L2.6.35_1.1.0_130130_source 在 Ubuntu 14.04 上的安装使用
Question asked by guangwang yang on Jun 13, 2018
各位大神好,我现在需要使用imx287进行相关开发(系统是Ubuntu 14.04),下载L2.6.35_1.1.0_130130_source安装完之后编译总是出错,在网上参考之后下载了些文件执行之后运行 ./ltib -m config 还是报错,烦请大神们指导一下,多谢!
下载的文件
0001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_12.04_64bit_OS.patch  patch-dist-ubuntu12.04.patch
ubuntu-ltib-patch
0001_make_L3.0.35_4.1.0_compile_on_Ubuntu_14.04_64bit_OS.patch ================================================================================
出现的错误:
Processing platform: Host support packages
using /home/vmware/project/ltib/L2.6.35_1.1.0_130130_source/build/config/platform/host/ltib.preconfig
Processing: fake-provides
Processing: mkspooflinks
Processing: distcc
Processing: ccache
Processing: bison
Processing: flex
Processing: texinfo
Processing: autoconf
Processing: libtool
Processing: lkc
Processing: wget
Processing: uclinux-cksum
Processing: genext2fs
Processing: genromfs
Processing: gen_init_cpio
Processing: u-boot-tools
Processing: mtd-utils
Processing: pkgconfig
Processing: dtc
Processing: cramfs
Processing: unifdef
Processing: sparse
Processing: git
Processing: tunctl
Processing: mux_server
Processing: elftosb
Build path taken because: no prebuilt rpm,
rpmbuild --dbpath ///opt/freescale/ltib/var/lib/rpm --target x86_64 --define '_unpackaged_files_terminate_build 0' --define '_target_cpu x86_64' --define '__strip strip' --define '_topdir /opt/freescale/ltib/usr/src/rpm' --define '_prefix /opt/freescale/ltib/usr' --define '_tmppath /home/vmware/project/ltib/L2.6.35_1.1.0_130130_source/build/tmp' --define '_rpmdir /opt/freescale/ltib/usr/src/rpm/RPMS' --define '_mandir /opt/freescale/ltib/usr/share/man' --define '_sysconfdir /opt/freescale/ltib/etc' --define '_localstatedir /var' -bb --clean --rmsource /home/vmware/project/ltib/L2.6.35_1.1.0_130130_source/build/dist/lfs-5.1/elftosb/elftosb.spec
Building target platforms: x86_64
Building for target x86_64
Executing(%prep): /bin/sh -e /home/vmware/project/ltib/L2.6.35_1.1.0_130130_source/build/tmp/rpm-tmp.28030
+ umask 022
+ cd /opt/freescale/ltib/usr/src/rpm/BUILD
+ rm -rf elftosb-2.6.35.3-1.1.0
+ tar -xvvf -
+ /bin/gzip -dc /opt/freescale/ltib/usr/src/rpm/SOURCES/elftosb-2.6.35.3-1.1.0.tar.gz
drwxrwxr-x root/root 0 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/
-rw-rw-r-- root/root 1533 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/COPYING
-rw-rw-r-- root/root 1884 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/ReadMe.txt
drwxrwxr-x root/root 0 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/bdfiles/
-rw-rw-r-- root/root 3401 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/bdfiles/basic_test_cmd.e
-rw-rw-r-- root/root 5404 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/bdfiles/complex.bd
-rw-rw-r-- root/root 563 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/bdfiles/habtest.bd
-rw-rw-r-- root/root 112 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/bdfiles/simple.e
-rw-rw-r-- root/root 2659 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/bdfiles/test_cmd.e
drwxrwxr-x root/root 0 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/
-rw-rw-r-- root/root 2321 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/AESKey.cpp
-rw-rw-r-- root/root 3654 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/AESKey.h
-rw-rw-r-- root/root 2421 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/Blob.cpp
-rw-rw-r-- root/root 1553 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/Blob.h
-rw-rw-r-- root/root 1360 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/BootImage.h
-rw-rw-r-- root/root 6066 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/DataSource.cpp
-rw-rw-r-- root/root 9216 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/DataSource.h
-rw-rw-r-- root/root 3660 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/DataSourceImager.cpp
-rw-rw-r-- root/root 1036 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/DataSourceImager.h
-rw-rw-r-- root/root 1745 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/DataTarget.cpp
-rw-rw-r-- root/root 3998 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/DataTarget.h
-rw-rw-r-- root/root 10445 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/ELF.h
-rw-rw-r-- root/root 14307 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/ELFSourceFile.cpp
-rw-rw-r-- root/root 6906 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/ELFSourceFile.h
-rw-rw-r-- root/root 46497 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/EncoreBootImage.cpp
-rw-rw-r-- root/root 35659 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/EncoreBootImage.h
-rw-rw-r-- root/root 4653 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/EndianUtilities.h
-rw-rw-r-- root/root 2576 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/EvalContext.cpp
-rw-rw-r-- root/root 2633 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/EvalContext.h
-rw-rw-r-- root/root 1914 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/ExcludesListMatcher.cpp
-rw-rw-r-- root/root 1915 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/ExcludesListMatcher.h
-rw-rw-r-- root/root 3245 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/GHSSecInfo.cpp
-rw-rw-r-- root/root 2135 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/GHSSecInfo.h
-rw-rw-r-- root/root 2511 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/GlobMatcher.cpp
-rw-rw-r-- root/root 1590 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/GlobMatcher.h
-rw-rw-r-- root/root 812 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/HexValues.cpp
-rw-rw-r-- root/root 549 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/HexValues.h
-rw-rw-r-- root/root 2688 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/IVTDataSource.cpp
-rw-rw-r-- root/root 10408 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/IVTDataSource.h
-rw-rw-r-- root/root 1516 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/Logging.cpp
