I am trying to build WolfSSL for MPC5748G microcontroller.
If any one has done this earlier, please let me know the steps you followed.
At present we are using GHS compiler for building for MPC5748G.
Since a large team is using the same compiler, we have license crunch.
So, I am trying to find out if gcc can be used as cross compiler for this.
If any one has used gcc cross compiler for MPC5748G, please let me know the details.
from my point of view, this is rather question to wolfSSL development team. NXP compiler for e200-VLE is based on gcc 4.9.4, binutils 2.28, so if this is supported compiler for wolfSSL, you should be able to compile this successfully.
Please try to ask your question at the community below:
Community | wolfSSL Embedded SSL/TLS Library
Martin
