LPC1788主频低,找别的替代
LPC1788主频低,找别的替代
youfu_ni
在使用LPC1788中频率低,想更换频率更高的单片机,能兼容引脚。
miguel_mendoza
Hi ni youfu,
The LPC4088 is the replace pin to pin compatible, unfortunately, run as the same frequency (120MHz) as LPC1788, but has an ARM Cortex-M4 so you have a better performance.
If you are looking for something faster, please check the LPC546xx family (LPC546xx), although it would not be pin to pin compatible.
regards,
Miguel
