IPU, CSI Timing
IPU, CSI Timing
ieio
Hi all,
I am working to a camera driver, and I am testing it with gstreamer.
My gst pipe is gst-launch-1.0 -e -v imxv4l2videosrc device=/dev/video0 ! imxipuvideosink so I a using mxc_v4l2_capture.c
If I well understood I set CSIn (primary, secondary) and I link it to a IPU (IPU0 and IPU1) and in the IPU the image can be elaborated (deinterlaced,rotated, converted).
My doubt is: as I have camera timings like, Active Vertical Width, Total Vertical Width, Vertical Back Porch and so on, where I should set this timings in the IPU?
If it is not in the IPU where they should be set where, should I set them?
Please point me to the code that handle input video timings.
Bio_TICFSL
Hi ieio,
The following link will help you with timming:
https://community.nxp.com/message/579476
AC timing of IPUx_CSI input signals.
ieio
Thanks Bio_TICFSL,
I have not found where they talk about timing in the first link, while the second one is really a good hint.
I found in the manual that there are special register in the IPU for image timing: SENS_FRM_WIDTH, SENS_FRM_HEIGHT, HSC, VSC, ACT_FRM_HEIGHT and ACT_FRM_WIDTH.
Any good starting points about understating how this registers are integrating in the mxc_capture framework?
