Compile error when download and make i.MX Yocto project
Question asked by zhang jiansheng on Jun 20, 2018
Latest reply on Jan 23, 2019 by Eric Cheng
I am using the imx 6sx SABRE-SDB development board. I want to download and build the i.MX Yocto project following the i.MX Yocto Project User's Guide, Rev. L4.9.11_1.0.0-ga+mx8-alpha, 09/2017. But it report an error when executing "bitbake fsl-image-validation-imx" command. The host environment is ubuntu 16.04 LTS on vmware. I don't know why it report the error. I have tried several times and the error remains.
Please tell me how resolve or avoid this problem. Thank you.
The error log is as following,
linkpro@linkpro-virtual-machine:~/Desktop/fsl-release-bsp/build_imx_x11$ bitbake fsl-image-validation-imx
WARNING: Host distribution "Ubuntu-16.04" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
Loading cache: 100% |############################################| Time: 0:00:01
Loaded 3049 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION        = "1.32.0"
BUILD_SYS         = "x86_64-linux"
NATIVELSBSTRING   = "Ubuntu-16.04"
TARGET_SYS        = "arm-poky-linux-gnueabi"
MACHINE           = "imx6sxsabresd"
DISTRO            = "fsl-imx-x11"
DISTRO_VERSION    = "4.9.11-1.0.0"
TUNE_FEATURES     = "arm armv7a vfp  neon        callconvention-hard        cortexa9"
TARGET_FPU        = "hard"
meta
meta-poky         = "HEAD:78890ea22750804e3e9113e76f7ca3d7234c8342"
meta-oe
meta-multimedia   = "HEAD:fe5c83312de11e80b85680ef237f8acb04b4b26e"
meta-freescale    = "HEAD:a398b50b7fc084a9e68cc3000c218d5028522a25"
meta-freescale-3rdparty = "HEAD:68314612e236cab1da82d72a0da62635a3523f84"
meta-freescale-distro = "HEAD:cd5c7a2539f40004f74126e9fdf08254fd9a6390"
meta-bsp
meta-sdk          = "HEAD:daba3340ecd8b358e0c6c415baeee0fcae95c525"
meta-browser      = "HEAD:10f6e3778d823ee1be106c126216c6f941088fbf"
meta-gnome
meta-networking
meta-python
meta-filesystems  = "HEAD:fe5c83312de11e80b85680ef237f8acb04b4b26e"
meta-qt5          = "HEAD:ff073f04109900fc07bf81e2f1df63c626caf342"
Initialising tasks: 100% |#######################################| Time: 0:00:27
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: assimp-3.3.1-r0 do_compile: oe_runmake failed
ERROR: assimp-3.3.1-r0 do_compile: Function failed: do_compile (log file is located at /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/temp/log.do_compile.119442)
ERROR: Logfile of failure stored in: /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/temp/log.do_compile.119442
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: make -j 2
| /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/x86_64-linux/usr/bin/cmake -H/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1 -B/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/build --check-build-system CMakeFiles/Makefile.cmake 0
| /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/x86_64-linux/usr/bin/cmake -E cmake_progress_start /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/build/CMakeFiles /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/build/CMakeFiles/progress.marks
| make -f CMakeFiles/Makefile2 all
| make[1]: Entering directory '/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/build'
| make -f code/CMakeFiles/assimp.dir/build.make code/CMakeFiles/assimp.dir/depend
| make[2]: Entering directory '/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/build'
| cd /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/build && /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/x86_64-linux/usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1 /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/code /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/build /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/build/code /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/build/code/CMakeFiles/assimp.dir/DependInfo.cmake --color=
| make[2]: Leaving directory '/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/build'
| make -f code/CMakeFiles/assimp.dir/build.make code/CMakeFiles/assimp.dir/build
| [  0%] Building CXX object code/CMakeFiles/assimp.dir/IFCBoolean.cpp.o
| [  1%] Building CXX object code/CMakeFiles/assimp.dir/IFCReaderGen.cpp.o
| cd /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/build/code && /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/x86_64-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-g++   -DASSIMP_BUILD_DLL_EXPORT -DASSIMP_BUILD_NO_C4D_IMPORTER -DASSIMP_BUILD_NO_OWN_ZLIB -DOPENDDLPARSER_BUILD -DOPENDDL_NO_USE_CPP11 -Dassimp_EXPORTS -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/. -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/build -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/include -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/imx6sxsabresd/usr/include -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/code/../contrib/rapidjson/include -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/code/../contrib/openddlparser/include -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/code/..  -march=armv7-a -mfpu=neon  -mfloat-abi=hard -mcpu=cortex-a9  --sysroot=/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/imx6sxsabresd  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0=/usr/src/debug/assimp/3.3.1-r0 -fdebug-prefix-map=/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/imx6sxsabresd=  -fvisibility-inlines-hidden  -march=armv7-a -mfpu=neon  -mfloat-abi=hard -mcpu=cortex-a9  --sysroot=/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/imx6sxsabresd -fvisibility=hidden -Wall -std=c++0x -fPIC   -o CMakeFiles/assimp.dir/IFCReaderGen.cpp.o -c /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/code/IFCReaderGen.cpp
