How to add the IoT Gateway, FRDM-KW41Z and MEN-KW41Z modules to the tip end.
Question asked by zafer sen on Jun 26, 2018
Latest reply on Jul 3, 2018 by Dhvanil Patel
Hi. I have 8 FRDM-KW41Z, 1 MENP-KW41Z boards and a modular iot gateway. There are menp-kw41z where the signal of the gateway is not good enough. I am trying to reach the menp-kw41z remotely (with android application) by putting another frdm-kw41z board between the menp-kw41z and the gateway, but I can not connect (menp-kw41z not active and can not use it on the andorid application). Which guidelines should I follow for this? Can I solve this problem with the existing software? I want to set up a connection scheme like below.
Available software for frdm-kw41z: FRDM-KW41Z-REED-RGBLED-MCU
Available software for MENP-KW41Z: MENP-KW41Z-REED-Clickmodule-MCU
network structure
