIApplication.java:211)
01-01 00:01:09.517   518   518 W StatusBar:     at com.android.systemui.SystemUIApplication.startServicesIfNeeded(SystemUIApplication.java:166)
01-01 00:01:09.517   518   518 W StatusBar:     at com.android.systemui.SystemUIService.onCreate(SystemUIService.java:33)
01-01 00:01:09.517   518   518 W StatusBar:     at android.app.ActivityThread.handleCreateService(ActivityThread.java:3420)
01-01 00:01:09.517   518   518 W StatusBar:     at android.app.ActivityThread.-wrap4(Unknown Source:0)
01-01 00:01:09.517   518   518 W StatusBar:     at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1686)
01-01 00:01:09.517   518   518 W StatusBar:     at android.os.Handler.dispatchMessage(Handler.java:105)
01-01 00:01:09.517   518   518 W StatusBar:     at android.os.Looper.loop(Looper.java:164)
01-01 00:01:09.517   518   518 W StatusBar:     at android.app.ActivityThread.main(ActivityThread.java:6600)
01-01 00:01:09.517   518   518 W StatusBar:     at java.lang.reflect.Method.invoke(Native Method)
01-01 00:01:09.517   518   518 W StatusBar:     at com.android.internal.os.Zygote$MethodAndArgsCaller.run(Zygote.java:240)
01-01 00:01:09.517   518   518 W StatusBar:     at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:772)
01-01 00:01:09.595   566   566 D CarrierConfigLoader: CarrierConfigLoader has started
01-01 00:01:09.599   566   808 E ActivityThread: Failed to find provider info for com.android.contacts
01-01 00:01:09.599   566   808 W CallerInfoCache: cursor is null
01-01 00:01:09.600   379   532 D BluetoothManagerService: Trying to bind to profile: 1, while Bluetooth was disabled
01-01 00:01:09.666   566   566 I TelecomFramework: TtyManager: updateUiTtyMode -1 -> 0
01-01 00:01:09.696   566   566 D ImsResolver: maybeAddedImsService, packageName: null
01-01 00:01:09.739   379   586 W WallpaperManagerService: no current wallpaper -- first boot?
01-01 00:01:09.741   566   566 D ServiceStateProvider: subId=-2
01-01 00:01:09.763   518   518 I StatusBar: isKeyguardShowing() called before startKeyguard(), returning true
01-01 00:01:09.764   518   518 W StatusBar: isKeyguardSecure() called before startKeyguard(), returning false
01-01 00:01:09.764   518   518 W StatusBar: java.lang.Throwable
01-01 00:01:09.764   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.StatusBar.isKeyguardSecure(StatusBar.java:7445)
01-01 00:01:09.764   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.StatusBar.isCameraAllowedByAdmin(StatusBar.java:5345)
01-01 00:01:09.764   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.KeyguardBottomAreaView$DefaultRightButton.getIcon(KeyguardBottomAreaView.java:858)
01-01 00:01:09.764   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.KeyguardBottomAreaView.updateCameraVisibility(KeyguardBottomAreaView.java:385)
01-01 00:01:09.764   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.KeyguardBottomAreaView.setUserSetupComplete(KeyguardBottomAreaView.java:363)
01-01 00:01:09.764   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.NotificationPanelView.setUserSetupComplete(NotificationPanelView.java:2658)
01-01 00:01:09.764   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.StatusBar.makeStatusBarView(StatusBar.java:1161)
01-01 00:01:09.764   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.StatusBar.addStatusBarWindow(StatusBar.java:3593)
01-01 00:01:09.764   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.StatusBar.createAndAddWindows(StatusBar.java:3589)
01-01 00:01:09.764   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.StatusBar.start(StatusBar.java:887)
01-01 00:01:09.764   518   518 W StatusBar:     at com.android.systemui.SystemBars.createStatusBarFromConfig(SystemBars.java:71)
01-01 00:01:09.764   518   518 W StatusBar:     at com.android.systemui.SystemBars.start(SystemBars.java:42)
01-01 00:01:09.764   518   518 W StatusBar:     at com.android.systemui.SystemUIApplication.startServicesIfNeeded(SystemUIApplication.java:211)
01-01 00:01:09.764   518   518 W StatusBar:     at com.android.systemui.SystemUIApplication.startServicesIfNeeded(SystemUIApplication.java:166)
01-01 00:01:09.764   518   518 W StatusBar:     at com.android.systemui.SystemUIService.onCreate(SystemUIService.java:33)
01-01 00:01:09.764   518   518 W StatusBar:     at android.app.ActivityThread.handleCreateService(ActivityThread.java:3420)
01-01 00:01:09.764   518   518 W StatusBar:     at android.app.ActivityThread.-wrap4(Unknown Source:0)