-rw-rw-r-- root/root 7048 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/Logging.h
-rw-rw-r-- root/root 1185 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/Operation.cpp
-rw-rw-r-- root/root 4305 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/Operation.h
-rw-rw-r-- root/root 1466 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/OptionContext.h
-rw-rw-r-- root/root 4180 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/OptionDictionary.cpp
-rw-rw-r-- root/root 3236 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/OptionDictionary.h
-rw-rw-r-- root/root 184 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/OutputSection.cpp
-rw-rw-r-- root/root 1896 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/OutputSection.h
-rw-rw-r-- root/root 1557 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/Random.cpp
-rw-rw-r-- root/root 1138 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/Random.h
-rw-rw-r-- root/root 2251 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/RijndaelCBCMAC.cpp
-rw-rw-r-- root/root 1435 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/RijndaelCBCMAC.h
-rw-rw-r-- root/root 7335 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/SHA1.cpp
-rw-rw-r-- root/root 3735 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/SHA1.h
-rw-rw-r-- root/root 5200 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/SRecordSourceFile.cpp
-rw-rw-r-- root/root 2242 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/SRecordSourceFile.h
-rw-rw-r-- root/root 3210 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/SearchPath.cpp
-rw-rw-r-- root/root 1360 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/SearchPath.h
-rw-rw-r-- root/root 4177 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/SourceFile.cpp
-rw-rw-r-- root/root 4696 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/SourceFile.h
-rw-rw-r-- root/root 17992 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/StELFFile.cpp
-rw-rw-r-- root/root 6620 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/StELFFile.h
-rw-rw-r-- root/root 14292 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/StExecutableImage.cpp
-rw-rw-r-- root/root 9642 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/StExecutableImage.h
-rw-rw-r-- root/root 5980 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/StSRecordFile.cpp
-rw-rw-r-- root/root 3484 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/StSRecordFile.h
-rw-rw-r-- root/root 1617 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/StringMatcher.h
-rw-rw-r-- root/root 842 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/Value.cpp
-rw-rw-r-- root/root 4152 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/Value.h
-rw-rw-r-- root/root 3369 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/Version.cpp
-rw-rw-r-- root/root 1031 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/Version.h
-rw-rw-r-- root/root 15294 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/crc.cpp
-rw-rw-r-- root/root 965 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/crc.h
-rw-rw-r-- root/root 1749 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/format_string.cpp
-rw-rw-r-- root/root 411 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/format_string.h
-rw-rw-r-- root/root 428 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/int_size.h
-rw-rw-r-- root/root 33274 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/options.cpp
-rw-rw-r-- root/root 16656 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/options.h
-rw-rw-r-- root/root 90763 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/rijndael.cpp
-rw-rw-r-- root/root 5729 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/rijndael.h
-rw-rw-r-- root/root 6510 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/smart_ptr.h
-rw-rw-r-- root/root 286 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/stdafx.cpp
-rw-rw-r-- root/root 2238 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/common/stdafx.h
-rw-rw-r-- root/root 201 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb.ccscc
-rw-rw-r-- root/root 16092160 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb.ncb
-rw-rw-r-- root/root 3000 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb.sln
-rw-rw-r-- root/root 56320 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb.suo
drwxrwxr-x root/root 0 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb.xcodeproj/
-rw-rw-r-- root/root 46844 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb.xcodeproj/creed.mode1
-rw-rw-r-- root/root 47231 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb.xcodeproj/creed.mode1v3
-rw-rw-r-- root/root 132838 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb.xcodeproj/creed.pbxuser
-rw-rw-r-- root/root 62729 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb.xcodeproj/project.pbxproj
drwxrwxr-x root/root 0 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb2/
-rw-rw-r-- root/root 1958 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb2/BootImageGenerator.cpp
-rw-rw-r-- root/root 2064 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb2/BootImageGenerator.h
-rw-rw-r-- root/root 43570 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb2/ConversionController.cpp
-rw-rw-r-- root/root 5713 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb2/ConversionController.h
-rw-rw-r-- root/root 9427 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb2/Doxyfile
-rw-rw-r-- root/root 31194 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb2/ElftosbAST.cpp
-rw-rw-r-- root/root 31790 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb2/ElftosbAST.h
-rw-rw-r-- root/root 562 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb2/ElftosbErrors.h
-rw-rw-r-- root/root 3254 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb2/ElftosbLexer.cpp
-rw-rw-r-- root/root 2752 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb2/ElftosbLexer.h
-rw-rw-r-- root/root 8371 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb2/EncoreBootImageGenerator.cpp
