MPC5604 read the data flash(ADR:0x008007D0),the system halted!!!
debug : the data flash MCR.ERR = 1 , the LML is locked but init the LML is disable ;
what i do ???
could you please specify, which microcontroller you use? MPC5604B or MPC5604P?
What project is downloaded in the flash memory?
From your description, it is impossible to tell you, what is wrong.
Martin
