I am using S32K144 devices, I want to build a CAN FD network but I want to simulate the system first.
Is there any simulator allowing that?
Thanks!
Is there any CAD tool to simulate a CAN network with S32k144 nodes?
If you want to simulate a CAN network you can use 2 devices one that is a Sender and another as Receiver, or You can use a loop back mode to send and receive with the same chip but need to configure accordingly the MBs one as send and another as receiver !