-rw-rw-r-- root/root 1853 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb2/EncoreBootImageGenerator.h
-rw-rw-r-- root/root 6344 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb2/FlexLexer.h
-rw-rw-r-- root/root 17088 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb2/elftosb.cpp
-rw-rw-r-- root/root 11601 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb2/elftosb2.vcproj
-rw-rw-r-- root/root 65498 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb2/elftosb_lexer.cpp
-rw-rw-r-- root/root 7107 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb2/elftosb_lexer.l
-rw-rw-r-- root/root 99126 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb2/elftosb_parser.tab.cpp
-rw-rw-r-- root/root 4106 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb2/elftosb_parser.tab.hpp
-rw-rw-r-- root/root 25821 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/elftosb2/elftosb_parser.y
drwxrwxr-x root/root 0 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/encryptgpk/
-rw-rw-r-- root/root 11171 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/encryptgpk/encryptgpk.cpp
-rw-rw-r-- root/root 7040 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/encryptgpk/encryptgpk.vcproj
drwxrwxr-x root/root 0 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/keygen/
-rw-rw-r-- root/root 9424 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/keygen/Doxyfile
-rw-rw-r-- root/root 7784 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/keygen/keygen.cpp
-rw-rw-r-- root/root 9576 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/keygen/keygen.vcproj
-rw-rw-r-- root/root 838 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/makefile
-rw-rw-r-- root/root 4369 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/makefile.rules
drwxrwxr-x root/root 0 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/sbtool/
-rw-rw-r-- root/root 9424 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/sbtool/Doxyfile
-rw-rw-r-- root/root 13027 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/sbtool/EncoreBootImageReader.cpp
-rw-rw-r-- root/root 3742 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/sbtool/EncoreBootImageReader.h
-rw-rw-r-- root/root 19397 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/sbtool/sbtool.cpp
-rw-rw-r-- root/root 9866 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/sbtool/sbtool.vcproj
-rw-rw-r-- root/root 1675 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/stdafx.h
-rw-rw-r-- root/root 692 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/test_elftosb.bat
-rwxrwxr-x root/root 892 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/test_elftosb.sh
drwxrwxr-x root/root 0 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/test_files/
-rw-rw-r-- root/root 1054698 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/test_files/ProfileSeed.bin
-rw-rw-r-- root/root 51200 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/test_files/ProfileSeedFile50k.bin
-rw-rw-r-- root/root 2444 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/test_files/hello_NOR_arm
-rw-rw-r-- root/root 1432 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/test_files/hello_NOR_arm.map
-rw-rw-r-- root/root 2496 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/test_files/hello_NOR_mixed
-rw-rw-r-- root/root 1476 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/test_files/hello_NOR_mixed.map
-rw-rw-r-- root/root 2348 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/test_files/hello_NOR_thumb
-rw-rw-r-- root/root 1432 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/test_files/hello_NOR_thumb.map
-rw-rw-r-- root/root 1292292 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/test_files/hostlink
-rw-rw-r-- root/root 1909984 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/test_files/player_linfix.elf
-rw-rw-r-- root/root 2884 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/test_files/plugin_complex
-rw-rw-r-- root/root 2068 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/test_files/plugin_hello
-rw-rw-r-- root/root 156236 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/test_files/redboot_gcc.srec
-rw-rw-r-- root/root 38496 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/test_files/rom_nand_ldr_profile
-rw-rw-r-- root/root 1451135 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/test_files/sd_player_gcc
-rw-rw-r-- root/root 539928 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/test_files/sd_player_gcc.srec
-rw-rw-r-- root/root 33 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/test_files/test0.key
drwxrwxr-x root/root 0 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/winsupport/
-rw-rw-r-- root/root 0 2010-09-20 21:28 elftosb-2.6.35.3-1.1.0/winsupport/unistd.h
+ STATUS=0
+ [ 0 -ne 0 ]
+ cd elftosb-2.6.35.3-1.1.0
+ exit 0
Executing(%build): /bin/sh -e /home/vmware/project/ltib/L2.6.35_1.1.0_130130_source/build/tmp/rpm-tmp.28030
+ umask 022
+ make
make -C bld/linux -f /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/makefile.rules SRC_DIR=/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0 all;
make[1]: Entering directory `/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/bld/linux'
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/AESKey.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/Blob.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/crc.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/DataSource.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/DataTarget.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/ELFSourceFile.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/EncoreBootImage.cpp
In file included from /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/EncoreBootImage.cpp:8:0:
/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/EncoreBootImage.h:101:32: warning: multi-character character constant [-Wmultichar]
ROM_IMAGE_HEADER_SIGNATURE = 'STMP', //!< Signature in #elftosb::EncoreBootImage::boot_image_header_t::m_signature.
