I believe I have accidentally erased the firmware from my OM14510-SJA1105TJP: Automotive Ethernet Switch Application Board with Flash Magic.
bannanabagle
Is there any way I can download the firmware? I believe this is the reason why I am having issues with running example_com files.
Hui_Ma
I would recommend to check with your local NXP distributor, who could help you to get OM14510-SJA1105TJP board LPC1788 MCU firmware file.
Thank you for the attention.
Mike
