ZigBee: No indirect capacity failure
alejandrovelez
Greetings
I've a ZigBee Coordinator, Several Router and Sleeping End Devices. One of the Zr is a Gateway that responds to a match descriptor request, but after some time I get a "No indirect capacity" command from ZigBee coordinator.
Here's the routing connections with only the Zc a Zr and a Zed, and the packets siniffed:
The only info about this problem that I could find is in the ZigBee spec:
Any Idea how can I solve this problem?
I'm using BeeStack 4.0 with BeeKit 3.0.2
Labels (2)
estephania_mart
Sorry for the inconvenience this might cause you, unfortunately, the BeeKit it’s no longer supported.
You can check our current ZigBee solutions on the following page, there you will find devices like the KW41Z that it's a multiprotocol device or the JN5169
Estephania
