In C the header file chip.h which include such things as adc15xx.h sets up the addresses for all the peripheral registers.
When writing a function in assembler, is there a way of accessing this information?
example: C knows that ADC->CTRL refers to the control register of the ADC converter and compiles the correct value for the address of this register, but can I access that information from assember, by writing something similar to LDR R3,=ADC->CTRL instead of first having to look up its address in the manual and define ADC_CTRL again as .equ ADC_CTRL, 0x40000000 ?
Hi Ian Benton,
Thank you for your interest in NXP Semiconductor products and the opportunity to serve you.
When debugging the demo, you can see assemble codes which seems like the interpretation of C codes.
I'd highly recommend you refer to these assemble codes for details.
TIC
