I use NXP DDR Test Tool to test MX7D .The TARGET has been choosed MX7D.
But the result ERROR: Can't open USB device!!!.
Why???
Solved! Go to Solution.
I.MX7 must be in Serial Downloader mode (BOOT_MODE[1:0] = 01).
Also it makes sense to check in i.MX7 is working. Use chaper 4 (Avoiding board bring-up problems)
of the Hardware Development Guide
http://www.nxp.com/assets/documents/data/en/user-guides/IMX7DSHDG.pdf
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
Yuri
button. Thank you!