/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/EncoreBootImage.h:102:33: warning: multi-character character constant [-Wmultichar]
ROM_IMAGE_HEADER_SIGNATURE2 = 'sgtl', //!< Value for #elftosb::EncoreBootImage::boot_image_header_t::m_signature2;
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/EvalContext.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/GHSSecInfo.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/GlobMatcher.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/HexValues.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/Logging.cpp
/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/Logging.cpp: In member function 'virtual void StdoutLogger::_log(const char*)':
/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/Logging.cpp:89:12: warning: format not a string literal and no format arguments [-Wformat-security]
printf(msg);
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/Operation.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/OptionDictionary.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/options.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/OutputSection.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/Random.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/RijndaelCBCMAC.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/rijndael.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/SHA1.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/SourceFile.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/SRecordSourceFile.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/stdafx.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/StELFFile.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/StExecutableImage.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/StSRecordFile.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/Value.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/Version.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/format_string.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/ExcludesListMatcher.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/SearchPath.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/DataSourceImager.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common/IVTDataSource.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2/BootImageGenerator.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2/ConversionController.cpp
In file included from /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2/EncoreBootImageGenerator.h:11:0,
from /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2/ConversionController.cpp:15:
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2/ElftosbAST.cpp
/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2/ElftosbAST.cpp: In member function 'virtual void elftosb::SectionMatchListASTNode::printTree(int) const':
/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2/ElftosbAST.cpp:1204:38: warning: too many arguments for format [-Wformat-extra-args]
printf("source: ", m_source->c_str());
/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2/ElftosbAST.cpp: In member function 'virtual void elftosb::SymbolASTNode::printTree(int) const':
/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2/ElftosbAST.cpp:1286:16: warning: format not a string literal and no format arguments [-Wformat-security]
printf(source);
/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2/ElftosbAST.cpp:1295:16: warning: format not a string literal and no format arguments [-Wformat-security]
printf(symbol);
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2/elftosb.cpp
In file included from /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2/elftosb.cpp:17:0:
/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2/elftosb.cpp: In member function 'void elftosbTool::printUsage(Options&)':
/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2/elftosb.cpp:320:33: warning: too many arguments for format [-Wformat-extra-args]
printf(k_usageText, k_toolName);
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2/elftosb_lexer.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2/ElftosbLexer.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2/elftosb_parser.tab.cpp
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2/EncoreBootImageGenerator.cpp
from /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/elftosb2/EncoreBootImageGenerator.cpp:8:
gcc AESKey.o Blob.o crc.o DataSource.o DataTarget.o ELFSourceFile.o EncoreBootImage.o EvalContext.o GHSSecInfo.o GlobMatcher.o HexValues.o Logging.o Operation.o OptionDictionary.o options.o OutputSection.o Random.o RijndaelCBCMAC.o rijndael.o SHA1.o SourceFile.o SRecordSourceFile.o stdafx.o StELFFile.o StExecutableImage.o StSRecordFile.o Value.o Version.o format_string.o ExcludesListMatcher.o SearchPath.o DataSourceImager.o IVTDataSource.o BootImageGenerator.o ConversionController.o ElftosbAST.o elftosb.o elftosb_lexer.o ElftosbLexer.o elftosb_parser.tab.o EncoreBootImageGenerator.o -lstdc++ -o elftosb
/usr/bin/ld: ElftosbAST.o: undefined reference to symbol 'powf@@GLIBC_2.2.5'
//lib/x86_64-linux-gnu/libm.so.6: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
make[1]: *** [elftosb] Error 1
make[1]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-2.6.35.3-1.1.0/bld/linux'
make: *** [all] Error 2
error: Bad exit status from /home/vmware/project/ltib/L2.6.35_1.1.0_130130_source/build/tmp/rpm-tmp.28030 (%build)
RPM build errors:
Build time for elftosb: 11 seconds
Failed building elftosb
Died at ./ltib line 1392.
traceback:
main::build_host_rpms:1392
main::host_checks:1447
main:554
