Freemaster Real-time Recorder graph
Question asked by CARLO CUROTTO on May 30, 2018
Latest reply on Jun 6, 2018 by Daniel Martynek
Hello everybody,
I'm using the Freemaster Serial Communication Driver to monitor some variables that change fast,
(The Microcontroller is a Tomar S12VR). The Driver has been set correctly and it is working properly.
My question is about the Recorder graph.
At the moment I'm monitoring a single variable using the autorun mode  and the FMSTR_TriggerRec() function is used to receive the buffer whenever it's ready.
My goal is to have a real-time Recorder graph (like the Scope graph)
updated every time a new buffer data is downloaded, without loosing previous data.
The problem is that every time a new buffer data is downloaded, it replaces the old one.
Is there a way to add every new buffer data to the old ones in real-time?
Please note:  I need a real-time graph like the Scope graph.  Changing the “time base multiple” (in the Recorder global properties) doesn’t solve my problem.
Thanks for your help