| cd /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/build/code && /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/x86_64-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-g++   -DASSIMP_BUILD_DLL_EXPORT -DASSIMP_BUILD_NO_C4D_IMPORTER -DASSIMP_BUILD_NO_OWN_ZLIB -DOPENDDLPARSER_BUILD -DOPENDDL_NO_USE_CPP11 -Dassimp_EXPORTS -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/. -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/build -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/include -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/imx6sxsabresd/usr/include -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/code/../contrib/rapidjson/include -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/code/../contrib/openddlparser/include -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/code/..  -march=armv7-a -mfpu=neon  -mfloat-abi=hard -mcpu=cortex-a9  --sysroot=/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/imx6sxsabresd  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0=/usr/src/debug/assimp/3.3.1-r0 -fdebug-prefix-map=/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/imx6sxsabresd=  -fvisibility-inlines-hidden  -march=armv7-a -mfpu=neon  -mfloat-abi=hard -mcpu=cortex-a9  --sysroot=/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/imx6sxsabresd -fvisibility=hidden -Wall -std=c++0x -fPIC   -o CMakeFiles/assimp.dir/IFCBoolean.cpp.o -c /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/code/IFCBoolean.cpp
| [  2%] Building CXX object code/CMakeFiles/assimp.dir/IFCOpenings.cpp.o
| cd /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/build/code && /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/x86_64-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-g++   -DASSIMP_BUILD_DLL_EXPORT -DASSIMP_BUILD_NO_C4D_IMPORTER -DASSIMP_BUILD_NO_OWN_ZLIB -DOPENDDLPARSER_BUILD -DOPENDDL_NO_USE_CPP11 -Dassimp_EXPORTS -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/. -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/build -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/include -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/imx6sxsabresd/usr/include -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/code/../contrib/rapidjson/include -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/code/../contrib/openddlparser/include -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/code/..  -march=armv7-a -mfpu=neon  -mfloat-abi=hard -mcpu=cortex-a9  --sysroot=/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/imx6sxsabresd  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0=/usr/src/debug/assimp/3.3.1-r0 -fdebug-prefix-map=/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/imx6sxsabresd=  -fvisibility-inlines-hidden  -march=armv7-a -mfpu=neon  -mfloat-abi=hard -mcpu=cortex-a9  --sysroot=/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/imx6sxsabresd -fvisibility=hidden -Wall -std=c++0x -fPIC   -o CMakeFiles/assimp.dir/IFCOpenings.cpp.o -c /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/code/IFCOpenings.cpp
| ERROR: oe_runmake failed
| [  3%] Building CXX object code/CMakeFiles/assimp.dir/STEPFileReader.cpp.o
| cd /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/build/code && /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/x86_64-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-g++   -DASSIMP_BUILD_DLL_EXPORT -DASSIMP_BUILD_NO_C4D_IMPORTER -DASSIMP_BUILD_NO_OWN_ZLIB -DOPENDDLPARSER_BUILD -DOPENDDL_NO_USE_CPP11 -Dassimp_EXPORTS -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/. -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/build -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/include -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/imx6sxsabresd/usr/include -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/code/../contrib/rapidjson/include -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/code/../contrib/openddlparser/include -I/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/code/..  -march=armv7-a -mfpu=neon  -mfloat-abi=hard -mcpu=cortex-a9  --sysroot=/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/imx6sxsabresd  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0=/usr/src/debug/assimp/3.3.1-r0 -fdebug-prefix-map=/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/imx6sxsabresd=  -fvisibility-inlines-hidden  -march=armv7-a -mfpu=neon  -mfloat-abi=hard -mcpu=cortex-a9  --sysroot=/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/sysroots/imx6sxsabresd -fvisibility=hidden -Wall -std=c++0x -fPIC   -o CMakeFiles/assimp.dir/STEPFileReader.cpp.o -c /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/assimp-3.3.1/code/STEPFileReader.cpp
| arm-poky-linux-gnueabi-g++: internal compiler error: Killed (program cc1plus)
| Please submit a full bug report,
| with preprocessed source if appropriate.
| See <http://gcc.gnu.org/bugs.html> for instructions.
| code/CMakeFiles/assimp.dir/build.make:2681: recipe for target 'code/CMakeFiles/assimp.dir/IFCReaderGen.cpp.o' failed
| make[2]: *** [code/CMakeFiles/assimp.dir/IFCReaderGen.cpp.o] Error 4
| make[2]: *** Deleting file 'code/CMakeFiles/assimp.dir/IFCReaderGen.cpp.o'
| make[2]: *** Waiting for unfinished jobs....
| CMakeFiles/Makefile2:120: recipe for target 'code/CMakeFiles/assimp.dir/all' failed
| make[1]: *** [code/CMakeFiles/assimp.dir/all] Error 2
| make[1]: Leaving directory '/home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/build'
| Makefile:130: recipe for target 'all' failed
| make: *** [all] Error 2
| ERROR: Function failed: do_compile (log file is located at /home/linkpro/Desktop/fsl-release-bsp/build_imx_x11/tmp/work/cortexa9hf-neon-mx6sx-poky-linux-gnueabi/assimp/3.3.1-r0/temp/log.do_compile.119442)
ERROR: Task (/home/linkpro/Desktop/fsl-release-bsp/sources/meta-fsl-bsp-release/imx/meta-sdk/recipes-graphics/assimp/assimp_3.3.1.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3242 tasks of which 3239 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