01-01 00:01:09.764   518   518 W StatusBar:     at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1686)
01-01 00:01:09.764   518   518 W StatusBar:     at android.os.Handler.dispatchMessage(Handler.java:105)
01-01 00:01:09.764   518   518 W StatusBar:     at android.os.Looper.loop(Looper.java:164)
01-01 00:01:09.764   518   518 W StatusBar:     at android.app.ActivityThread.main(ActivityThread.java:6600)
01-01 00:01:09.764   518   518 W StatusBar:     at java.lang.reflect.Method.invoke(Native Method)
01-01 00:01:09.764   518   518 W StatusBar:     at com.android.internal.os.Zygote$MethodAndArgsCaller.run(Zygote.java:240)
01-01 00:01:09.764   518   518 W StatusBar:     at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:772)
01-01 00:01:09.790   566   566 D PhoneSwitcherNetworkRequstListener: got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
01-01 00:01:09.791   566   566 D PhoneSwitcherNetworkRequstListener: got request NetworkRequest [ TRACK_DEFAULT id=3, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
01-01 00:01:09.791   566   566 D PhoneSwitcherNetworkRequstListener: got request NetworkRequest [ TRACK_DEFAULT id=4, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
01-01 00:01:09.791   566   566 D PhoneSwitcherNetworkRequstListener: got request NetworkRequest [ BACKGROUND_REQUEST id=2, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
01-01 00:01:09.800   566   566 D TelephonyDebugService: TelephonyDebugService()
01-01 00:01:09.806   566   566 D CarrierConfigLoader: mHandler: 12 phoneId: 0
01-01 00:01:09.806   566   566 D CarrierConfigLoader: Build fingerprint changed. old: null new: Android/sabresd_6dq/sabresd_6dq:8.0.0/1.0.0-rfp-rc4/20180205:userdebug/dev-keys
01-01 00:01:09.827   279   279 W OMXUtils: do not know color format 0x7f000789 = 2130708361
01-01 00:01:09.844   234   234 W /system/bin/hwservicemanager: getTransport: Cannot find entry android.hardware.media.omx@1.0::IOmx/default in either framework or device manifest.
01-01 00:01:09.845   279   279 I OMXClient: Treble IOmx obtained
01-01 00:01:09.846   282   312 I OMXMaster: makeComponentInstance(OMX.google.mpeg4.encoder) in omx@1.0-service process
01-01 00:01:09.859   566   566 E PhoneInterfaceManager: [PhoneIntfMgr] getIccId: No UICC
01-01 00:01:09.896   379   532 W Telecom : : registerPhoneAccount not allowed on non-voice capable device.: TSI.rPA@AAc
01-01 00:01:09.897   566   566 I TelecomFramework: AccountEntry: Registered phoneAccount: [[ ] PhoneAccount: ComponentInfo{com.android.phone/com.android.services.telephony.TelephonyConnectionService}, [e0184adedf913b076626646d3f52c3b49c39ad6d], UserHandle{0} Capabilities: CallProvider MultiUser PlaceEmerg SimSub  Audio Routes: BESW Schemes: tel voicemail  Extras: Bundle[{android.telecom.extra.SUPPORTS_VIDEO_CALLING_FALLBACK=false}] GroupId: [da39a3ee5e6b4b0d3255bfef95601890afd80709]] with handle: ComponentInfo{com.android.phone/com.android.services.telephony.TelephonyConnectionService}, [e0184adedf913b076626646d3f52c3b49c39ad6d], UserHandle{0}
01-01 00:01:09.901   566   566 I TelecomFramework: PstnIncomingCallNotifier: Registering: Handler (com.android.internal.telephony.GsmCdmaPhone) {99059fe}
01-01 00:01:09.925   518   518 D LocalBluetoothProfileManager: Adding local MAP profile
01-01 00:01:09.934   518   518 D BluetoothMap: Create BluetoothMap proxy object
01-01 00:01:09.949   566   566 I TelecomFramework: PstnPhoneCapabilitiesNotifier: handleVideoCapabilitesChanged. Video capability - false
01-01 00:01:09.954   518   518 D LocalBluetoothProfileManager: LocalBluetoothProfileManager construction complete
01-01 00:01:09.956   566   566 E PhoneInterfaceManager: [PhoneIntfMgr] getIccId: No UICC
01-01 00:01:09.976   379   390 W Telecom : : registerPhoneAccount not allowed on non-voice capable device.: TSI.rPA@AAo
01-01 00:01:10.025   518   518 I StatusBar: isKeyguardShowing() called before startKeyguard(), returning true
01-01 00:01:10.026   518   518 W StatusBar: isKeyguardSecure() called before startKeyguard(), returning false
01-01 00:01:10.026   518   518 W StatusBar: java.lang.Throwable
01-01 00:01:10.026   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.StatusBar.isKeyguardSecure(StatusBar.java:7445)
01-01 00:01:10.026   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.StatusBar.isCameraAllowedByAdmin(StatusBar.java:5345)
01-01 00:01:10.026   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.KeyguardBottomAreaView$DefaultRightButton.getIcon(KeyguardBottomAreaView.java:858)
