Thanks for the reply,
Tried setting bit 6 in the SPI1CR1 but still no pules train from SCK1 also checked the register addresses
against the documentation and they are correct. I did toggle the SCK1 bit through the port H register
and it works so it's not a bad chip. Also tried reading the SPI1SR register just before the write to the
register and still no luck.
Message Edited by MTopward on
2008-11-11 06:27 PM
