S32K148 Eval Board Pinout?
zbellay
Hello, NXP Community!
I am using the NXP S32K148EVB-Q144 and cannot find documentation on which header pins on the eval board correspond to which pins on the microcontroller. I have looked at S32K148_IO_Signal_Description_Input_Multiplexing.xlsx but cannot decipher, for example, how pin 16 corresponds to VSS. I may be reading the docs incorrectly, so your help would be greatly appreciated.
Thank you!
danielmartynek
You can look at the EVB headers in the schematic.
danielmartynek
andrew_thornbor
Hey Daniel Martynek,
I think the link you provided is dead. Is there a place that the schematic has been moved to?
danielmartynek
Hi Andrew,
There is more than one schematic now depending on the EVB revision.
Take a look at the product web page. S32K148EVB: S32K148 Evaluation Board
Under Software & Tools / Schematics.
