iMX8M EVK MX8-DSI-OLED1
OdedAvraham
Senior Contributor II
What is the manufacturer part number of the display used in the MX8-DSI-OLED1?
microajim
I asked via setting up a case at support.nxp.com and got back the answer that it is the US Micro Products USMP-A055-108192CDX-A0. I found a URL here:
https://www.usmicroproducts.com/sites/default/files/USMP-A055-108192CDX-A0.pdf .
joanxie
refer to the linux reference manual, the mipi dsi driver in the bsp is:mxcfb_hx8369_wvga.c, maybe you can refer to it.
OdedAvraham
Can you forward the question to someone can help provide the OLED manufacturer part number?
Thanks.
Oded a
OdedAvraham
Joan hi,
To our understanding the MX8M DSI OLED kit includes  MODULE_DESCRIPTION("Raydium RM67191") CHIP.
The correct driver should be:
https://source.codeaurora.org/external/imx/linux-imx/tree/drivers/gpu/drm/panel/panel-raydium-rm6719...
Looking inside I didnot find any clue for the panel part number used.
Waiting for update
Oded A
