Access to K82 MMCAU in UserMode
EugeneHiihtaja
Senior Contributor I
Hi !
K82 have PPB bus with esome contol registers and MMCAU.
Private peripheral (PPB) bus The PPB provides access to these modules: • ARM modules such as the NVIC, ETM, ITM, DWT, FBP, and ROM table • Freescale Miscellaneous Control Module (MCM) • Memory-Mapped Cryptographic Acceleration Unit (MMCAU)
I have configured MPU where access to MMCAU is enabled in UserMode,
e,g whole peripheral area  0x40000000 - 0xFFFFFFFF have RW rights.
But any read access to MMCAU range 0xE0081000 - ...1FFFF generate BusFault.
AIPS is also dosn't have any register for enable access to MMCAU.
How I can configure K82 blocks for have access to MMCAU address rang in UserMode ?
Eugene
jingpan
Hi Eugene,
MPU does not cover PPB(from 0xe0000000). Unprivileged access to the PPB causes BusFault errors unless otherwise stated. Notable exceptions are:
• Unprivileged accesses can be enabled to the Software Trigger Interrupt Register in the System Control Space by programming a control bit in the Configuration Control Register.
• For debug related resources.
Please download DDI0403D_arm_architecture_v7m_reference_manual.pdf from ARM website and check it at B3-707.
So your report is not a bug of ARM cortex-M4 or program error. It is just a feature of CORTEX-M4.
Regard,
Jing