01-01 00:01:10.026   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.KeyguardBottomAreaView.updateCameraVisibility(KeyguardBottomAreaView.java:385)
01-01 00:01:10.026   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.KeyguardBottomAreaView.setUserSetupComplete(KeyguardBottomAreaView.java:363)
01-01 00:01:10.026   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.NotificationPanelView.setUserSetupComplete(NotificationPanelView.java:2658)
01-01 00:01:10.026   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.StatusBar$1.onUserSetupChanged(StatusBar.java:525)
01-01 00:01:10.026   518   518 W StatusBar:     at com.android.systemui.statusbar.policy.DeviceProvisionedControllerImpl.addCallback(DeviceProvisionedControllerImpl.java:69)
01-01 00:01:10.026   518   518 W StatusBar:     at com.android.systemui.statusbar.policy.DeviceProvisionedControllerImpl.addCallback(DeviceProvisionedControllerImpl.java:63)
01-01 00:01:10.026   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.StatusBar.makeStatusBarView(StatusBar.java:1249)
01-01 00:01:10.026   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.StatusBar.addStatusBarWindow(StatusBar.java:3593)
01-01 00:01:10.026   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.StatusBar.createAndAddWindows(StatusBar.java:3589)
01-01 00:01:10.026   518   518 W StatusBar:     at com.android.systemui.statusbar.phone.StatusBar.start(StatusBar.java:887)
01-01 00:01:10.026   518   518 W StatusBar:     at com.android.systemui.SystemBars.createStatusBarFromConfig(SystemBars.java:71)
01-01 00:01:10.026   518   518 W StatusBar:     at com.android.systemui.SystemBars.start(SystemBars.java:42)
01-01 00:01:10.026   518   518 W StatusBar:     at com.android.systemui.SystemUIApplication.startServicesIfNeeded(SystemUIApplication.java:211)
01-01 00:01:10.026   518   518 W StatusBar:     at com.android.systemui.SystemUIApplication.startServicesIfNeeded(SystemUIApplication.java:166)
01-01 00:01:10.026   518   518 W StatusBar:     at com.android.systemui.SystemUIService.onCreate(SystemUIService.java:33)
01-01 00:01:10.026   518   518 W StatusBar:     at android.app.ActivityThread.handleCreateService(ActivityThread.java:3420)
01-01 00:01:10.026   518   518 W StatusBar:     at android.app.ActivityThread.-wrap4(Unknown Source:0)
01-01 00:01:10.026   518   518 W StatusBar:     at andr^C
130|sabresd_6dq:/ $ ls /dev
type=1400 audit(87.340:105): avc: denied { write } for pid=379 comm="Binder:379_7" name="timerslack_ns" dev="proc" ino=19076 scontext=u:r:system_server:s0 tcontext=u:r:untrusted_app_25:s0:c512,c768 tclass=file permissive=0
ls: /dev/.coldboot_done: Permission denied
__properties__  graphics           pps0       tty2  tty4type=1400 audit(165.650:106): avc: denied { getattr } for pid=1370 comm="ls" path="/dev/.coldboot_done" dev="tmpfs" ino=9469 scontext=u:r:shell:s0 tcontext=u:object_r:device:s0 tclass=file permissive=0
1 tty63
ashmem          hw_random          ptmx       tty20 tty42 tty7
autofs          hwbinder           ptp0       tty21 tty43 tty8
binder          i2c-0              pts        tty22 tty44 tty9
block           i2c-1              pxp_device tty23 tty45 ttymxc0
bus             i2c-2              random     tty24 tty46 ttymxc2
console         input              rfkill     tty25 tty47 ttymxc4
cpu_dma_latency ion                rtc0       tty26 tty48 tun
cpuctl          keychord           snd        tty27 tty49 ubi_ctrl
cpuset          kmsg               socket     tty28 tty5  uhid
device-mapper   loop-control       stune      tty29 tty50 uinput
dri             memcg              tty        tty3  tty51 urandom
fd              memory_bandwidth   tty0       tty30 tty52 usb-ffs
fscklogs        mtp_usb            tty1       tty31 tty53 usb_accessory
full            mxc_asrc           tty10      tty32 tty54 vcs
fuse            mxc_dcic0          tty11      tty33 tty55 vcs1
galcore         mxc_dcic1          tty12      tty34 tty56 vcsa
gpiochip0       mxc_ipu            tty13      tty35 tty57 vcsa1
gpiochip1       mxc_mem            tty14      tty36 tty58 video0
gpiochip2       mxc_vpu            tty15      tty37 tty59 video16
gpiochip3       network_latency    tty16      tty38 tty6  video17
gpiochip4       network_throughput tty17      tty39 tty60 vndbinder
gpiochip5       null               tty18      tty4  tty61 xt_qtaguid
gpiochip6       ppp                tty19      tty40 tty62 zero
1|sabresd_6dq:/ $
