Failed during ddr calibration
macochen
iMX6DL 目前使用 ddr test tool 2.8.0 進行檢測 PCBA 的 ddr calibration 時,出現 Error : Failed during ddr calibration 後來嘗試用 register configuration 更換 inc file 參數,還是顯是同樣的訊息。請問是什麼原因 ?
( DDR part number : MT41K128M16JT-125:K , 請參考我附件資訊 )
Hi Maco
from attached Calibration log.txt.zip log seems that memory is not working at all.
May be suggested to check memory signals with oscilloscope and recheck guidelines given in
i.MX6 System Development User’s Guide
https://www.nxp.com/docs/en/user-guide/IMX6DQ6SDLHDG.pdf
Freescale i.MX6 DRAM Port Application Guide-DDR3
